Denso Iridium Spark Plugs
Old 12-04-2002, 05:23 PM
Maxima.org Sponsor and Donating Maxima.org Member
talkinghorse's Avatar
I will soon be replacing the plugs in my '98 SE...has anyone tried Denso Iridium plugs? Any thoughts/recommendations? ed
talkinghorse is offline
Old 12-04-2002, 05:29 PM
Rogo02SE's Avatar
Go with NGK's platnium!!!
Densos are good for Toyotas.
Nissan uses NGK's as OE and if its not broke "DON'T FIX IT"
Rogo02SE is offline
Old 12-04-2002, 05:32 PM
gambit's Avatar
NGK Coppers are much more economical. Although they have half the durability, they cost approximately 5x less. Also, copper plugs actually give a better spark. Since changing plugs isn't too difficult once you know how to do it, go with the coppers like I did; you won't be sorry.
-gambit
gambit is offline
Old 12-04-2002, 06:02 PM
SamMan23's Avatar
-gambit
have you noticed better drivability with this better spark? I hear everybody say it, but nobody says, it feels like the engine is stronger.
SamMan23 is offline
Old 12-04-2002, 06:36 PM
Needs non-Maxima Friends
nismo2020's Avatar
i run densos
pricey but i like them
nismo2020 is offline
Old 12-05-2002, 09:07 AM
TonyGotSkilz's Avatar
I've got bosch platnum +4 i've heard bad things so i'm switching to NGK next tune up in janurary. Do they make platnum ngks?
TonyGotSkilz is offline
Old 12-05-2002, 09:22 AM
dwapenyi's Avatar
That's the thing with sprak plugs. How different can they be in terms of power? 1-2hp at most if you're lucky, for an NA car. The main difference is longevity.
If you're running boost, then the spark plug types, copper, platinum etc, will play a bigger factor in the mod game.
DW
dwapenyi is offline
Old 12-05-2002, 09:51 AM
hacim105's Avatar
I have the denso iridiums, no big deal. Better spark doeesn't really do anything but make the car run and fire better and they last longer. They don't add horse power or anything.
Just get spark plugs that work well. NGK are specifically for nissans I think. But if you get denso's or NGK's it won't make a difference. Just make sure you tighten them right.
hacim105 is offline
Old 12-05-2002, 10:42 AM
Desno Iridium spark Plugs
Yes, NGK platinums are std equipment. ed
Old 12-05-2002, 10:46 AM
SuDZ's Avatar
You can pick them up at your local dealer.
SuDZ
SuDZ is offline
I'm not looking for huge HP gains...if they result in better driveability and last as long as the stock plugs, then I'd consider that a win. Will probably just stick with the recommended NGK's. I agree on the tightening...I always use a torque wrench for these occasions. ed
06-06-2017 02:01 PM
magiconthetire
10-26-2015 09:03 PM
Need help
23
10-02-2015 08:56 AM
dshinn
09-26-2015 08:07 PM
zmcneely13
09-26-2015 02:26 PM
Quick Reply: Denso Iridium Spark Plugs
