When I apply the brakes the car shakes...
what's up with that? Since I have done a front brake job (didn't do anything to the rotors), the car shakes when I apply the brakes. This shaking / rattling is increased as the speed increases. Do I need to turn the rotors?
Thanks,
M.
Maxima GLE 95
115K
Stillen Intake (insalled last night)
strut bar
clear corners / Grille
Thanks,
M.
Maxima GLE 95
115K
strut bar
Originally posted by 95Max
Was the car shakeing before? Yes=rotors. No=maybe/maybe not rotors. Did you bed the pads correctly? Over torque/unevenly torque bolts thus warping rotors
Mohmd.
Originally posted by myamin
Hi -
I should have asked, what does turning the rotor entail? Can this be at home with basic tools, or should I take it to a mechanic?
Hi -
Turning the rotor involves using a lathe-type machine to rotate the rotor as a cutting bit shaves off the high spots on the rotor. This can only be done a couple of times before the rotor reaches its minimum specified thickness. These days this is done with the rotor still on the car.
I can't remember how much it cost me to have mine turned last time (it was years ago) but for the cost of new rotors, I just replace them and try to drive easier (for a while).
Originally posted by MdMaxDrvr
I have never had luck with getting my rotors turned. Since you are shaving down the rotor to get it even, you loose more metal, making it thinner than before, thus easier (in my book) to warp again.
Before you get new rotors or turned take a fine sandpaper and sand the surface. When you brake pad material is deposited on the rotor. If you do not bed the pads or rotors correctly you can get spots that have more pad material than other areas causing a warped rotor feel.
Lakersallday24
06-16-2019 01:35 AM
MaximaDrvr
08-19-2015 08:20 PM
RealityCheck
08-05-2015 06:18 AM
