Go Back   Maxima Forums > Maxima Discussions > 3rd Generation Maxima (1989-1994)
Sign in using an external account
Register Forgot Password?
Register Photos Classifieds FAQ Timeslips Members Parts Guide Search Today's Posts Mark Forums Read ExperienceVendorsUsed CarsGarage TSB & Recalls
Search
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Search this Thread Display Modes
Old 12-18-2011, 09:48 PM   #1
Points: 2,915, Level: 33
Points: 2,915, Level: 33 Points: 2,915, Level: 33 Points: 2,915, Level: 33
Activity: 9.9%
Activity: 9.9% Activity: 9.9% Activity: 9.9%
How to: Reading and Clearing Diagnostic Trouble Codes
Click the image to open in full size.
READING DIAGNOSTIC CODES
The stored malfunction codes are accessed using the red diode on the ECM. The codes are interpreted by the number and duration the diode flashes.
A long flash (0.6 seconds) indicates the "tens" digit while a short flash (0.3 seconds) is the "ones" digit. All flashes will have a short pause in between.
For example, if the red diode flashes once and then flashes twice rapidly this should be interpreted as code 12. The codes are displayed in numerical order starting with the lowest and ending with the highest.
If more than one code is in the memory, the ECM will always display the lowest number first, pause for about two seconds and then go to the next higher number. This will continue until all the stored codes have been displayed. The ECM will then go back to the lowest numbered code and repeat the cycle.
EXTRACTING DIAGNOSTIC CODES
1. Access the ECM and position it for observing the diode.
2. Turn on the ignition switch on (do not start engine).
3. Confirm that the "CHECK ENGINE" lamp in the instrument panel illuminates. If not check the bulb and/or the bulb circuit. Repair as necessary.
4. Turn the diagnostic mode selector on the ECM fully clockwise for at least two seconds then turn the selector fully counterclockwise. The ECCS system is now in mode 2.
5. Observe the diode and note the code(s) displayed.
Note: Code 55 indicates all systems are OK.
ERASING DIAGNOSTIC CODES
1. Turn the ignition key on.
2. Turn the diagnostic mode selector on the ECM fully clockwise and wait more than two seconds then turn the selector fully counterclockwise. The ECCS system is now in mode 2.
3. Turn the diagnostic mode selector on the ECM fully clockwise and wait more than two seconds then turn the selector fully counterclockwise. The ECCS system is now in mode 1.
ECM memory is now erased.
SOURCE: ALLDATA REPAIR 2011
Laevateinn is offline   Reply With Quote
MaximaOrg
Nissan Maxima
Paid Advertisement
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
Emails Backup
Search Engine Optimization by vBSEO 3.5.2
