ECTS temperature range??
I was thinking of changing the coolant temeperature sensor. I checked
the Hayne's manual which says that a good ECTS should have following
readings:
Engine coolant temperature 68F, ECTS resistance 2.1 - 2.9 Kohms
Engine coolant temperature 194F, ECTS resistance 0.24 - 0.26 Kohms
I bought a new ECTS from courtsey nissan and found the readings
are quite different. I am getting,
Engine coolant temperature 68F, ECTS resistance 9.5 Kohms
Engine coolant temperature 194F, ECTS resistance 4.4 Kohms
Does it mean that newly bought ECTS is bad? Also, I am getting the
similar readings from my old ECTS and thats the reason I bought
the new one to replace it.
readings:
My Haynes manual says the same thing. What year is your car? Is it a Cali Spec? I wonder if some changes were made to the Cali Spec cars which include some sensor changes. The 99 Cali Spec Maxima shares some parts with the 5th gen Max's. That sensor may be one of them.
Originally posted by rsemwal
No my car is not cali spec. I am from Texas.
Do you mean to say that the readings I am getting, belong to ECTS
of 5th gen. maxima.
Can I replace my 1993 maxima SOHC ECTS with this one?
of 5th gen. maxima.
And I don't think your 93 would use the same sensor as the 95-99 years. Then again......
doctorpullit
10-28-2019 10:58 PM
RWCreative
09-21-2015 11:01 AM
