interior lights
Old 02-20-2003, 08:33 AM
KGBSJU's Avatar
interior lights
This sounds strange but when I push down hard on my brakes the interior lights in my car turn on....well just the dome and front door lights...what could that be?
KGBSJU is offline
Old 02-20-2003, 09:03 AM
97blackSE's Avatar
what could that be? WEIRD!!!...and ANNOYING!!!
97blackSE is offline
Old 02-20-2003, 09:15 AM
dvpatel99se's Avatar
Re: interior lights
What could that be?? It seems that you are pinching some wiring by the brake pedal. Better fix it quick before the wires get cut or else some lights will totally quit working.
dvpatel99se is offline
Old 02-23-2003, 09:29 AM
KGBSJU's Avatar
Re: Re: interior lights
ok thanks...ill check that out
KGBSJU is offline
Old 02-23-2003, 10:21 AM
95emeraldgxe's Avatar
lol that is one of the funniest things i've ever heard - check your grounds
95emeraldgxe is offline
Old 02-23-2003, 01:32 PM
My other car is a Hybrid
Chunger's Avatar
Like stated above... door switch circuit:
Check the door switches or check for a grounding door trigger wire to the aftermarket alarm near your break pedal (probably green in color)
Chunger is offline
Old 02-23-2003, 01:43 PM
I aim to misbehave.
Speebs's Avatar
Is this when you're moving or when you're stopped? If moving, then maybe the switch inside the door is loose and the extra force exerted by the door is causing the lights to come on. Seems unlikely, but if your wires are okay...
Speebs is offline
Old 02-24-2003, 05:19 AM
multiplexor's Avatar
maybe when you press on your brake pedal, the extra lights that pedal lights up, drains more power from your battery and makes your lights dim?
could this be fixed with a hyper ground system? or even the DIY kind...?
multiplexor is offline
Maximan190
12-16-2015 06:01 AM
sdotcarter
09-02-2015 09:53 PM
A32goldylocks
09-02-2015 06:39 AM
Quick Reply: interior lights
