Boss said it's been long enough.
Old 09-11-2018, 04:36 PM
  #41
kcidmil's Avatar
Major ignition problems when at full operating temp (thinking the distributor or power module). Slight miss at idle, tons of power until it reaches a certain temp and then I lose power. I think one, possibly 2 cylinders cut out. It's still getting fuel as i can smell it.
Needs wheel bearings, and ball joints. The exhaust may be leaking at the rear header to collector pipe. I would still have to try and get it to pass emissions.
kcidmil is offline
Old 09-12-2018, 08:20 AM
  #42
Tarzan's Avatar
Usually when you have temp related problems, all temp sensors are suspects. Check if you are getting correct reading from the coolant temp sensor, maf etc.
Tarzan is offline
Old 09-12-2018, 09:19 AM
  #43
kcidmil's Avatar
That's the issue, at this age I could be looking at a lot of parts that are suspect, especially after sitting for so long. I do this stuff all day long as a job and honestly get burned out. If I can part her out to keep others going then i feel better than just letting her eventually get crushed.
kcidmil is offline
Old 09-12-2018, 02:19 PM
  #44
Tarzan's Avatar
I usually keep cars as long as I can DIY and when they become a burden, they are well above 10 year old, but I cannot imagine maintaining a 3d gen Maxima today. Your patience is commendable, and it's perfectly understandable that this is a time for a stop loss call. Espeacially for a pre-OBDII car.
Tarzan is offline
Old 09-14-2018, 07:36 PM
  #45
CMax03's Avatar
You're giving up too soon....IMO!
CMax03 is offline
Old 09-21-2018, 12:58 PM
  #46
kcidmil's Avatar
Well I'm not getting too much interest on the parts so I may put her on the back burner till next year. Just don't have the funds right now to throw parts at her, and not something I like doing.
kcidmil is offline
Old 09-21-2018, 10:54 PM
  #47
CMax03's Avatar
Make sure it's not the Idle air control valve, that sits above the EGR valve...You can take it apart and see if the thermostatic valve is still functional....If not search the boneyard or ebay! I noticed you reused old coolant hoses and that was cheap and easy to replace and not be a future problem! So if you reused the bypass hose what else did you reuse? If you have all that apart why not install new hoses, orings, seals, so there are less issues later on?
CMax03 is offline
Paxtonsdad_94
01-17-2019 04:10 AM
bprice92
10-01-2013 11:36 AM
Infowire
10-13-2011 03:18 PM
Kevlo911
08-07-2010 08:34 AM
C MAX
30
11-23-2009 07:03 PM
Quick Reply: Boss said it's been long enough.
