What does the fuel pump relay look like?
Im trying to find the fuel pump relay behind the drivers side kick panel. I know the color wires i need and i think i see them but i just want to make sure. Its a black circular cylinder with 12v and a number on it. Can Anyone help me???
Brett
Brett
You need to remove the larger plastic piece/panel just left of the dead pedal... It is mounted on the left side of the rectangular hole. There are 2 relays with a 10mm bolt holding it. One of them is the FP relay.
Originally posted by Krash513
Ok the pain in the a$$ part is done, its all wired up and the wires are hidden, i started the car (thank god!) and now how long would it run at idle before it would die if the switch was off?
I've seen your many posts about this. I was wondering if there was a reason you didn't just wire a switch inline with the fuse rather than the relay. The only reason I could think is difficulty to find, but I really don't think it would be an issue. In any case, good job on the mod.
Originally posted by jargoone
Probably for less than 15 seconds or so. But why don't you just try it? It would be nice to know, and you won't hurt anything.
jmlee44
10-02-2022 02:13 PM
06-06-2017 02:01 PM
