problems starting up
Old 09-26-2002, 07:23 PM
crazedMAX's Avatar
ok i have a 98 max and my car has problems starting. but when the car is running everything seems to be normal. i have a stereo with cap can my battery be drained after a year? also does anyone know what i can do about my windows going down so slow and off track it keeps rubbing up on the rubber.
crazedMAX is offline
Old 09-26-2002, 08:36 PM
Kashoggio's Avatar
Re: problems starting up
alittle more info about your cars problme would help. like when is it doing this.. how does it sound. Does the car have dim lights when you first get in to it... stuff like that. As for the windows, spray some silicone lube on the rails and it should help them out a bit
Kashoggio is offline
Old 09-27-2002, 08:07 AM
crazedMAX's Avatar
Re: Re: problems starting up
it doesnt have any dim lights it sounds like its having a hard time cranking up but after about 5 secs it kicks in
Old 09-27-2002, 08:14 AM
njmaxseltd's Avatar
Re: Re: Re: problems starting up
Your starter is telling you it's had enough. Retire it before it gets ****ed at you and walks out on the job, leaving you stranded.
njmaxseltd is offline
Old 09-27-2002, 01:02 PM
Kashoggio's Avatar
test your battery first, dont go changing the starter right away. If the starter is actually starting the car then its mostly ok unless it has dead spots (thats why people tell you to hit it hard with a hammer) Change your bettery first. A starter from Nissan can cost you 200 dollars
Old 09-27-2002, 02:12 PM
mike_rose's Avatar
if you have a voltmeter you can measure voltage at your battery posts when you are cranking you should have at least 9.6 volts. if you have any less you will need to replace your battery. dont hit the starter with a hammer, you used to be able to do that in the 70's but you cant do that with todays starters. they are too fragile
mike_rose is offline
Old 09-27-2002, 11:30 PM
vicodin ... gift of life
nadir_s's Avatar
I have the original starter on my 96... so far 140k miles w/ it. It's startin to give up, takes about 3-5 seconds to startup in the mornings sometimes. I checked my battery... produces 12.96V so that's fine... i'm thinking of upgrading the ground wire for the starter as well as replacing the starter wire (if it's easy to access) to a thicker gauge in hopes of provide better conductivity and start faster... or i'll just end up buying one for less than $100 and installing it myself. This car has treated me well w/ the starter... haven't replaced it yet! unlike my celica... had to change it 4 times, but then found it the wires weren't thick enough lol.
nadir_s is offline
Old 09-28-2002, 12:28 AM
crazedMAX's Avatar
ok thank you everyone im going to run to the auto store tomorrow and check if its my battery
matts95max
09-09-2023 01:52 AM
sctludwig
09-01-2022 01:32 PM
mvm062
11-30-2020 09:00 AM
trungg86
09-04-2015 04:58 AM
dcardello
09-03-2015 11:44 PM
Quick Reply: problems starting up
