GA Block-off plate for 5th Gen IACV
For sale: Designed a block-off plate for the 5th Gen IACV for my 00VI swap. I had some extras made. I designed it with a hose fitting which allows an easy spot to plumb in the IACV adapter plate which I have available as well. Machined from 6061 aluminum. Will come with the necessary hardware to mount to the throttle body.
$44.99 shipped ConUS.
Why block off?? Why not just use the 5th gen tb and iacv?? Just curious as ill be doing an 00vi swap soon... jist bought entire setup...i got a 99 and from what ive seen i can use the iacv...if the info is wrong maybe ill buy this plate and adapter lol
Some people don't have good luck with the 5th gen iacv. Just reuse your current iacv a 99 w/3.5 swap here reused his stock iacv in a pftb.
Yea but my 00vi comes with iacv...might as well try it as im not 100% that mine is functioning properly...ill knkw more once i pull my mevi nd install usim with iacv alreaxy on it... besides i dont expect to cut corners or do it a certain way...im keeping swirl valves and all....
Can the 5th gen IACV be used? Yes, but some folks have cold start issues running the 5th gen IACV with the 4th gen ECU. Some would say the 5th gen IACV is iffy at best. Thats why they choose to run the 4th gen IACV instead.
Sorry, been out of town with the holiday. Not sure if it would fit a pathfinder TB or not. I have a buddy that has one that I will be getting a hold of soon so I can finish designing a pathfinder TB adapter to run on a 3.5 swap, along with an adapter for the 00VI swap.
If anyone is curious about his work, don't be. I've bought both of the adaptor plates he has made and they work flawlessly. We have 2 maximas, 2 that are running 00vi set ups and running fine without the cold start.
Also the machining work he does is really detailed and exact fit.
Bump for a good item and seller.
