Opps, wrong torque spec
Old 09-03-2016, 04:40 PM
kcidmil's Avatar
So after many years of putting it off, I finally got around to putting it all back together. A good side note for anyone trying this with the Chiltons, make sure you're reading the specs for the right motor. Off to the machine shop to make sure I didn't warp it.
kcidmil is offline
Old 09-22-2016, 08:58 AM
arsonist63086's Avatar
you won't warp the head if you over torque it . you will just break bolts lol. the worst case is once you install the engine and run it over time you will end up having to replace the head gasket since you basically got rid of its expansion/flex space by over tightening it.
arsonist63086 is offline
Old 09-22-2016, 04:33 PM
2 VE's are better than one!
James92SE's Avatar
Wow you must have put some serious torque into that head bolt to snap it. What's the VG intended spec and what did you actually torque it to?
James92SE is offline
Old 09-29-2016, 08:14 PM
kcidmil's Avatar
46 ft lbs for the VG, 90 ft lbs for the VE. VG torque sequence diagram is on the same page as the VE torque steps.
I got one bolt to the 90 ft lbs and was working on the second when it snapped. Luckily where I work we have a machinist and everything checked out fine.
kcidmil is offline
MADMAXA33
23
06-27-2017 09:34 AM
DuaLMaGz
09-01-2016 06:18 PM
jzack
08-26-2016 03:26 PM
pjgreek
08-17-2016 08:23 PM
Maxima 97 SE
22
08-10-2016 11:00 AM
Quick Reply: Opps, wrong torque spec
