1998 black maxima manual part out
got rid of the car these are the parts i got left
u could email me at samarooai@aim.com for any questions
i have manual transmission
engine the engine has arp head studs and cometic head gaskets 400
turbo kit 1500
black housing headlights 100
ACT Clutch Kit - Heavy Duty Pressure Plate, 6 Pad Sprung Race Disc Item# NM1-HDG6 350
map ecu2 500
upgraded injector
3 gauge pod 50
3 inch exhaust with magnaflow exhaust and greedy tip 300
shifter trim 30
center vent piece 30
looking for 1500 for turbo kit without intercooler and blowoffvalve
turbo kit 1500
map ecu2 500
upgraded injector
3 gauge pod 50
shifter trim 30
how much for the coil packs and can u email me pics of the gauges with the gauge pod at wooda.k3v1n@gmail.com
How much for all of the EVAP sensors and box(s) shipped to 12158?
I'm referring to everything by the rear left wheel (the box, sensors, etc.) and other stuff in the engine bay. Basically what's listed in this picture:
So...
PM me and we can discuss. Thanks.
So...
- Fuel Cap
- EVAP Canister Purge Volume Control Solenoid Valve
- EVAP Canister Vent Control Valve
- EVAP Canister
- EVAP Control System Pressure Sensor
- EVAP Canister Purge Control Valve
- Absolute Pressure Sensor
- Tank Fuel Temperature Sensor
- MAP/BARO Switch Solenoid Valve
- Water Separator
- EVAP Vapor Cut Valve
I need the stock air intake. Everything except for the MAF and the small resonator box on the bottom part...so pretty much the tube from the TB, the box after the MAF, the airbox itself and the scoop. Shipped to 93010.
Email me at egxflash@gmail.com if you still got it pls. Thanks
