Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Thread Tools Display Modes
Old 12-15-2002, 10:44 PM   #1
Send a message via AIM to DanSE
Is it bad to have just lowering springs without KYB AGX?
I want to lower my max, probobly with Eibachs, but I dont have the money to go all out with KYB AGX'S which is what I plan on eventually doing. I have heard different opinions on just getting the springs without going all out. Some say that the stock shocks cannot take this, some say it can. Anyone have just lowering springs here?(eibachs) Hows the ride?
Thanks,
Dan
p.s.-How do the settings work on the AGX's?
DanSE is offline   Reply With Quote
Old 12-15-2002, 11:20 PM   #2
Re: Is it bad to have just lowering springs without KYB AGX?
To adjust KYB you just turn a knob or a screw on the shocks, 1 - 4 on the front and 1 - 8 on the rear (yours maybe different), to adjust stiffness or the ride. I believe its only adjusting the shock dampening (or is it rebound) Im not sure.
As for the stock shocks with Eibachs, you will shorten the life of the shock since it was not designed to operate at a lower ride height than stock. (decreased shock travel)
KYB actually inserts several warnings about ride height with the AGX line. I have gone through a few sets of AGX's with Cattmans coilovers, from lowering the car too much. Even worse with the Gen IIs. (way more then 2"). The set I have on now is dead.
You should be ok with the Eibachs/AGX as it doesn't lower the car as much. (about 2" i think.)
__________________
'97SE 5Speed, Cattman Coils,CAI,Cattman Y-pipe,RT cat,Greddy cat-back,Stillen FSTB,RSB,Stillen Flywheel, Stillen short shifter. 18" Konig Reigns under Yokohama Parada tires.
Want Ksport Coilovers? Work Wheels? Spec Clutches? Contact Neil @ Millenniun Motorsports sales@mmsnyc.com
MAXIN is offline   Reply With Quote
Old 12-16-2002, 06:48 AM   #3
Send a message via AIM to njmaxseltd
You can couple Eibachs with KYB GR2 if you don't need adjustability. There's a pretty firm strut.
I definately would not use stock components with Eibachs. There a pretty stiff spring and the valving on the OEM components is no where near tight enough to control Eibachs.
It's not a matter of the struts failing, but your handling will get worse over not so smooth road surfaces. Thats due to the fact that the OEM struts cannot control the spring force. You'll get tossed around a lot more. Ideally you want the strut to absorbe the impact then immediately firm up to stop the spring from ossolating(sp?). The valving on your OEM components can't do that. Toss some ware and tare already on them into the picture and you got a setup that really doesn't benifit you.
__________________
njmaxseltd is offline   Reply With Quote
Old 12-16-2002, 07:10 AM   #4
Super Moderator
JAY25's Avatar
Send a message via AIM to JAY25
Quote:
Thanks,
Dan
If your car does not have some where around 120K , you should be good. I drove with intrax and stock shocks for like a year and a half in a pothole infested city, my shocks were still fine. Is just a mushy ride and thats it. I know quite a few old dogs here that are on sprint springs and stock shocks and been driving around like that for a while.
__________________
www.titanstaffords.com yes that is my new hobby now
JAY25 is offline   Reply With Quote
Old 12-16-2002, 07:26 AM   #5
Send a message via ICQ to Lime Send a message via AIM to Lime Send a message via Yahoo to Lime
If your car has over 75k miles on it, I would not recommend running on stock struts and shocks. Especially the rear shocks; they do not hold up. My car had about 65k miles on it when one of the rear shocks blew.
__________________
erica
1998 maxima SOLD
1985 Toyota MR2
1988 Nissan Pulsar NX SE
car pix
Lime is offline   Reply With Quote
Old 12-16-2002, 07:30 AM   #6
I've had on Eibachs now for about ten months. The rear drop is 1.3" and 1.5" for the front (pro kit that is). I've had no problems whatsoever with the ride quality on my stock shocks and I now have 121k miles. I am getting KYB AGX's today, but not because of the ride, I just want it to handle a little better.
visionmax is offline   Reply With Quote
Old 12-16-2002, 08:54 AM   #7
Thanks a lot for the replys everyone. I guess I am going to save up and buy them together and install them together, I need to get my frankencar first anyway.
Lime: sorry about your car, what set up do you have on now?
Thanks,
Dan
Old 12-16-2002, 11:14 AM   #8
Send a message via AIM to 95emeraldgxe
Thanks,
Dan
lime has B&G's with AGX struts
__________________
TBP-NYC #004, FnF-NYC #008, 7-11 Crew-NYC #008, DMM-NYC #004, ILP-NYC #001, OBMC # 66, BMC # 69
95emeraldgxe is offline   Reply With Quote
Old 12-16-2002, 11:33 AM   #9
I had H&R springs for about two years (roughly 25k miles?) before I got my AGXes. They were fine for me, but if you are going to get both, might as well get em done at the same time, to either save money on install if you pay a shop to do it, or save time yourself instead of undoing everything twice. Besides, if a stock strut blows, you're not going to want to drive on it for too long, then you'd have to wait until you order and get your AGXes, etc... If you don't got the money for both, save up until you can afford both.
__________________
1998 Maxima GLE - Konig Tantrum 18x8 / Pirelli P7000 Supersport / MEVI / Osram HIDs / PIAA 1100x Driving Lights / Indiglo Gauges / Front Clears / Red/Clear Taillamps / FTSB / Addco RSB / H&R Springs / PR CAI / RT CC / Cattman Y / Cattman B / Wilwood Big Brake Kit
Maxima LIVE CHAT @ #maxima on EFnet
mrb23 is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
