Generally this isn't good..
Old 07-27-2010, 09:36 AM
  #41
chrome91's Avatar
that's what i meant.. for shame!
yea. while it's true that your mechanic can fix the static camber (ie, camber while the car is sitting still on level ground) the problem with struts, and why they are garbage, is that you only have one control arm.. and therefore can't really control camber through the full range of motion worth a crap.
you want the gamber to go more negative as the suspension compresses, more positive as it extends, to compensate for body roll and shear forces against the sidewall. if you watch a pickup truck or Ford panel van with blown shocks on the highway, you can actually wtatch the wheels camber in and out as the nose bounces over the road. That's cuz they have dual wishbones in front, with a short arm at the top and a long arm at the bottom, so the top arm pulls in at a faster rate than the bottom arm, hence the camber change. see how that would work on this setup? upper control arm angles in alot faster due to being shorter, and pulls the top of the knuckle inward toward the frame as the bottom pushes out.
however since on struts, the top is a 'fixed point', all you have to adjust the camber with is the control arm at the bottom. and as soon as the control arm starts pointing up... you start gaining positive camber under compression which is massively massively bad for cornering and stability, and just as bad for tire wear because you are basically riding on your sidewalls around turns. And i can tell you, based on crawling underneath nc90gxe's car with intrax springs, that his control arms are already pointing waay up on a 1.7" drop. you can see it in this pic.. you gain negative camber up until your control arm (yellow on the left, yellow/teal on the right) goes level (just like they show in the pic), then once it starts pointing up, you go back towards (and into) positive camber (not shown in pic) as the cosine of the arm (ie distance horizontal to body) decreases as theta (angle) increases.
about the only way to combat that and have negative camber even under compression is to add a huge amount of caster angle (which isn't very common on FWD cars), a huge amount of kingpin inclination (which you are kindof limited by your strut tower location on that one, plus it hurts turning radius after a certain point) or a huge amount of static negative camber (not so great for tire wear when you're going straight)
holy crap ive gotta study this stuff
has anyone else done a 2" drop on a 3rd gen before?
chrome91 is offline
Old 07-27-2010, 02:00 PM
  #42
Call me Wookiee Goldberg
CapedCadaver's Avatar
yes, they have. and their cars most likely handled worse than a car with a 1.5" drop or they had god-awful tire wear, or both. the only way to drop a car without those problems would be to lower the control arm and tierod end down 2" to set geometry back to what it was stock. luckily this is really easy to do on a z31. very very hard to do on a 3rd gen Maxima tho.
CapedCadaver is offline
Old 07-27-2010, 06:40 PM
  #43
STFU n00b!
Matt93SE's Avatar
What Caped said... I was that guy.. no point in coilovers on these cars unless you like replacing struts every 10,000 miles and tires every 8000.
Front suspension geometry just sucks for lowering these cars.
1.5" is about all you can do before the steering goes whack.
Matt93SE is offline
Old 07-27-2010, 06:59 PM
  #44
Fox Body FTW
AM_BlackMax's Avatar
Gonna adjust the end link tomorrow...and I'm rethinking the whole spoiler thing and considering just wiring my 3rd light in the car and just bondo, sand, & repaint the trunk to get it nice and smooth so I can save some $$
AM_BlackMax is offline
Old 07-27-2010, 08:32 PM
  #45
chrome91's Avatar
im dropping into twilight zone territory
i'm going to still try a Koni strut/2" Ksport drop setup. i go through tires so fast that im considering just getting cheap junkyard tires from now on.
i know Koni has a lifetime warranty for their struts, does this apply to if you buy them on Ebay and if theyre on a lowered car?
chrome91 is offline
Old 07-27-2010, 09:18 PM
  #46
STFU n00b!
Matt93SE's Avatar
No and no.
When you hit bottom, the Konis mash the adjuster on the bottom of the shaft into the end of the housing and it FUBARs the whole strut. you immediately lose all damping. Send it in for warranty and they laugh at you and tell you go to buy a new one (at full price) and install bumpstops next time.
problem is when you go that low, you're already on the bumpstops and any compression in the bumpstop will result in bottoming of the strut and damage.
Matt93SE is offline
Old 07-28-2010, 07:08 AM
  #47
No and no.
unless you find a way to move the strut mount up relative to the body. but by the time you get THAT much compression in the suspension your geometry is uselessly far off anyways so what's the point, right?
Old 07-28-2010, 08:07 AM
  #48
Jesus was a Zombie.
BenStoked's Avatar
Hey, Matt, I know you are generally really knowledgeable about engineering stuff.
If one were to move the balljoint above the control arm, and add a spacer, would this correct the problem, or create a bigger problem?
