425WHP Sleeping Road Warrior build thread
So I put these wheels in motion about 3 weeks ago on this build. I have a 91'SE5 with 200k on the clock, the car is in great shape as the owner before me (my aunt) took great care of it. She was the original owner and I added the service records up from 97' until I received the max FOR FREE about a year ago and she put $13,000! in maint. and repairs and that is no lie. You can come and add them up yourself and they only go back to 97' so the number is higher but that is all I can prove.
So.... about 3 weeks ago I blew my clutch, so i bought a cheap clutch kit to hold me off BUT I did buy a JWT flywheel, which BTW is less than half the weight and let me tell you I felt a dramatic increase in acceleration so I was happy. Not even 1 week later a 3rd gen pulled up at my shop with white smoke POURING out the exhaust I didn't even have to check it, I knew what it was....HG.. I was so happy cause I knew this guy wasn't gonna fix it, so i checked it to make sure thats what it was and sure enough... HG.
so I gave him the price and he wasnt going for it so I told him i'll give $100 more than the scrap yard would and he took the deal $300.
So now I have my donor motor plus not to mention All the spare parts, factory floor mats and the carpet (which i already installed) is MINT mine had a huge hole in it from the years of her wearing high heels to work and working the clutch.
So i already bought my tokico blues and eibachs, mounts, dust boots, bearings, insulators, bump stops, my stillen FSTB from the classifieds, LCAs with ***** from my parts supplier, and JWT flywheel
!*!*!*!*!Now for the plans!*!*!*!*!
Gonna have the motor rebuilt with 8:1 JE forged pistons and eagle forged rods high flow oil pump THE WORKS
Garret gt35 BB turbo with stock z31 manifolds
intercooler and piping
BOV undecided
Which ever injectors JWT recommends as well be working together closely to build this motor they have been a great help so far with questions i have asked them
z32 MAF
Nistune
2 stage electronic boost controller
walbro 255l fuel pump
spec stage 3 clutch
blehmco stage 2 lower tie bar if I can find since he seems not to make them anymore
blemcho rear parallel link kit
Z32 BBK
Suspension techniques Front and rear sway bars
Removing ALL the emissions BS
Grounding kit
JWT stage 2 cams
JWT valve spring kit
MSD SCI-L box
Thats all I can really think of off the top of my head ATM. I will keep you updated as it progresses with pics
And i thank the Org with all the resources they provided me at my finger tips
BOV undecided
z32 MAF
Nistune
spec stage 3 clutch
Z32 BBK
Grounding kit
JWT stage 2 cams
MSD SCI-L box
research.... that's how it's done
looking forward to seeing this build. Don't bail on it, like a quite a few have done.
edit: blehmco may go ahead and make the ltb. I think they still have the jig for it. you could email their sales dept, see if they will fab you one up.
Cool beans. Don't let any of these tards around here run you off. Looks like you've done some research and aren't a total newb in terms of know-how so they probably won't give you a hard time
In for pics of your ride. I've gotta say that's pretty cool your aunt was the original owner! You don't see many women pick up stick shift sport sedans.
(is a VG 5 speed a sport sedan? )
Ya theres a few of us around with boosted 3rd gens running nistune. don't know about the others but so far its going great. Also would recomend the ve trans and axles (or change the hub side with the vg ones to fit your hubs)
Good luck bro. And don't let the org put you down cuz many here do. Personally like i plan on doing is just doing the complete build with pics and what not and just post at the end. Less chance of being picked on. You don't need too much info from the org since from the sounds of it your technically inclined in automotive. Research is all in the key to accomplishing the task you have at hand.
They can put me down all they want... Yeah its my first turbo build BUT yeah I am a full time mechanic with an entire shop at my disposal. I do thank everyone thank does believes in this build, maybe i'll let those who were helpful drive it (maybe not) I know it will take me some time, I'm not planning on being done till maybe the end of summer 11' so I don't wanna see people coming in here thinking it fell off cause i didnt know what i was doing. New suspension pics on there way
i'm kinda up in the air ATM about what ecu to run Ben at JWT swears on his ecu, but i like the way nistune works, something about just set it and forget it just doesn't sit right with me, what do you guys think
upgrades seem to be one of those things where one thing leads to another.
unless you can't find a tuner (and you seem like the kind who can find what you are looking for), I could see going jwt.
there is almost always a little more that can be had with the right tune.
also with nistune, you can set it up with race gas, e85, pump gas, and all it'll take is 5 minutes with a laptop to switch tunes for the fuel you'll run.
