FS: 00VI stuff
Old 10-24-2007, 07:27 AM
3.5 in the works
DandyMax's Avatar
FS: 00VI stuff
SOLD. Thanks for looking.
I have some 00VI stuff for sale. For those who are going to ask, NO this is not a complete kit, however it is most of the main pieces.
I have for sale:
-DEK upper manifold
-DEK lower manifold
-DEK fuel rail with injectors and FPR
-DEK throttle body
-DEK IACV
-all Nissan bolts and rear brackets for the UM
Pics:
Thanks for looking.
Edit: I forgot to mention that one nipple on the side of the TB area is broken (but it was evident in the picture). This isn't a big deal though, as most people cut that off anyways and install a brass fitting for EVAP, or vacuum etc.
DandyMax is offline
Old 10-24-2007, 12:33 PM
black_maxed95's Avatar
does the LIM have the swirl valves?
black_maxed95 is offline
Old 10-24-2007, 02:04 PM
maxboy325's Avatar
great pics you got a pm
maxboy325 is offline
Old 10-24-2007, 06:50 PM
3.5 in the works
DandyMax's Avatar
Yes, keep them or remove them, up to you.
DandyMax is offline
Old 10-26-2007, 10:34 AM
3.5 in the works
DandyMax's Avatar
achooo
DandyMax is offline
Old 10-28-2007, 03:22 PM
3.5 in the works
DandyMax's Avatar
bump bump
DandyMax is offline
Old 10-30-2007, 06:43 AM
3.5 in the works
DandyMax's Avatar
back to page 1
DandyMax is offline
Old 10-30-2007, 08:46 AM
The Jackal's Avatar
I'm very new to the concept of an 00VI swap, but what else would I need to complete the swap?
The Jackal is offline
Old 10-31-2007, 03:09 AM
kzoosho's Avatar
Im with hiim dandy . what else would i need to make this work as far as parts and also what gains do you think i would get since i am boosted.
kzoosho is offline
Old 10-31-2007, 12:58 PM
3.5 in the works
DandyMax's Avatar
You shouldn't need a whole lot more parts. With any 00VI swap you'll need some misc hoses and clamps (generic parts store stuff, just to re-route stock vacuum/air lines etc) but besides that, you'll need:
-the 5th gen EGR guide tube (get from Nissan for <$40 IIRC) if you're keeping the EGR, otherwise just block off the upper manifold
-fuel rail off-fitting or 5th gen damper for the front of the rail (either one works)
-electrical connectors for injectors & VIAS
-some kind of RPM switch to activate the VIAS (if you already have a tuning unit like a VAFC, EB, or EU they can serve that purpose too)
An extra option would also be the 5th gen rear valve cover and ignition coils, but this isn't necessary if you're trying to save money. When I did my swap initially I just ground down the 4th gen coils/bosses a bit and connected an elbow for the PCV and it worked/fit just fine.
For more info on the swap check the All-Motor stickies, Tatanko's website and Ceasar's big "for dummies" thread (in the stickies IIRC).
As for power gains, on an N/A car the USIM chokes past 5000-5500. The 00VI makes power all the way to redline and past. At 6500 you'll have 30-40 more whp easily, and if you extend the rev limit it only gets better. Even boosted it's a similar power curve adjustment. The car will be a lot faster with more area under the curve up top, will do better on higher speed pulls, or in the 1/4 mile etc, especially with an extended rev limiter to 7000 or 7200 to complement the manifold.
Do some searching in the dyno forum, and in the stickies in the All-Motor forum, there's some links there too IIRC.
DandyMax is offline
Old 11-01-2007, 02:45 PM
VQrebuild96's Avatar
If i only had the money... how come you are selling??
VQrebuild96 is offline
Old 11-01-2007, 05:31 PM
3.5 in the works
DandyMax's Avatar
It's a spare set off my new DEK with 50k on it. I don't need 2 swaps now..
DandyMax is offline
Old 11-04-2007, 01:21 PM
GreenVQ30's Avatar
hey got a question how much would u charge to install it??
GreenVQ30 is offline
Old 11-05-2007, 06:40 AM
3.5 in the works
DandyMax's Avatar
I'll PM you..
DandyMax is offline
Old 11-05-2007, 06:42 AM
3.5 in the works
DandyMax's Avatar
C'mon people, price is negiotiable, I need to get rid of these parts. This is a heck of a mod for a 4th gen with USIM, or upgrade from a MEVI...
DandyMax is offline
Old 11-05-2007, 03:36 PM
Bad time of the year for me... if i still had my job i would take it off your hands right now... Somebody will buy it eventually.
Old 11-05-2007, 06:57 PM
maxpeed96plat.'s Avatar
12 runner, you wouldn't happen to have a VAFC II for sale would you?
maxpeed96plat. is offline
Old 11-08-2007, 09:25 AM
3.5 in the works
DandyMax's Avatar
If that question is to me, no sorry no VAFC...
Anyone want this? Make me an offer, I'm flexible.
DandyMax is offline
Old 11-09-2007, 12:06 AM
Yes the question was for u, thanks for the reply.
