Thicker head gasket to increase compression??
Old 09-12-2002, 08:24 PM
MAXINXS's Avatar
I have wondered this for awhile and finally decided to ask. I have read in import magazines many times that thicker head gaskets are used to increase the compression of the engine, which then sometimes increases horsepower. I'm not sure if this would benefit more for cars with boost or n/a. Would this work for the Max?
MAXINXS is offline
Old 09-12-2002, 08:32 PM
Minister of Silly Walks
mzmtg's Avatar
A thicker head gasket decreases the static compression of an engine.
This will lose HP on an NA engine.
mzmtg is offline
Old 09-12-2002, 08:55 PM
Sin
Sin's Avatar
I was thinking the same thing
I thought I misread him, and I thought about how increasing the compression ratio that way would not be a good idea on pump gas or on stock internals. With all the risks, and the fact that gains may not be had without much more work, I was just going to advise against.
Sin is offline
Old 09-12-2002, 09:01 PM
Keven97SE
Re: Thicker head gasket to increase compression??
Boosted cars can gain lots of HP with a thicker head gasket because the drop in compression allows them to turn up the boost more...and in the end, the HP they lose from the compression drop is well exceeded by the HP gain from the increased boost. They wouldn't be able to run that much boost normally because the engine would detonate.
Normally aspirated engines require an increase in compression to make more power. They don't have a compressor to shove in more air, so the more bang they get from the cylinders squeezing the mixture, the better...more bang comes from more compression.
aw11power
10-10-2021 04:57 AM
knight_yyz
11-01-2015 01:34 PM
maxinout93
10-31-2015 02:04 AM
jaydot901
09-29-2015 01:18 PM
Quick Reply: Thicker head gasket to increase compression??
