Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Timeslips Members Parts Guide Search Today's Posts Mark Forums Read ExperienceUsed CarsGarageVendor Directory
Search
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Search this Thread Display Modes
Old 11-11-2002, 05:49 PM   #1
Points: 13,624, Level: 75
Points: 13,624, Level: 75 Points: 13,624, Level: 75 Points: 13,624, Level: 75
Activity: 0%
Activity: 0% Activity: 0% Activity: 0%
How to remove stuck spark plugs?
I was helping my friend change his spark plugs on his 97 Max. We did five cylinders with no problems, but when we were removing the coil pack from cylinder No. 5, there was a missing piece from the coil pack. A rubber boot that didn't come off when we pulled the coil pack out. When have tried several things to get the boot off, but nothing has worked. We can't get a socket in the hole to remove the spark plug. What can we do to remove the spark plug? Do we have to remove the cylinder head?
Thanks!
1FSTMAX is offline   Reply With Quote
Old 11-11-2002, 06:01 PM   #2
Sin
Send a message via ICQ to Sin Send a message via Yahoo to Sin
Re: How to remove stuck spark plugs?
Quote:
Thanks!
Do a search. The solution involves either using long needle nose pliers, or using a stick with some superglue on it.
Sin is offline   Reply With Quote
Old 11-11-2002, 06:04 PM   #3
Activity: 0%
Re: Re: How to remove stuck spark plugs?
Quote:
I tried that. That rubber o ring is really attached to the spark plug. I'll try to take a pic and post it up.
Old 11-11-2002, 06:09 PM   #4
Sin
Re: Re: Re: How to remove stuck spark plugs?
Try a larger socket, and try to twist out the spark plug by grabbing the rubber boot.
Old 11-11-2002, 06:33 PM   #5
Send a message via AIM to D1NOnly34 Send a message via Yahoo to D1NOnly34
Thanks!
I had this problem literally like 2 days ago. The end rubber socket of the coil pack stayed in the spark plug shaft. What I did was put super glue on the coil pack and jammed it in the hole again. I waited like a day cause I forgot, but it was good cause the glue had dried completely. When I remembered about it, I took out the plug, and there it was connected again. It was a bad coil pack anyways so I changed it for a newer one. If I were you I'd go and check that coil pack to see if ti still works, hope this helps.
__________________
VQpower.com
95 SE 18" Giovanna Corsicas|Eibachs|Tokico Blues|8000k Hanabis|Hybrid Intake|Redded out Tails|Pioneer-Rockford System|7" Microvision TV|PS2|Custom Trunk|99 Headlights|Blue LEDs|Wood Dash
D1NOnly34 is offline   Reply With Quote
Old 11-11-2002, 09:54 PM   #6
Activity: 0%
Worked like a charm. Thanks a bunch!
MaximaOrg
Nissan Maxima
Paid Advertisement
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
Emails Backup
Search Engine Optimization by vBSEO 3.5.2
