obx headers installed help
Old 05-25-2014, 04:56 PM
custommaxi92's Avatar
Hellow this is for anyone that in stalled them also Id like to know how or what you used to make the 02 sensor fit since the hole on the pipe is a lot bigger thanks
custommaxi92 is offline
Old 05-25-2014, 07:01 PM
CMax03's Avatar
Pictures please! I never had a problem with the O2 bung size just it's location!
CMax03 is offline
Old 05-25-2014, 08:18 PM
schmellyfart's Avatar
The headers have a M18 o2 bung, I believe the senor on the 3rd gen Maxima is M14. Unfortunately I do not recall the thread pitch of either size, but you will need an adapter or have a new bung welded in.
schmellyfart is offline
Old 05-26-2014, 05:54 AM
ac max 92's Avatar
An adaptor or new bung welded in like previously stated does sound like your only option but being these are made for the 3rd Gen you would figure they'd make it the right size. Outside of that issue how were they to install? Did they fit well? and did you put them on the VG or the VE? Reason I ask is I thought about a set myself.
ac max 92 is offline
Old 05-26-2014, 06:36 AM
shiloh51933's Avatar
I never had a problem w/o2 sensor fitting...
shiloh51933 is offline
Old 05-26-2014, 11:48 AM
CMax03's Avatar
Another sign of OBX copying crap (Pacesetter VG30 Maxima Headers) and not quite getting it right! If you can't get an O2 bung adapter just buy a M14 (14mm x 1.5) bung and a M18 (18mm x 1.5)...use the M18 plug for yours and drill and weld on the correct size O2 bung as req'd...good luck finding the M14 size they're out there but not the standard size....You sure it's not a M12?
CMax03 is offline
Old 05-26-2014, 06:18 PM
Problem solved I just got an adaptor from pepboys but thanks for the help...as far as the headers they were quite easy to install I had broken studs but I got them all out only problem I had wuz the 02 sensor bung being twice size of my o2 sensor and rear header flange wuz tapping in to the rack so i had to grind them down a bit and I moved the rack up a tiny bit but I can say that I love them they look nice sound nice but make sure you use exhaust wrap its gets real hot .but I give them a 10/10 for sound nd 7/10 for installing
Old 05-26-2014, 06:19 PM
Yes there for a vg
Old 05-26-2014, 06:31 PM
bald aggression est 78
Kountz430's Avatar
will they work with a warp speed y pipe
Kountz430 is offline
Old 05-26-2014, 06:46 PM
Ad·min·is·tra·tor
DanNY's Avatar
highly doubt it. if i know OBX they copied pacesetter. pacesetter replaces all the y-pipe stuff.
DanNY is offline
Old 05-27-2014, 05:44 AM
If you cut and weld, otherwise no.
Old 05-27-2014, 05:49 AM
Originally Posted by custommaxi92
I had broken studs but I got them all out only problem sensor and rear header flange wuz tapping in to the rack so i had to grind them down a bit and I moved the rack up a tiny bit but I
I had to grind the flange on mine too...it wasn't touching at stand still but during movement(driving) it would rattle on the rack something awful!! I got a Magnaflow cat/resonator w/2.5" SS plumbing to 2.5"inlet 3.0" dual outlets SS Megan muffler...sound Bad Azz!!
Old 05-27-2014, 09:30 AM
Kountz430's Avatar
im guessing the mounting/connecting points from bottom of the header to y pipe ?(lack of better term)
Old 05-27-2014, 10:15 AM
CMax03's Avatar
I've seen the OBX SS version of Pacesetter VG headers....post a picture they're Identical slip joints and all....
CMax03 is offline
Old 05-27-2014, 01:32 PM
Nice that's aswome I have the same setup but with out the resantor nd and an hks muffler sounds amazeing I'm going to post pics when I get the chance
Old 05-27-2014, 03:43 PM
What size did it end up being?
Old 05-29-2014, 06:47 AM
Pics w/sound clips please!!
Old 05-30-2014, 01:09 AM
The o2 sensor wuz 11mm nd the bung wuz 17mm (i used a wrench to figure the diffrence in size) so i just got an adaptor tht wuz 12mm to 18mm bc thats all they had that wuz double dreaded nd everything fit perfect.....the annoying part is when i bought this car someone glued the o2 connectors toghter smh so i had to splice and re wire it
Old 05-30-2014, 07:07 AM
CMax03's Avatar
That means the sensor was a M12 (12mm x1.5) and the bung was a M18 (18mm x 1.5)...I saw plenty of M18 to M12 adapters online but no M18 to M14 whuich I was looking for!!! Wrong size my bad! Anyway slap OBX's mama and make her do it right next time!