Old 11-09-2007, 12:23 AM
supermanrox305's Avatar
If you have it in 2 weeks i may pm you about it.
supermanrox305 is offline
Old 11-09-2007, 01:19 AM
SLOW
Nealoc187's Avatar
this is one of the key parts that made the fastest all motor 4th gen what it is, someone should pick this up.
Nealoc187 is offline
Old 11-12-2007, 10:25 AM
3.5 in the works
DandyMax's Avatar
Monday afternoon blues... er, bump.
DandyMax is offline
Old 11-16-2007, 11:08 AM
3.5 in the works
DandyMax's Avatar
Bumpitupagain.
There's gotta be someone left who still wants an 00VI swap...
DandyMax is offline
Old 11-17-2007, 05:41 PM
nycmaximas member
BORQUA79's Avatar
Bump
because I'd love to have it but I need to read up more about it first...
I will regret it...
BORQUA79 is offline
Old 11-20-2007, 12:41 PM
Curt's Avatar
For any of you guys contemplating doing the 00VI but are scared off by the posts you read (all too often) by guys who are having problems, I can promise you that 99% of those problems are because they (1) didn't prepare and study the numerous threads about how to do it; (2) didn't understand what and/or why the different things involved; (3) decided that they were going to cut some corners (like leaving out the EVAP, EGR, IACV, etc.); or (4) were just too sloppy in keeping track of everything and forgot how to reconnect things (or just overlooked hooking some things up).
This is not a simple, Saturday-and-a-six-pack type of project. But there are lots and lots of guys who were thorough in their preparations and didn't fall into any of the above catagories, and will tell you that is one super enhancement to the 4th gen Maxima. I have the 7200 RPM JWT ECU with mine and have power and torque hands down over the stock USIM or MEVI throughout the RPM spectrum.
Oh, and let me just add, a few years ago when contemplating the 00VI mod, if I had read all the threads you're seeing these days of guys who've mutilated this installation, I'd have probably been scared off too. But face it, some guys just aren't cut out for doing mechanical stuff beyond changing their oil!
Curt is offline
Old 11-23-2007, 08:00 AM
3.5 in the works
DandyMax's Avatar
Friday bump.
DandyMax is offline
Old 11-26-2007, 05:59 AM
RedfoxXx's Avatar
wow . . . not looking froward to selling my VI swap in a month, this thread went no were free bump tho good luck!
RedfoxXx is offline
Old 11-26-2007, 09:10 AM
3.5 in the works
DandyMax's Avatar
Yeah it's pretty sad. I figured there'd still be some demand. I'm gonna bump it till it sells though.. hah
DandyMax is offline
Old 11-29-2007, 11:22 PM
ur getting sleeepy.........ur getting sleeeeeeeepy........you need an 00vi......u neeeed an 00viiii......bump....wake up!!
Old 11-29-2007, 11:45 PM
im very interested in doing a 00vi soon. i have been doing lots of reading and researching....however unfortunately do to $$$ its only a dream right now. Im hoping after Christmas ill have some extra money. (unless you want to do, say $200 shipped )
Old 12-02-2007, 02:36 PM
3.5 in the works
DandyMax's Avatar
Price updated, see the first post.
DandyMax is offline
Old 12-06-2007, 01:28 AM
Old Maxima Legend
Ceasars Chariot's Avatar
there must be heaps of new 4th gen owners or something aye ? i did the 00VI swap, see sig ? I dare you to find someone more honest and trustworthy than dandymax? no worries there.
if you are looking for a serious performance mod then this is the ticket. there are several writeups and the all motor guys here on the forums are fantastic. nothing to worry about, the 00VI swap was scary for me but I started a thread and the maxima crew here stood with me every step of the way. its really not that bad at all.
good luck with the sale dan. if i had it to do all over again, it would be a no brainer, 00VI kills the poor USIM !
bump for probably the best bang for the buck performance mod in the 4th gen classifieds
Ceasars Chariot is offline
Old 12-06-2007, 03:56 PM
Would you sell me just the upper manifold and tb ?
Old 12-06-2007, 04:43 PM
3.5 in the works
DandyMax's Avatar
Maybe, but I want to give it a little bit longer as a package, there have been several people interested and close to buying it. Ask me again in a couple weeks...
DandyMax is offline
Old 12-07-2007, 07:10 AM
RedfoxXx's Avatar
I need a 00VI LIM if you do want to brake them up, and some of the bolts that hold the UIM to LIM
RedfoxXx is offline
Old 12-08-2007, 06:58 AM
osixMAX3.5se's Avatar
I live in the Philly PA area. If I got this for my 95 would some one who knows what there doing help me install it?
osixMAX3.5se is offline
Old 12-08-2007, 09:10 AM
maximabebe's Avatar
Dandy, I'll buy it. Where do I send payment to? PM me.
maximabebe is offline
Old 12-08-2007, 04:17 PM
3.5 in the works
DandyMax's Avatar
PM sent.
DandyMax is offline
Old 12-08-2007, 07:55 PM
figs. when your interested you get bumped haha. it's all good tho. enjoy it!
Old 12-10-2007, 09:14 AM
3.5 in the works
DandyMax's Avatar
Sale pending, if it falls through there's maximabebe and then you're 3rd on the list...
DandyMax is offline
Quick Reply: FS: 00VI stuff
