fuel ration to run 2.87 pulley on V2 s/c'r ???
I'm currently running a 6:1 vortech fmu for the 3.125 pulley on the V2 s/c kit. I was wondering, if I upgraded to the 2.87 pulley will I need to change anything.... BTW, The car is controlled by the Apexi S-AFC controller.
Re: fuel ration to run 2.87 pulley on V2 s/c'r ???
Run 370cc injectors and use the S-AFC to control them.
~12.5:1 AFR
Test and tune it on a dyno with a wide band O2 sensor to be sure you have it right.
My advice to you is an 8:1 FMU disc, it will be rich but you can lean it out with the AFC. This is the safest approach.
aminus21
09-12-2015 04:53 PM
ballerchris510
09-10-2015 09:35 PM
