Think the steering rack went bad
Old 02-09-2014, 07:43 PM
jbbons25's Avatar
Here's a video of my car making noise when I turn the steering wheel to see if you guys can confirm if it is the steering rack or something else. I wanna say that it's the steering rack because the noise is not coming from the suspension (springs, struts, ball joints) ATF is on level on the power steering reservoir and I replaced the steering rack bushings last June.
jbbons25 is offline
Old 02-10-2014, 03:46 PM
chrome91's Avatar
i would guess its maybe something in the steering shaft itself
chrome91 is offline
Old 02-10-2014, 06:22 PM
Levsimus's Avatar
My Mustang did that awful screeching, but replacing the inner tie rods and ball joints/ outer tie rod ends solved it. No idea which was the cause of the problem though.
Levsimus is offline
Old 02-11-2014, 01:39 AM
jbbons25's Avatar
Double-checking and I did the inner tie rod ends (moog) along with the bushings. I wonder if the tie rod ends prematurely failed. I will say that I haven't replaced the struts at least 5 years ago, but I do believe the noise is coming from right in the center.
I also remembered that the rack is remaned and installed around that same time as the struts, I think way before that.
Gotta find someone to steer while I pinpoint the noise.
jbbons25 is offline
Old 02-11-2014, 08:12 AM
Levsimus's Avatar
Does it do it when going over bumps as well or only doing it when turning the wheel? Only stationary or even when moving?
Levsimus is offline
Old 02-11-2014, 02:39 PM
jbbons25's Avatar
It only makes the noise when turning the wheel. So far I only paid close attention when stationary and it makes the noise at idle and around 3k RPM. When moving, I only noticed when I make turns from a stop.
jbbons25 is offline
rbarnes
12-31-2015 06:29 PM
mikeg75
11-30-2015 05:12 PM
ChrisIve
09-21-2015 12:01 AM
ColdCananda
09-20-2015 10:45 PM
Bluenissan
09-20-2015 08:54 PM
Quick Reply: Think the steering rack went bad
