well, today I replaced the lower ball joints on my 94 SE. Although the gods were not kind to me(it started to rain in the middle of doing the job) I got both of them done in about 3 hours. I'm going to take a little time to pass on some hints and also a little info about ball joint.
What are ball joints and why do they fail?
Ball joints connect the lower control arm to the spindle assembly. They allow for the movement of the tire when your car hits bumps, etc. They fail because either the boot that keeps the grease in gets torn and foriegn debris gets in there or in my case, the car takes so many bumps from the road that they just wear out. (again, I love chicago's roads
) There are a few ways to tell that they are going bad. Vibrations at higher speeds, a clunk noise when going over bumps(that can be worn struts too), or uneven tire wear too. There is a simple test to see if they are worn out. Jack the car up and pull the bottom of the tire towards you. It should not move at all or very little. if you get movement then it's time to replace.
I recommend replacing both at the same time. If one is worn then the other one is probably worn too. You have two choices. 1. take it to a shop and have it done. Around here that was about $280. 2. Do it yourself...The parts cost me $53 with tax.
Tools needed:
22mm open end wrench
17mm socket with a breaker bar.
needle nose plyers
Pickle fork
hammer
small screw driver.
How it:
1. Jack the car up and remove the tire and place the car on a jack stand.
2. take the small screwdriver and bend the cotter pin on the top spindle nut so that you can remove it. Pull it out with the needle nose pliers.
3. Spray all nuts with a penetrating oil to make your life easier. (this is a 10 year old car we are talking about here)
4. Loosen the top spindle nut but you can't remove it yet because the CV joint is in the way.
5. remove the lower 3 bolts that hold the ball joint to the lower control arm with the 17mm socket and breaker bar. They will be tight so give um a good tug.
6. Now, place the pickle fork into the joint and give it a good wack with the hammer until the ball joint seperates.
7. Remove the top nut completely and wiggle the old joint out.
8. Place the new joint into the hole and tighten the top nut as much as possible.
9. Now the fun part. Push the lower control arm down while lining up the three holes. (a helper would be handy at this point.) Thread one of the nuts and tighten till you can thread the other two.
10. tighten all of the nuts and insert the cotter pin on the top nut.
11. Put the tire back on......clean up the tools and take it for a test drive.
I hope this helps everyone.
Mike.
5. Remove the three lower nuts
