speedometer is off
Old 10-17-2010, 11:57 PM
jeremeep's Avatar
speedometer is off
so my speedometer is off by 10. i noticed this the other day, my friend said its probably the enkies that i put on it. is there anyway i can fix this? or should i just buy a tom tom and call it good?
jeremeep is offline
Old 10-18-2010, 05:13 AM
Jesus was a Zombie.
BenStoked's Avatar
when is it off by ten? if it's always off by 10, it's not the tires.
what size tires?
BenStoked is offline
Old 10-18-2010, 08:18 AM
2 VE's are better than one!
James92SE's Avatar
It's probably your tires.. they look too small to me at first glance
I doubt it's always off by 10
James92SE is offline
Old 10-18-2010, 10:42 AM
elusivemax93's Avatar
It is more then likely tires. You have to keep the same height as what was on your vehicle from the factory. Im soon putting 18's on mine and im still gonna make sure that my tire and rim size stay the same height as what came from Nissan when the car was made.
elusivemax93 is offline
Old 10-18-2010, 11:45 AM
shiloh51933's Avatar
Bigger wheel, lower profile tire should solve that issue.
shiloh51933 is offline
Old 10-18-2010, 11:49 AM
jeremeep's Avatar
yeah. well there 17's. i put them next to my stock wheels and they looked like the same size. but its only off by ten when im on the freeway (60+). i really dont want to have to buy new wheels though. might just deal with it
jeremeep is offline
Old 10-18-2010, 11:53 AM
What's the tire size on the wall of the tire? I have 97 se rims and my tires read 205/55/r16 so you running 17's it would have to be 205/45/r17 to keep the correct height
Old 10-18-2010, 11:59 AM
jeremeep's Avatar
yeah so mine definately arent the correct height, mine read 205/40ZR17
jeremeep is offline
Old 10-18-2010, 12:01 PM
jeremeep's Avatar
oh well, im not even worried about it being off by ten. im getting a gps anyways. hopefully the wheels will look better once i paint them, polish the lip, and lower the car.
jeremeep is offline
Old 10-18-2010, 12:10 PM
Just realize it can effect more then just your speedometer it could by chance effect your suspension over time or your transmission. Most likely not but then again i could be wrong. Havent ever had to deal with anything like that. I always do the math to figure correct fitment.
Old 10-18-2010, 12:15 PM
jeremeep's Avatar
yeah, i will probably get the right size tires in the next couple of months. hopefully is doesnt do any damage!
jeremeep is offline
Old 10-18-2010, 12:59 PM
jbbons25's Avatar
This may be of help for you:
http://www.rimsntires.com/rt_specs.jsp
Set the left side to OEM specs:
205/65-15x6.0 ET35
Then set the right side to whatever setup you're looking for. The chart below it should tell you the clearances and may warn you about fitting them on your vehicle including the speedometer conflict.
And looks like you may need 205/50-17 tires to be as close as OEM without going over.
jbbons25 is offline
Old 10-18-2010, 01:08 PM
Way out West
Cliff Clavin's Avatar
use a TIRE CALCULATOR. That will tell you the percent that your speedo is off.
http://www.1010tires.com/tiresizecalculator.asp
Stock size is 205/65/15
With 17s you should be running 235/45/17 or 215/50/17. Those are both very close. You can also use 225/45/17, but the speedo is a little off.
Any size 17s other than what I listed will throw your speedo off by a certain percent, determined by the actual tire size.
Cliff Clavin is offline
MR2 T'd
07-09-2021 05:06 AM
jchronis2552
09-21-2015 05:52 AM
Djsmaxima
09-14-2015 11:58 PM
Jigaa
01-03-2001 01:29 PM
Quick Reply: speedometer is off
