whats wrong
These cars are known for leaky injectors and rails. There was a safety recall once upon a time, but was later resolved. Not sure the recall affects you, but worth checking with the dealership. They will run your vin and see if there are any active recalls.
Fuel line itself (actually, there are two that run side by side) runs from the drivers side of the engine near the rear valve cover, and back toward the fire wall.
As for the OP, there are a series of things that could be possibly wrong and you have failed to provide sufficient detail to be demanding a precise answer. I mean... does it LITERALLY smell like fuel INSIDE where you put the oil in???
Why don't YOU tell us how the car is running? Is it making any noises? Smoking from anywhere? does it still smell like fuel after the car is warmed up?
you know... something along those lines with some background info.. You username leads us to believe you own a 1991 Maxima which is a VG30e equipped vehicle, can you confirm that IS what you are asking about?
lol DanNY beat me to saying it! I'd be lucky if I get a responce withint 24 hours
In that case, I'm gonna bypass all the other possibilities and jump directly and firmly on to saying you have intermittently failing injectors at least one is on its way out. You can test resistance by setting a multimeter to Ohms possibly the "20" option is the best. Put each lead onto each of the prongs in the injector. Should NOT be less than 10.0 and no more than 14.0. Keep us posted.
I am ordering a fuel pressure regulator for mine. On its way out was like a progression. Engine was running richer and richer. At 1st I thought I bought some bad fuel. Changed it out same problem. Checked my injection pulse from the ECU with a light on one of the injector wires and it was very dim. Thought I had a really lean issue going on from the ECU but my engine was overloading with fuel. After that I checked the ECU lights it was showing RED much of the time telling me it was rich. Glowing red then after several REVS of the engine changed to green & red, then after that if I let it idle at some point would revert back to red. My O2 senor was reading the extra fuel and doing its job trying to lean the mixture. So I cut the elbow off the top of the regulator and threaded a woodscrew down and tighten it down some and put pressure helping close the valve some in the regulator and the engine responded running better but by doing that effects the return line some because the fuel pumps tone would change to a higher pitch. Night and day difference. You can also put compressed air in there but I didn't have anything like that to use. I think after time getting hot and cold over the years weakens the spring tension in the regulator. Ran like a carbureted engine that's float is stuck open an overloading. You can REV it out but only lasts but so long. That extra un burnt fuel makes its way into the crankcase, plus it produces a lot of vapor.
Good time to quit smoking...and rule out items listed by members here. Check you tune parts, plugs, cap, rotor, plug wires to ensure that you have the SPARK it takes to burn the fuel, check the fuel pressure Regulator this does what its name applies. If all that don't work check the resistance of your injectors sited earlier. You have to rule things out one by one. Check ECU for any codes rule out bad sensors, having one out them not working can cause the ECU to put out a rich mixture. Make a check list and take your time on each thing. Its hard to tell anything without feedback of visual inspection of some of the related parts. So keep us posted.
Forge277
06-13-2016 09:26 PM
bigfrank
10-01-2015 12:51 PM
pears
09-18-2015 05:25 AM
