Go Back   Maxima Forums > Classifieds > Parts For Sale/Wanted > 4th Generation Classifieds (1995-1999)
Thread Tools Display Modes
Old 09-04-2007, 10:40 PM   #1
........................Consult Blazt ECU interface w/datascan..serial and usb
Would you like to see what the exact water temperature is instead of a needle pointing between "C" and "H"? Want to see the injector duty cycle at varying RPM's and graph it all? How about the ability to see if that ticking noise is the lifters or the VVT springs? This cable lets you see all the data that the ecu (car computer) sees and does many diagnostic tests as well!
This is an affordable, highly developed serial or usb ECU Interface Cable for your Nissan's Consult port. Blazt is not an ebay "exposed circuit board" with serial connectors only and no registered programs to actually use the cable! It comes with the latest Nissan DataScan software (lifetime registration with support), which lets you see real time ECU(engine computer) data displayed on your computer.
The new version of datascan has basic datalogging so the price is $159 shipped in the us for USB+datascan software, $132 shipped in the US for serial cables + datascan software, paypal fees included. I will also price match any other brand name consult cable. I am an official distributor and you will get your cable in a few days!
It can be used for a wide range of problem solving as well as monitoring engine sensors, datalogging, performance, and upgrades. This is a commercial grade, high quality product, not the home hobbyists, made in the garage version. There is no box along the cable, for added reliability and a clean look, all the electronics are built into the plugs. The time it will save you when working on your car is well worth it and is cheaper than taking it once to a dealer. Compare to other ecu interfaces, blazt is a great value.
Some of the functions include 0-60 speed trials, setting the TPS "the easy way", doing a power balance test the easy way, changing engine temp, shutting off the fuel pump, aac valve manipulation, A/F mixture adjustment, ecu fault code read/clear, ecu self learn clear, active tests such as the power balance test, ignition timing change, injector cycles, datalogging, and more. Tested cars other than the z32 are: 240sx/silvia, 93 Altima (KA24DE), A32 Maxima, 94 Sentra B13 (GA16DE), 93-97 INFINITI J30 (VG30DE), 91-97 INFINITI Q45 (VH45DE), Sentra B13 SE-R(SR20DE), other nissans may work, inquire for further details.
For more information, feel free to contact me at: whats x the x good x word x at x hotmail x dot x com . Please note that this is anti spam: remove the spaces, and all x's to make sure I get the mail and can answer any questions, thanks
whatsthegoodwor is offline   Reply With Quote
Old 09-05-2007, 08:14 AM   #2
The Original CF Maxima
Flava_24/7's Avatar
So this device not only allows you to monitor the various conditions but also allows you to tweak certain parameters? ie: AFR/ & timing?
Also, if the settings can be changed are they permanetly set?
Flava_24/7 is offline   Reply With Quote
Old 09-05-2007, 08:40 AM   #3
Certified Hooptie
NmexMAX's Avatar
Send a message via AIM to NmexMAX Send a message via MSN to NmexMAX Send a message via Yahoo to NmexMAX
Quote:
A32’s do not have VVT.
If this is the A32 Cipher equivalent, that’s a good price. But we shall remember the A32 ECU isn’t as fast as some of us would like. With that said, what is the data feed rate?
A/F mixture adjustment, …………..ignition timing change…
Explain this in detail.
I’m sure most if not all of us would like this discussion to take place right here vs private email.
__________________
03 SE 4AT 242whp/238wtq
95 SE 4AT 235k Miles
NmexMAX is offline   Reply With Quote
Old 09-05-2007, 09:09 AM   #4
00VI Guy
Tatanko's Avatar
Send a message via AIM to Tatanko
I am interested in this as well, pending it can actually make changes to timing and details like Nmex asked. If it can change timing, great, but is it permanent? i.e. if we disconnect the software, shut off the car, and turn it back on will the settings be retained or will the software need to be run every time the car is started?
__________________
SHIFT_obsession
Tatanko's Maxima Site & VQ35DE.com
Tatanko is offline   Reply With Quote
Old 09-05-2007, 09:23 AM   #5
00VI Guy
Tatanko's Avatar
From what I've done searches on, this guy posts this same crap on every Nissan forum. If you look at those forums and the website (blazt.biz), it appears to be OBDI software for the most part. Although it goes through the Consult port rather than the OBD port, I get the impression that settings can't be retained and that it's more for you to hook up a laptop or something and do datalogging that way, rather than tune and retain settings.
Let's see if he actually responds here, but I doubt it. We will likely have to email to get answers.
