Power Windows
Old 12-29-2016, 09:47 PM
Starrider's Avatar
Power Windows
Hi Guys!
Power windows aren't working right. Sometime they work...other times they don't. Usually don't work when the weather is cold. Have tried the lock buttons control to make sure that isn't the issue...What is the fix? It's a 94GXE.
Thanks in advance!
Starrider is offline
Old 12-30-2016, 04:34 AM
Ray229Harris's Avatar
Could it be that the motor is on the way out? With my car; first it would go slow; then it would only go down. Eventually it stopped and didn't move at all.
Ray229Harris is offline
Old 12-30-2016, 09:30 AM
Ad·min·is·tra·tor
DanNY's Avatar
it's usually the master switch(es) at the driver's door that causes these weird problems.
DanNY is offline
Old 01-07-2017, 06:58 PM
That_93maxima's Avatar
Check fuses/relays a friend of mine at work was having a similar problem but it was the fuel pump it turned out to be a bad connection and when it got cold out it didnt work
That_93maxima is offline
