Brakes sticking
When is it sticking? - when you expect it to release and its thus overheating the disk/caliper/hub?
How do you know its sticking?
OP...this is what i'm talking about...did the new caliper come with this piece too?
I took it to a mechanic and he cant figure it out, im wondering if the master cylinder can stop working on just one line that the fluid doesnt go back to the resoiur, my master cylinder has four lines one for each wheel. Does anybdy know ? J.A.
At the time of the brake "dragging" what happens if you undo the bleeder nipple on that wheel - does the "drag" go away then? .............. with lots of fluid spraying out from it?
This happened to me many years ago in my old chevy truck. the stock brake line had collapsed internally and was acting as a check-valve with the brake fluid. I push on the pedal and it stops. I let go of the pedal, and fluid can't flow backwards due to the damage in the line. truck still stops.
replaced the rotor, caliper, and pads.. problem was still there. replaced the master cylinder. problem still there. finalyl broke down and replaced the $10 brake line. problem gone.
something to think about. Brake lines are relatively inexpensive, but get VERY expensive when they fail and you can't stop... if your car is 20 years old, it can't hurt to replace the lines, even if it's not the problem.
Hell if you are really stumped on where to start try going to Andy's autosport.com. Theres been a couple of times I found legitamently good products reasonably priced. Doesn't hurt to try.
04-16-2020 05:15 AM
06-06-2017 02:01 PM
HerpDerp1919
09-29-2015 02:02 PM
