How do you drain coolant out the VE block?
Old 10-09-2016, 05:46 PM
Say Candyman 5 times
CandiMan's Avatar
Just changed the water pump, added a coolant flush additive with straight water, would like to drain the complete system before adding antifreeze.
I was thinking of jacking up the rear end, disconnect the lower radiator hose at the radiator and apply compress air in the bleeder screw port.
I know the remaining water in the block may not make a difference so remember the tile of this thread, LoL
CandiMan is offline
Old 10-10-2016, 12:06 PM
DennisMik's Avatar
There is a drain plug in each side of the block to drain the coolant. See page 7 for the locations.
http://boredmder.com/FSMs/Nissan/Maxima/1994/LC.pdf
DennisMik is offline
Old 10-10-2016, 12:18 PM
CandiMan's Avatar
Get the freak out of here. After 20yrs of ownership (and having my own FSM) I never realize there's a drain plug, LoL
What's funny, over the years I've probably put my eye on those drains plugs numerous times and never realized what they were.
Hopefully they are easily accessible, especially the RH side next to the axle
CandiMan is offline
Old 10-10-2016, 03:32 PM
2 VE's are better than one!
James92SE's Avatar
I've never actually used them but I assume this is a drain plug visible here in my block (below the crank side freeze plug). This is the firewall side:
And another on the front of the block (above the freeze plug on crank side):
James92SE is offline
Old 10-10-2016, 04:57 PM
CandiMan's Avatar
I'll see how easily accessible are those drain plugs when I get under there
CandiMan is offline
Old 10-24-2016, 11:58 AM
CandiMan's Avatar
FYI - Those drain plugs worked wonderfully. I was quite surprise to see how much coolant came out the left (radiator side) drain plug and this was after draining the radiator. The right plug, not as much as the left but enough.
Access to the plugs was easy. No special tool or having to be a contortionist. 14mm(9/16) socket, extension and rachet.
CandiMan is offline
MaximaNoob1
20
10-13-2016 02:53 PM
acamarillo
10-03-2016 03:02 AM
Greenman03
09-19-2016 06:34 AM
thankumuch
09-17-2016 12:44 PM
MAXIMARK
09-11-2016 03:03 PM
Quick Reply: How do you drain coolant out the VE block?
