90 manual Transmission breakdown
Old 10-12-2012, 09:03 AM
woot's Avatar
I'm trying to find a procedure on how to split the cases on the Tranny.I don't wanna split the two and pieces fly everywhere. can someone please assist?
woot is offline
Old 10-12-2012, 09:07 AM
jbbons25's Avatar
http://www.nicoclub.com/FSM/maxima/1994/mt.pdf
jbbons25 is offline
Old 10-12-2012, 09:24 AM
woot's Avatar
I cannot get it to go into second for nothing, all other gears are smooth. It just started doing this!! Hopefully it's a pretty forward procedure when splitting the case.
THanks for the Link!
woot is offline
Old 10-12-2012, 06:19 PM
maximo018's Avatar
So is it a 5spd or A/T?
maximo018 is offline
Old 10-12-2012, 06:23 PM
woot's Avatar
Got the tranny out in a couple hours. Gonna split the cases in the morning. Keep the fingers crossed
woot is offline
Old 10-12-2012, 06:29 PM
woot's Avatar
5speed, sorry I thought I had mentioned that
woot is offline
Old 10-12-2012, 10:02 PM
maximo018's Avatar
You want to remove the check ***** first. Pretty much the same side as the slave the are 3 bolts that contain the check ball and spring. You will need a telescoping magnet to extract the spring and ball. To get an idea of what the bolts look like there is one under the slave towards the bottom (if you were looking at it horizontally). After all that right behind the slave there is the seem where the bell housing meets the case. Loosen the bolts in according to the fsm. Use a rubber mallet and a flat head screwdriver to course the 2 apart. Beware there will be a bit of gear oil leak out once this is done.
Old 10-12-2012, 10:03 PM
maximo018's Avatar
Wait til you've done it enough to get it out in 40mins. Lol.
Old 10-13-2012, 06:43 AM
woot's Avatar
I'm trying to locate this check ball you speak of, and either I'm blind or it doesn't exist.
I will dig further, before I give up
woot is offline
Old 10-13-2012, 10:40 AM
woot's Avatar
Do you get the ball and springs out through the bolt holes or what
woot is offline
Old 10-13-2012, 01:15 PM
maximo018's Avatar
Yes. Its the easiest way instead of opening the case and they go everywhere(I did on my first time). Clue: the bolts should be close to the end of the veins that run along the cast of the casing. Idk if that makes any sense. I know 2 are located right below the fill plug. If you don't mind waiting until 8 (when I get back home) I'll take a pic.
hcarter1112
42
07-18-2022 03:35 PM
tarun900
19
12-20-2021 06:57 PM
06-06-2017 02:01 PM
Pied
09-26-2015 03:29 PM
Quick Reply: 90 manual Transmission breakdown
