ve turbo manifold
Old 07-02-2014, 07:43 PM
TonyJr's Avatar
ve turbo manifold
https://i.imgur.com/HN1FNDZ.jpg
I'm planning to use my warspeed ypipe to custom make a manifold this weekend. I have a spare ypipe so that why I'm planning to do this. Do you guys think this pic is a good way for a manifold? It's enough room for the down pipe to pass down next to the manifold what do you guys think?
TonyJr is offline
Old 07-02-2014, 09:19 PM
CMax03's Avatar
Not Bad!!! Kinda small for a turbo, secondaries wise...But should do the job....
CMax03 is offline
Old 07-04-2014, 06:28 AM
2 VE's are better than one!
James92SE's Avatar
Well that isn't really a "turbo manifold", that is a reverse y-pipe, which is a common turbo piping method for V6's. The reverse y-pipe retains your stock exhaust manifolds. Make sure to keep room for your downpipe and to "tuck" it all close enough so you don't have ground clearance issues.
Here is my reverse y-pipe:
And with downpipe installed:
Good luck with it
James92SE is offline
Old 07-04-2014, 11:23 AM
TonyJr's Avatar
Looks good. I think you would have more room with my setup I plan to do tomorrow
TonyJr is offline
Old 07-04-2014, 12:12 PM
James92SE's Avatar
Post some pics up tomorrow, I'd like to see it
Old 07-04-2014, 12:40 PM
TonyJr's Avatar
Ive plan to do it
TonyJr is offline
Old 07-05-2014, 10:07 AM
CMax03's Avatar
That's pretty impressive James! Hopefully your starters can survive the heat (Which I do see the exhaust wrap and heat barrier) and hopefully you can still get to things without all having to take all that exhaust stuff down.....Your turbo back exhaust looks well done (I would've used a larger resonator but the turbo is a noise diffuser as well) nice component grade especially the cat with the V-band clamps...The Maxima is very well done!
CMax03 is offline
Old 07-06-2014, 07:18 PM
TonyJr's Avatar
James what standalone are you using for your setup?
It's your engine stock or did you lower your compression?
I'm thinking of buying a mirotech lt8 for $400.
TonyJr is offline
Old 07-07-2014, 05:03 AM
Jacobaudi's Avatar
Originally Posted by TonyJr
James what standalone are you using for your setup? It's your engine stock or did you lower your compression? I'm thinking of buying a mirotech lt8 for $400.
what kind of calipers your running ?
Jacobaudi is offline
Old 07-07-2014, 05:45 AM
TonyJr's Avatar
Factory setup
TonyJr is offline
Old 07-07-2014, 06:35 AM
Jacobaudi's Avatar
Factory setup
ve comes with dual piston calipers ?
Old 07-07-2014, 08:55 AM
TonyJr's Avatar
Single
TonyJr is offline
Old 07-07-2014, 09:54 AM
Jacobaudi's Avatar
Single
from the picture it looks like a dual piston from the 300zx
Old 07-07-2014, 10:37 AM
I'm needing a caw
Jeff92se's Avatar
300z aluminum 4 piston calipers, my old brackets and 13" cobra rotors.
Jeff92se is offline
Old 07-07-2014, 10:48 AM
Jacobaudi's Avatar
what type of bracket would fit ?
Old 07-07-2014, 11:57 AM
James92SE's Avatar
Tony - I'm using Nistune, stock engine. I have bad rings in one cylinder and thus low compression in that cylinder and it's smoking pretty bad now. I've just parked it and have a new rebuilt VE to go into it if I can ever get around to it. I still haven't fully figured out Nistune 100% so I want to make sure my tune is 100% spot on on the new engine. The guy that tuned my car I don't think he really knew what he was doing with Nistune.
Jacobaudi - I assume you meant to ask me about the calipers. Those are my pictures. You are correct, they're Z32 calipers. Specifically the 30mm aluminum ones. Like Jeff said, they are his brackets. He designed and had the caliper adapter brackets built years and years ago and a number of us here bought them. Occasionally, you'll still see a set pop up for sale on here.
Old 07-07-2014, 12:46 PM
Jacobaudi's Avatar
Tony - I'm using Nistune, stock engine. I have bad rings in one cylinder and thus low compression in that cylinder and it's smoking pretty bad now. I've just parked it and have a new rebuilt VE to go into it if I can ever get around to it. I still haven't fully figured out Nistune 100% so I want to make sure my tune is 100% spot on on the new engine. The guy that tuned my car I don't think he really knew what he was doing with Nistune. Jacobaudi - I assume you meant to ask me about the calipers. Those are my pictures. You are correct, they're Z32 calipers. Specifically the 30mm aluminum ones. Like Jeff said, they are his brackets. He designed and had the caliper adapter brackets built years and years ago and a number of us here bought them. Occasionally, you'll still see a set pop up for sale on here.
kool thanks because I'm really looking for a set for my maxi
Old 07-07-2014, 03:14 PM
TonyJr's Avatar
Is this the best ecu for the maxima
TonyJr is offline
Old 07-07-2014, 03:18 PM
TonyJr's Avatar
I have to research on anyone that knows to tune that standalone you use . Cuz in Orlando fl we have one of the best tuner for mirotech. At central Florida turbo shop. Www.cft.com.
