How many gallons does my fuel tank hold?
Old 11-23-2000, 08:21 PM
ryGuySE's Avatar
I have a 91SE
ryGuySE is offline
Old 11-23-2000, 08:27 PM
Jason F's Avatar
18.5 gallons.
I looked the other day after I was shocked to fill my tank with 16.7 gallons (the most I'd ever put in by far...until then, I had only seen 16.0 gallons a few times).
Jason F is offline
Old 11-23-2000, 09:26 PM
STFU n00b!
Matt93SE's Avatar
a month or so ago, I ran the sucker completely dry (as in stalled on the side of the road, had to push it to the pump)
it only took 17 gallons to fill, and that was after I splashed some out when I filled it completely up! ??!?!?!?!
Matt93SE is offline
Old 11-23-2000, 09:52 PM
Maxima Princess
Sarah99GXE's Avatar
so being that our cars are fuel injected, if you run it dry as you did, and you put gas in your car will it start right up? I mean I've always heard that is worse on fuel injected cars to run out of gas...I wouldn't know what it does as I always fill up at 1/4 tank. I drive so far going to & from work that I dont like to have any less going either way.
Sarah99GXE is offline
Old 11-23-2000, 10:05 PM
Eagles Fan 4 Lyfe
Chris91SE's Avatar
damn...my sh*t was below E the other day and it only took 14.1 gallons....does that mean the whole fuels system still holds 3 or so gallons...or my needle can be f-d up...
Chris91SE is offline
Old 11-23-2000, 10:10 PM
Maxima Princess
Sarah99GXE's Avatar
speaking of f*&^ed up needles..
mines crazy..I can fill up my car..then say 30 miles down the road my needle will read 3/4 of a tank then during the next 30 or so miles it will go back up to full and vice versa...at first this freaked me out & I thought I was leakin fuel as I was driving..but now it does it all the time...weird..
Old 11-23-2000, 10:13 PM
Eagles Fan 4 Lyfe
Chris91SE's Avatar
Re: speaking of f*&^ed up needles..
yeah in 40 miles mine gets to 3/4 tank....then it takes awhile to make to 1/2 and 1/4....i dunno what the deal is with that...
Old 11-23-2000, 10:39 PM
Maxima Princess
Sarah99GXE's Avatar
yeah same with mine...in 2 days I can get to almost 1/2 a tank then it takes the next 3-4 days to drop to 1/4..heh at least Im not the only one
Old 11-23-2000, 11:26 PM
Blu Max's Avatar
Whoa my gas needle seems to go slow before 1/2 tank, then it starts to go faster to 1/4 tank. btw how much gas mileage are you guys and girl gettin' i get around 350 to 400+ city/highway is that good or should i be needin a oxy sensor soon?
Blu Max is offline
Old 11-26-2000, 05:31 AM
Jaybird180's Avatar
I know for sure that I can get about 450 miles in one stretch.
Jaybird180 is offline
Old 11-26-2000, 08:57 AM
OG Maxima.org Member
nubiannupe's Avatar
Yeah, Jaybird.... I think that's about right. I just did a little over 400 from one end of the needle to the other. Sittin' there thinkin to myself, 'oh, I can make it'. Thank goodness I did!! Would not have wanted 2 be in your shoes, Matt, and have to push my car. Especially here in ND!!
nubiannupe is offline
Old 11-26-2000, 09:46 AM
93 SE's Avatar
ive heard that car companies do this purposely to make the driver feel good about his gas mileage...if your needle goes slowly to 1/2 a tank then drops quickly thats their doing...you shouldnt worry unless you notice your gas mileage per tank is below around 300-340 you should normally be higher than that
93 SE is offline
Old 11-26-2000, 10:29 AM
90maxSE's Avatar
what about me??
I am only gettin about 300 miles and then she takes about 15 to 16 gallons, I know it suckcs, but should it be better? I mean its cold up here I am in NY, so could that be a factor??
90maxSE is offline
Old 11-26-2000, 12:44 PM
93 SE's Avatar
hmmmn... i really dont know if this could be an answer...but since you live in upstate ny where your higher above sea level than most people your car gets less air to breathe cuz your so high..so i think the car works a little harder using more gas and probably intaking more air to compensate.. but thats just my theory ,sounds good though...just ask a maxima owner up there what mileage they get and compare...good luck
93 SE is offline
Old 11-26-2000, 06:07 PM
Brandon90gxe's Avatar
what the hell? im getting really crappy milage i think.. like 200 miles a take, but then thats judging from a quarter being at 50 miles, and then now im just about at half and the counter sais 95 miles on it. Is there something wrong with my car cause i know i should be getting much higher the 14 MPG!!
Brandon90gxe is offline
Old 11-26-2000, 06:27 PM
perlmax90
the gas millage does suck.
if i drive 60 miles i use about half tank of gas at about 65-70 mph. but at least you get alittle time before you run out of gas completly. my needle would be on E but i can still drive like another 30 miles before i'm completly empty. i think my guages might be F$%ked up.
Old 11-26-2000, 06:59 PM
Eagles Fan 4 Lyfe
Chris91SE's Avatar
Re: the gas millage does suck.
thats 120 miles per tank?!?!...you really need to do something about that...i've gotten 400 - 450 miles driving an avg of 65-70 on the whole tank...
Old 11-26-2000, 09:02 PM
93 SE's Avatar
how much$$$$$$ do you spend on gas at 120 a tank
93 SE is offline
Old 11-27-2000, 10:56 AM
perlmax90
it takes like $25-$30 to full my tank. and i have to full it about 21/2 times in one
week. dude i can't afford this
Old 11-27-2000, 03:22 PM
Eagles Fan 4 Lyfe
Chris91SE's Avatar
Re: it takes like $25-$30 to full my tank. and i have to full it about 21/2 times in one
that's not good...how long has it been since you changed your O2 sensor?
jmlee44
10-02-2022 02:13 PM
aw11power
10-10-2021 04:57 AM
06-06-2017 02:01 PM
Forge277
06-13-2016 09:26 PM
ef9
10-04-2015 08:43 AM
Quick Reply: How many gallons does my fuel tank hold?
