car door got hit by another in a parking lot. How can I get the paint mark off?
Old 08-29-2002, 06:25 PM
Sorgasm's Avatar
Some dumbass hit my drivers side door today with their car door and it left a little mark of paint on my car. What's the best way to try to get this off myself?
Sorgasm is offline
Old 08-29-2002, 06:27 PM
maximamoose's Avatar
Re: car door got hit by another in a parking lot. How can I get the paint mark off?
you could try to wax it off, or polish, or wash even.
maximamoose is offline
Old 08-29-2002, 08:48 PM
White96MaxSE's Avatar
You may want to try Meguier's Paint Cleaner to see if that will take it off by applying it to a soft terry cloth towel.
White96MaxSE
White96MaxSE is offline
Old 08-29-2002, 09:04 PM
ereet's Avatar
Clay Bar? I got a lot of paint off my door with that on the last boo-boo the car had.
ereet is offline
Old 08-29-2002, 09:07 PM
Flanman007's Avatar
Body Scrub (meguires?) I hear that works good
Flanman007 is offline
Old 08-29-2002, 09:16 PM
SamMan23's Avatar
That is quite a shine on your sig flanman. It really looks great. But all these guys are right. Meguiar's Body Scrub is the same as the paint cleaner, just slightly stronger. The clay bar is probably the most effective but they'll all work. I've used both meguiar's paint cleaners, and they are pretty similar.
SamMan23 is offline
Old 08-29-2002, 09:33 PM
way2fast95's Avatar
I used this stuff called "Goof off", www.goof-off.com to get paint marks off mine, As long as the clearcoat is not damaged in anyway, then it will work. If the clearcoat is damaged at all then it will desolve the paint, SO MAKE SURE IT IS OK BEFORE USING. use 2 cloths, one dry, and one soaked with water, use the Goof-off on the dry cloth and wipe the paint-marks off, then use the water-soaked cloth to clean any excess "Goof-off" off.
Worked awesome on my car.
way2fast95 is offline
Old 08-29-2002, 09:48 PM
I couldn't fix your brakes, so I made your horn louder
turbomax97's Avatar
Even if the clearcoat isn't damaged, this product will strip whatever clearcoat you have left on, and if your not extremely careful, will strip your paint as well. I wouldnt recommend this product, I used it to take spray paint off the carpet.
turbomax97 is offline
Old 08-29-2002, 09:53 PM
way2fast95's Avatar
Worked fine for me, but yeah this stuff is strong, if you use it you have to be very careful.
Old 08-29-2002, 11:28 PM
Nismo's Avatar
that happened to me once and they left about 2 feet of black bumper on the rear door. I used water and a blunt piece of wet wood to carefully rub it out. kinda hard to explain but its like how a clay bar works
Nismo is offline
Old 08-29-2002, 11:42 PM
Flanman007's Avatar
Thanks, Turtle Wax Polish (the kind that is different for different colored cars), then a regular wax, then meguire's 26 yellow wax/glaze worked great on my black beauty.
Old 08-30-2002, 04:33 PM
99maxi's Avatar
i used a little bit of alcohol on a q-tip.. and then put some wax back on it..
99maxi is offline
Old 09-01-2002, 03:20 AM
$tillen$ux's Avatar
Happened to me once. If its not too bad, b/c i dont know how big it is.. get some soapy water and put it on the scuff area. then with your thumb fingernail, scratch at an low angle (45 deg) with pressure and persistently being careful not to put the fingernail at 90 degrees (seriously! not kidding) to the surface. sounds stupid, but worked for me.
$tillen$ux is offline
Old 09-01-2002, 03:37 AM
TurDz's Avatar
If you can afford it at ~$18 a piece, find a Meguiar's Professional Products dealer (use their website to locate stores in your area) and buy Meguiar's Unigrit Sanding Block. Get the 2000 grit one. It's been one of the best 20 bux I've spent in a long time...
TurDz is offline
Old 09-01-2002, 08:32 AM
FameMax's Avatar
Laquor Thinner or Paint Thinner will work and b4 people start to bash this idea I detail cars, we use that stuff when paint gets on cars. Just wax if after and dont rub in to hard so u dont wreck the clear coat.
FameMax is offline
Old 09-01-2002, 11:31 AM
Newman's Avatar
damn JMU students. no respect for Maximas.
someone bashed my windshield in in Ashby last friday. had to get a new one.
good luck with it
Newman is offline
Lakersallday24
06-16-2019 01:35 AM
SmokinMax02
18
09-11-2015 12:25 AM
MAXSE5SPD
08-23-2015 12:06 PM
FanaticMadMax
08-10-2015 08:55 PM
Quick Reply: car door got hit by another in a parking lot. How can I get the paint mark off?
