NGK Platinum plugs?
Old 08-23-2010, 03:43 PM
gladiator's Avatar
NGK Platinum plugs?
Hi, just bought a set of NGK Platinum plugs, and I think they need to be gapped. I got the gapper but don't know the gap our cars need.
I have the 94 Max GXE with SOHC
TIA
gladiator is offline
Old 08-23-2010, 10:32 PM
jbbons25's Avatar
http://www.nicoclub.com/FSM/maxima/1994/
MA-12
jbbons25 is offline
Old 08-29-2010, 09:08 PM
Get Off My Lawn
Chris Gregg's Avatar
Um, I thought Platinum plugs came pre-gapped? The pintle (or whatever it's called) is too fragile to be pushed against in order to gap?
Chris Gregg is offline
Old 08-29-2010, 09:09 PM
gladiator's Avatar
just to update myself, the gap was a bit too small. I had to widen the gap a very very tiny bit as per jbbons25's link
Old 08-30-2010, 04:36 PM
tresboi's Avatar
Correct. If the gap is off, always take them back and have the clerk find some with the spec'd gap. Turning it into a DIY gapping party it a great way to kill a new set of plugs. I learned this the hard way in my late teens.
tresboi is offline
Old 08-30-2010, 04:54 PM
Italianjoe1's Avatar
You can gap them if you use the ground strap to adjust the gap, but the normal wedge-style gappers will damage a fine electrode plug, be it platinum, iridium, or whatever.
Italianjoe1 is offline
Old 08-30-2010, 06:44 PM
gladiator's Avatar
well ain't that some sh*t, the autozone guy knew nothing. Didn't even tell me to buy anti seize gel, I had to tell him.
I used this tool to gap it. I used a tool like this to gap my platinum plugs, hope I didn't destroy brand new plugs.
http://cgi.ebay.com/ebaymotors/Lisle...motiveQ5fTools
Old 08-30-2010, 08:21 PM
tresboi's Avatar
I do stand corrected!! Thanks for the heads up, man.
tresboi is offline
Old 08-30-2010, 08:45 PM
gladiator's Avatar
so is that tool okay to gap?
Old 08-30-2010, 09:22 PM
It could be, as long as you aren't prying between the ground and electrode. You can do it with a pair of pliers, just grab the ground strap and gently open the gap. Use the tool to check the gap, just not to pry the gap open.
Old 08-30-2010, 09:24 PM
gladiator's Avatar
ah good, I didn't touch the electrode at all. Platinum tip is way too small, so my sense were like don't pry there.
Thanks!
Old 08-30-2010, 09:27 PM
Thanks!
Good call
Yeah, they are very easy to break, that's why most of those plugs come pre-gapped.
06-06-2017 02:01 PM
gigabyte
01-06-2017 06:05 PM
trsandrew
04-08-2016 06:45 PM
magiconthetire
10-26-2015 09:03 PM
trsandrew
10-25-2015 02:47 PM
Quick Reply: NGK Platinum plugs?
