I changed my Maxima injectors for another kind. (Chevrolet Astra)
Hello friends.
I made a reform to change my Maxima injectors 93 by "Chevrotet Astra" injectors.
The problem is that here in Argentina, it is very difficult to get Nissan injectors. They are very expensive, each Nissan injector cost about U $ S200, Chevrolet injector, which is a common car in Argentina, each cost U $ S45, and have the same flow characteristics and impedance than the Nissan.
The problem is that the fuel income is over the top and in the Nissan, as you know, is lateral.
For that reason I had to redo the fuel injectors ramp completely.
I attach some pictures.
Injector, Top Head and ramp
Injectors in the intake, and top head
ramp
Ramp with top head welded
Ramps finished
Injector in engine
Well, the engine works very well, both high speed and idle.
In terms of consumption, highway, 130 km / h (81 mi / h) is 9km / liter (21.17 miles / gallon) in city 8Km / liter (18.82 miles / gallon), considering this is a car that does not has oxygen sensor, (the cars arrived to Argentina in the years 92-94 do not brought) is an acceptable consumption.
I hope you understand my English and help if anyone wants to do the same reform
Regards
Augusto
ramp
Ramps finished
Injector in engine
Regards
Augusto
Nice job bro!..you may have solved alot of our problems with our problematic US injectors. Plus changing it over to a top feed system. Interested in what were all the materials to complete this. Great work!
That's some Manu Ginobili type ingenuity.. Nice work, I'm sure someone here would have given you a deal on some used injectors, or you could have ordered them online. Regardless, you saved some money and have brand new injectors. Nice job.
All materials are standar steel, ramps and top head.
I made the top head with a old screw, the interior diameter is 14 mm, std with the most injectors.
I used parts of the nissan original ramp, see picture.
I welded the joints of the ramp with the injector top head with bronze (I don't know if "bronze" is the correct term), maybe is better weld with TIG
Saludos
Augusto
Gracias Hectic
Yes, off course, I saw ebay publication with the nissan injectors, but the problem is that in this "argentian political moment", is very complicate to import spare part, worse if was used.
For that reason we have to sharpen our wits!
Saludos
Augusto
Very very cool! Love the creativity and determination to get this done. Reminds me a little bit of how Cubans basically have to invent and fabricate their own parts to keep their old cars going.
How rare is the 3rd gen in Argentina? Do you ever see any when you're out driving around or are you the only person you know of in your neighborhood who has one?
....Well, the engine works very well, both high speed and idle.
Regards
Augusto
Regards
Augusto
but nothing to measure the results and trim the fuel mapping from reading the exhaust.
The 3dr gen is very rare in Argentina, there are no many. My father bought one in 1992, zero miles, and I fell in love. Also, I have same spare parts from that car.
Saludos
Augusto
Excellent creativity with the injector modification. I find it interesting that you say that most cars come without the oxygen sensor. To me that says that your car is not running optimally. If you plugged in an O2 sensor, the car's power would go up and you would get better fuel economy. How else does the computer measure the air/fuel ratio? You have the MAF going in
I think he local dealers brought cheaper cars without sensor.
The car has MAF sensor but works in open loop.
I canīt put an O2 sensor because the ECM not have the right firmware, have an special firmware does not consider the sensor. I should change the ECU by a US ECU
Saludos
Augusto
I was thinking the same thing James had mentioned about how in Cuba they have to improvise using many different parts. Very impressive work ajvnissan! Way to use your wits and creativity. Nice work!
kjlouis
11-24-2018 06:09 AM
Finkle
09-27-2015 09:53 PM
Ray229Harris
09-16-2015 08:16 PM
RealityCheck
08-05-2015 06:18 AM