I agree.
im not a tuner.
my car's aren't tuned (stock ecus)
understanding from what I was told.
okay, since that's out the way...
the guys I know running e85 love it, but run bigger injectors than they would for gas. e85 requires more fuel. lots of good info out there, if it's an option in your area.
never heard of anyone running leaded or aviation fuels in a modern US engine, but that's not to say it can't be done.
(you would need bigger injectors for your application, anyway.)
my friend runs in his stock 03ish v6 ranger with no cats, and as mechanic i have not seen any side affects on his vehicle, but i also haven't taken the top end off either just seems to run fine
If you search the NASIOC forums, there used to be a VERY extensive writeup and discussion on using E85... lots of good info to research there.
.....if these tards run this guy away its because every other week, there's a post about turbocharging a VG 3rd gen.
....and in the end, can you really blame them? whats the ratio of people asking/saying they are going to turbocharge their 3rd gen vs. those who have actually done it?
OP...looking forward to seeing this happen. keep us posted!!
well got my stillen FSTB last week and my warpspeed SFCs arrived today. Today I put them both on and man what a difference. I can defiantly feel all the roll is coming from the suspension not from body flex the body is as stiff as a board. Now I just cant wait to install all my suspension parts I bought and get my ST F/R sway bars and S2 LTB and im done with suspension. This thing should turn on a dime!
I cant imagine how odd it would feel to have SFC FSTB and no other suspension upgrades. You can probably really tell what the SFCs are doing. Good luck with the remaining steps
You have no idea the difference I feel with just those 2 mods NO BODY FLEX, I love it. I can defiantly feel all the roll is now in the suspension which will be done soon! pics OTW
Yeah I've been away for a while, suspension is done though and heres the list: ST front and rear swaybars, S2LTB, subframe connectors, stillen FSTB, blemco rear link kit, lowered on eibachs wrapped around GR-2s cause they don't make tokico blues anymore for our cars unfortunately, nor do they make the eibachs but I was able to pick up a used set from a fellow org member, front camber bolt kit, new control arms all new strut mounts, boots, and bearings... I did a V-LSD swap with new axles and all new seals. I have my motor mounts drying at the moment, solid filled 80a poly resin. im ordering new rims and tires for her this week: Enkei RPF1 in black 17x8 with 225/45 kuhmos, so I can fit in a big brake kit, needs a new rack and pinion cause well lets face it, she is 20 years old and its not looking too hot, theres a lot of play. and THEN we can get to the motor which im not gonna lie i didnt do anything to except an UR underdrive pully, JWT flywheel, and a full MSD set up. I am in the process though of getting an old junker i have with a blown motor, taking my old 5 speed and swapping the trans out and sending the whole car and my donor engine to my friends shop so he can start fabbing up my custom stainless TURBO HEADERS!!!!! and let it be known this is my daily driver sorry if its taking time, Im doing all this work with little to no down time and building from the bottom up, the car has to be able handle 425hp you don't just slap it in on 20 year old suspension
Taking my Maxima to the Max!
I would go with bigger tires if I were you. I had 225/45/17s on mine and they were too small. Try a 235/45/17. It's a little bigger than stock in terms of diameter, but it's better than going smaller. 215/50/17 is the same as stock.
245/45/17 is also the same as stock, just wider than the 215, and will fit with the right wheels (ie ford cobra wheels @ 17x8+30). I had 225/50/17 on mine which is slightly larger than stock.
Sounds fun......I like your setup already it's very similar to my 90 Se......I'll be performing a leakdown test on my 90 this weekend just to see what damage I have if any damage at all......Spend alot of time setting up the 4th Gen.....exhaust and intake systems!
04-16-2020 05:15 AM
doctorpullit
12-12-2015 09:39 AM