TonyJr is offline
Old 07-07-2014, 08:40 PM
Ad·min·is·tra·tor
DanNY's Avatar
James - turn up the heat on your mig welder man.
Tony - are you really going a true stand alone or piggy back?
let's keep the terminology correct here so you sound half way intelligent when you're talking to a shop.
a piggy back - (nistune, emanage) more or less takes your stock ECU and you as the user can modify the settings from the factory. you will use your existing stock set up (MAF) and sensors.
a stand alone - (AEM EMS, Haltech) replaces your stock ECU with the stand alone ecu. Many times you may need to switch harness and sensors to get the stand alone running. the benefit of this set up is that you're able to run anything you want and there's a good amount of support.
DanNY is offline
Ad·min·is·tra·tor
DanNY's Avatar
DanNY is offline
Old 07-08-2014, 01:02 AM
TonyJr's Avatar
Probably a piggy back. Thanks for the info tho
TonyJr is offline
Old 07-08-2014, 06:29 AM
James92SE's Avatar
Dan, the visible welds in my picture (support brackets etc) were all done in flux core about 8-9 years ago when I first started this project
My mig welds don't look that bad
Old 07-08-2014, 06:59 AM
Ad·min·is·tra·tor
DanNY's Avatar
oh ok...thanks for letting me know james. i'm like ohhh boyyy he needs to practice on a scrap piece next time..LOL
DanNY is offline
Old 07-10-2014, 06:16 PM
TonyJr's Avatar
Do you have the nistune type 3 board?
TonyJr is offline
Old 07-11-2014, 04:26 AM
James92SE's Avatar
I don't remember off the top of my head but that sounds right
It lists right on their website what type board for which engine. The actual engine code VE30DE is listed so double check there
Old 07-11-2014, 08:08 AM
TonyJr's Avatar
I check it's type 3 for $545. Way cheaper then a standalone. But I found a mircotech lt8 for $400 on craiglist.
Thanks for those pics of the turbo setup you made on paper. Very helpful. I learn you need the Wastegate connected on dump pipe n turbo manifold. I though it was only for turbo manifold. I need to learn to tig weld so I can save money on the turbo manifold etc
TonyJr is offline
Old 07-11-2014, 11:57 AM
Ad·min·is·tra·tor
DanNY's Avatar
buy this book...it's a little aged but the basics and the info is very relevant.
http://www.amazon.com/Maximum-Boost-.../dp/0837601606
if you can't understand the basics how the system works how the heck are you going to even start piecing it together?!
the wastgate is attached to the system..generally right before the turbo.
the "dump pipe" is the piece that attaches to the wastegate and either dumps out the excessive gas from the engine into the atmosphere or it can be rerouted back to the down pipe after the turbo. purpose of the wastegate is to bleed off exhaust gases so the turbo doesn't continue to build boost and over boost your car.
are you REALLY going to learn to TIG weld? a decent AC/DC TIG welder is $1000 and up...add water cooled torch and etc and it can cost you over 2K for something from Miller. TIG has the steepest learning curve out of all the welding methods so it's not something taken lightly since considerable time and money will need to be put into TIG welding.
if you know someone with a TIG set up you'll still need to understand the fab part and what parts needs to go with what. if you're building your own manifold then you'll need to have a good idea on fit up and make sure it's tight since you can't really correct poor fit up with TIG. MIG...you still get away with slapping more weld in a spot and have it work when the fit up is not perfect.
if you really really REALLY want to do this then you'll need to invest A LOT of time and money. are you ready to do that?
did you actually build that manifold like you said in the first post in the thread from swapping the Y-pipe around?
DanNY is offline
Old 07-11-2014, 12:22 PM
CMax03's Avatar
Awesome book....I have it as well! I have a libary of automotive, aircraft and technical manuals....and there's another book I would recommend regarding understanding automotive engine management systems:
http://www.amazon.com/Modify-Managem...4WB46J4KENT07V
CMax03 is offline
Old 07-11-2014, 03:16 PM
James92SE's Avatar
On paper? Do what?
Like Dan said, the wastegate is generally placed right before the turbo. However, unlike the setup in your picture you do not want the wastegate feed pipe T'd directly sideways into your y-pipe. I'm not sure who's setup that is, I'm assuming a 4th or 5th gen guy, and it may work okay for him but a wastegate that is just fed with a totally perpendicular T is really a subpar design and does not allow the wastegate to function properly.
Ideally, your wastegate should be fed off of a Y right with the other "fork" feeding your turbo.
Old 07-14-2014, 07:33 PM
akurtzer57's Avatar
Tony nistune is way to go. I make awesome power and very easy to learn imo.
akurtzer57 is offline
Old 07-15-2014, 09:35 AM
TonyJr's Avatar
Yes nistune sound good. Tons of YouTube video, learn alot. It's just getting too learn the software. I'll solder it myself
TonyJr is offline
litch
123
01-04-2024 07:01 PM
aw11power
10-10-2021 04:57 AM
JonBlz
10-05-2015 06:02 PM
09maxshawn11
09-30-2015 10:28 AM
dshinn
09-26-2015 08:07 PM
Quick Reply: ve turbo manifold
