going crazy
Old 03-27-2011, 04:30 PM
tothemax2003's Avatar
going crazy
i dont know what else to do, my car has being running perfect until two days ago.It started when my dash went out, ofcourse i first check the bulbs and sure enough i had a burnt bulb.I then turned the lights on and it burned my number 10 a fuse, well it just keeps blowing the fuse.Thing is that the rear light assemblys were all changed they are pretty much brand new.And pfcourse the dash lights up when i brake without having the headlights on.Any help would be appreciated .
tothemax2003 is offline
Old 03-27-2011, 08:41 PM
MaxandAlt's Avatar
Have you tried your rear side marker lights? I just got my 93VE and kept having the same problem! Changed the lights and the fuse kept blowing! The only thing is that my dash lights didn't light up at all. I checked the rear side marker lights and both were out. Replaced, and Maxine lighting up like new again!
MaxandAlt is offline
Old 03-27-2011, 09:26 PM
maximo018's Avatar
Most ppl have this issue. The sockets for the rear tails usually have some corrosion build up. Just clean and use dielectric grease.
maximo018 is offline
Old 03-27-2011, 09:37 PM
CMax03's Avatar
pull all your bulbs out and see if it still blows a fuse! If it still blowing the fuse it's more than likely in the harness....Any drilling done recently???? Sounds like you hit your harness!!!!
CMax03 is offline
Old 03-28-2011, 05:52 PM
thanks found the problem light bulb making ground , my friend changed the light bulb all is good.
Old 03-29-2011, 06:41 AM
CMax03's Avatar
Wowwwww! All that from that................?
CMax03 is offline
ivorton23
09-28-2015 09:08 PM
Garrettz459
09-28-2015 02:50 PM
ColdCananda
09-20-2015 10:45 PM
Maxima30
09-07-2015 06:13 PM
Garrettz459
08-29-2015 02:18 PM
Quick Reply: going crazy