CMax03 is offline
Old 05-30-2014, 11:15 AM
Lol more than a slap i didnt kno about the other brand headers i would of bought them
Old 05-30-2014, 11:25 AM
Real soon i just gota take care of this maf problem nd give it a gud tune
last owner of this car wuz a real ******* but its only got 115 thousand mile that pretty young for these cars since they can go up to about 300 if more with proper care
Old 05-30-2014, 05:12 PM
Hey guys how do u post pics im useing the android app i kno how to do it but for some reason it only works wen i start a thread ?
Old 05-30-2014, 05:16 PM
Fakie J Farkerton's Avatar
Photobucket.
Fakie J Farkerton is offline
Old 05-31-2014, 01:43 AM
TonyJr's Avatar
Imgur Android app really easy to use
TonyJr is offline
Old 09-28-2015, 10:37 AM
ac max 92's Avatar
I realize i am bumping and old thread but i now have the same issue as cutommaxi92 had on my 92 vg but being in Canada i cant seem to find an adaptor/reducer to go from m18 to m12 but have noticed that the 4th gens have an m18 o2 sensor with the same connector and all so i was thinking of giving it a shot. The only difference apparently from what i gathered from the parts store is the sensing element. Strange thing is 85-88 have the same sensing element as the 4th gens but the 3rd gen seems to be different but im wondering if that sensing element is going to make it or break it and if it's worth a try. Being i was going to change my o2 anyway it might just as well save me from getting both a reducer and sensor where i could just use a 4th gen o2 and call it a day. Any thoughts?
Looks like the 2nd and 4th gens use zirconia sensing elements where the 3rd gens use titania sensing elements if im not mistaken the titania would be the better sensing element though?
Old 09-29-2015, 02:03 PM
ac max 92's Avatar
Well being i cant seem to find an adaptor i am just having a 12mm bung welded on. Also after talking to a rep at ngk about the sensor he said that i should stick with the stock titania sensor and that going to a zirconia sensor wouldnt be recomended. So it looks like i have the solution to the issue taken care of.
Old 09-30-2015, 08:18 AM
2 VE's are better than one!
James92SE's Avatar
Is the M12 and M18 different sized from the US ones?
I don't remember what the exact sizes are, but US cars have "large" and "small" 02 sensors. The 3rd gen has the "small" one. I very easily found screw-in bung adapters on eBay that I have used on my turbo project
James92SE is offline
Old 10-01-2015, 05:52 AM
ac max 92's Avatar
I would imagine they are the same as long as they're metric. I couldnt find an adapter anywhere where i am. I was actually pondering ordering one from ebay but it would have took over a week to arrive and could only get them in pairs at about $30 cdn with shipping and its on my friends hoist so i didnt want to have his hoist tied up too long as thats his livelyhood but he was able to grind a 12mm nut to fit perfect to weld in so it worked out well. After researching our 3rd gen o2's are titania which are a quicker acting sensor than the zirconia. I could have got the zirconia in a m18 but after speaking to a rep at ngk he said it would definately be recomended to stick with the titania stock sensor. Anyway everything worked out well. Now just have to grind the rear flange a little for clearance so its not hitting the rack and everything will be good.
Old 10-01-2015, 03:26 PM
imported_Nismo_max's Avatar
how much modification will a 4th gen aftermarket y pipe need to fit in our 3rd gen, specifically VE5 models?
imported_Nismo_max is offline
Old 10-04-2015, 05:22 PM
ac max 92's Avatar
If your just wanting the y pipe your probably best to just stick with warpspeed which make 3rd gen specific y pipes that dont need mods. If your wanting headers too well chances are you'd be looking at some slight mods with the obx. I don't think the 4th gen flanges or pipe would match up and probably not worth modding for what its worth modding a 4th gen pipe you could probably just have an exhaust shop do a custom pipe. I had a custom job done that i'd sell but probably keeping incase i ever needed or decided to put the stock manifolds back on. Long story short just check warpspeed's site if your just after a y pipe.
MaxLife17
06-27-2019 01:37 PM
2kmaximel
09-16-2015 03:19 PM
Maxboy23
09-04-2015 06:04 PM
Johnny9595
09-03-2015 05:18 AM
Quick Reply: obx headers installed help