__________________
SHIFT_obsession
Old 09-05-2007, 09:36 AM   #6
Flava_24/7's Avatar
I found some more info about it, and its kind of vague about the adjustment features. This is what it states:
Quote:
Adjust base settings while driving: GRundeinstellungen während der Fahrt:
* timing
* change engine temp
* AAC valve
* IACV valve
* air/fuel mixture
* turn variable cam timing on/off
* turn fuel pump on/off
* turn cylinder spark on/off * Zündzeitpunkt
* Motortemperatur
* AAC Ventil
* IACV Ventil
* Luft/Benzin Gemisch
* Variable Ventilzeiten Ein/Aus
* Benzinpumpe Ein/Aus
* Zündung einzelner Zylinder Ein/Aus
The while driving part leads me to belive the settings are NOT permanent. Its a cool device to do data logging but without the ability to tune is a waste to me.
http://www.blazt.biz/products/datascan.php
__________________
Old 09-05-2007, 09:47 AM   #7
00VI Guy
Tatanko's Avatar
Quote:
I'm emailing him right now.
__________________
SHIFT_obsession
Old 09-05-2007, 09:52 AM   #8
ewuzh's Avatar
Send a message via AIM to ewuzh
I've had this for over a year now. Base A/F and timing adjustment was grayed out on mine. I think on their website it says it only works on the 300ZX. The other stuff works though (all the meters, O2 readings, temperature, RPM, datalogging, speed trials). I primarily used it for pulling/erasing CEL codes since OBDII readers cost $75+, might as well get one of these for a few bucks more.
It doesn't matter if you have OBDI or II. It plugs into the Nissan CONSULT diagnostic port. Any 90's era Nissan should have it under the driver side dash.
__________________
current: 2001.5 S4 Avant 6MT
sold: 1997 Maxima SE 5MT
ewuzh is offline   Reply With Quote
Old 09-05-2007, 09:54 AM   #9
00VI Guy
Tatanko's Avatar
Ugh. Great. So another worthless spam ad and disappointment for us.
__________________
SHIFT_obsession
Old 09-05-2007, 10:02 AM   #10
maximabebe's Avatar
For a second, this seemed like an inexpensive alternative to the Jim Wolf Technologies upgrade. Seems like a waste of time to me, unless the seller responds with some in-depth insight specified to the A32 OBDII system. We shall see.
__________________
maximabebe is offline   Reply With Quote
Old 09-05-2007, 12:32 PM   #11
Well I just posted the ad earlier today, give me a sec! I've sold one here, but I haven't been here in a while because someone called me to meet them to give a demonstration but never showed up. I am a regular member on the site www.twinturbo.net, if you sign up there to ask or search for my user name "whats the good word (one word), then you will see that many people have bought from me. The VTC on/off and fuel and timing map real time trace is mostly for the 300zx but other models can use it too. I don't think the real time map trace works on the maxima though.
Gauges have a peak hold function and can datalog and play it back later. I am not a maxima guy, but for people with 300zx's, many of them are on 99% or 100+ fuel injector duty cycle and don't even know it....*BOOM*. By datalogging a few runs on the street (drive safe ), you can see exactly what your engine is doing, and since the gauges move very fast, it has a peak hold function that lets you see any spikes. Here is a movie of the gauges in action, sorry for the jumpiness, it's from the capture software, not the gauges.
www.myturbodiesel.com/1000q/highway_.avi (right click and save would be easier)
It connects to the consult port. It will work on any car that uses the grey consult port. It will also work on the a32 maxima, even the obd2 models, as long as it has a grey consult port. If you have an infiniti q45 , j30, 240sx, 240sx with skyline or rb20 engine, it will work on any of these as long as you have a grey consult port under the dash.
Settings such as ignition advance, fuel lean or rich, will not stay once you unplug the cable. The advantage of this is that you can go to a dyno and see immediately without teaking under the hood, what a +1 timing advance will do for power. Once you are satisfied, go under the hood and change it manually. It is not a substitue for an AFC since it cannot tweak by RPM. This way, you can't mess up your car.
There are a lot of neat tricks you can do, such as a power balance test to isolate problems to a cylinder, seeing the tps voltage so that you don't have to get a multimeter and pins to stick in the wire to set the TPS, you can shut off the fuel pump to relieve any pressure if you need to change the fuel filter or lines, etc.. Like someone posted, it costs only a little more than a scanner but does a lot more.
9600 baud comms.
I am an official distributor for these cables and if you set up a group buy, I can give a group discount. Prices also include lifetime registration to datascan consult software and lifetime product support.
Old 09-05-2007, 01:16 PM   #12
Also, it can read the ecu rom data. If you have any use for reading the rom data, this can download it. Can't write it, but can read it.
More info, the fuel and timing map real time trace only works for the rb25, r32 rb26, sr20, rb20, and vg30.
A bonus feature of the serial cable is that it can work with a serial sync cable and connect to a compatible PDA. Here are some pics of engine gauges on a PDA. This way, you can see water temp instead of "c and H', fuel injector, engine rpm, etc.,
Mine also has mp3s on it and TomTom gps navigation loaded on the PDA. (pocket pc only, no palms, ask for a long list of compatible pdas)
Old 09-05-2007, 10:16 PM   #13
Certified Hooptie
NmexMAX's Avatar
Looking at the price, it's not bad for datalogging/reading peak hold/etc. IMO, worth it if you're a data head.
__________________
Old 09-09-2007, 10:10 AM   #14
Thanks. While it's not a full featured chip burner and AFC, it's still a good value and useful for many people.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