(I am not giving advice to the noobs with no engineering background. this is an uneducated idea, so don't try it)
BenStoked is offline
Old 07-28-2010, 10:24 AM
  #49
chrome91's Avatar
No and no.
ah i see. well i'm going to be stupid and still try it, i'll see how things play out. i know youre right but i want to see if my mechanic can work things out
the last part i need to fix my suspension is the front swaybar mount, i went to the junkyard today and found a low mileage US 94 GXE. i think i found the swaybar (black piece of metal running across near the control arms) but what exactly is the mount? theres 2 bracket like things around the swaybar, are those them?
chrome91 is offline
Old 07-29-2010, 09:04 AM
  #50
dude you're such a dipshiit. if Matt couldn't do it on his own car, as a parts fabricator for 3rd gens there's no way in hell your so-called mechanic (who cares nothing about maximas, just getting paid) can do it. not unless he can figure out how to move the whole balljoint and tie rod end down by 2 inches.
Old 07-31-2010, 10:37 AM
  #51
Hatmanafro's Avatar
so im still curious what matt has to say about bens comment
Hatmanafro is offline
Old 07-31-2010, 03:49 PM
  #52
STFU n00b!
Matt93SE's Avatar
Nope. tried that too. wound up removing it in short order cause it made bumpsteer horrible bad.
(note the date on the picture if you go to the directory listing..)
just because you're changing the angle of the control arm relative to the joint, you're not actually moving the pivot. in effect, all you did was lengthen the control arm by a fraction of an inch. Unless you find a way to move the balljoint down relative to the spindle (so the ball joint is physically lower, not just bolted to the control arm differently), it's not going to do you any good.
Matt93SE is offline
Old 07-31-2010, 04:06 PM
  #53
Jesus was a Zombie.
BenStoked's Avatar
knew it was too simple
not surprised you tried it, either.
Old 07-31-2010, 08:20 PM
  #54
Hatmanafro's Avatar
now i can sleep at night..
Old 07-31-2010, 08:47 PM
  #55
STFU n00b!
Matt93SE's Avatar
Matt93SE is offline
Old 07-31-2010, 08:58 PM
  #56
Hatmanafro's Avatar
Old 08-01-2010, 06:25 AM
  #57
yep, i had thought about it too but realized it wouldn't work for the reasons he mentioned. The ones on the z31 actually separate the bj from the spindle, but leave the bj directly attached to the lca, which is what you want. sweet bonus on the z31 is that the bj and tierod attach to the same thing so i don't get bumpsteer issues since they both move together (not my pics)
cliffs:
LCA->spacer->bj->spindle = bad
LCA->bj->spacer->spindle = good
Old 08-01-2010, 06:37 AM
  #58
1991Maxima1991's Avatar
i personally have the 2" drop without getting an alignment or anything and let me tell you if it didnt look so badass id take it right back off...The ride is SOLID and the negative camber is just eating up the insides of the new tires i baught... i took my bumpstops out because they were a little dryrotted... truthfully it was because upon reinstalling the spring on the strut i forgot to put 1 on so i said hell with it all of em are off but i would NOT recommend that atall..I still love the drop tho and it higs corners like no other with virtually no body roll...
1991Maxima1991 is offline
Old 08-01-2010, 06:46 AM
  #59
STFU n00b!
Matt93SE's Avatar
Half the reason your tire wear is so bad is because you haven't gotten an alignment yet. take that sucker to an alignment shop and get it fixed. your toe is way off, causing it to eat tires. it always is after you lower a car.
Matt93SE is offline
Old 08-01-2010, 07:10 AM
  #60
part of the reason is also because my balljoints are about shot and tierod ends need replacing...but indealing with the motor swap and tranny swap issues ive put that on the back burner so to speak...
Old 08-09-2010, 06:01 PM
  #61
chrome91's Avatar
well everything is done tomorrow, i just need to get an alignment and camber bolts now. couple of questions-
i need camber bolts after, i can get a cheap alignment done at Canadian Tire because i bought tires from them, but theyre and probably dont know what a camber bolt is, can camber bolts be put in a few days after an alignment?
and i'll be away from Thursday-Sunday and the Max will be in the garage for the whole time, obviously nothing would be wrecked if i just drove the Max home tomorrow and got an alignment/camber bolts Monday right? thanks
chrome91 is offline
Old 08-10-2010, 11:29 PM
  #62
chrome91's Avatar
its done i have the tytest mad JDM handling of any 3rd gen now
chrome91 is offline
Old 08-11-2010, 09:28 AM
  #63
Darkwing48's Avatar
Pics or it didn't happen?
Darkwing48 is offline
Old 08-11-2010, 10:23 AM
  #64
chrome91's Avatar
pics shall come tonight
chrome91 is offline
Old 08-11-2010, 01:55 PM
  #65
chrome91's Avatar
threw them in the camber bolt thread
http://forums.maxima.org/3rd-generat...-question.html
chrome91 is offline
jmlee44
10-02-2022 02:13 PM
aw11power
10-10-2021 04:57 AM
Serotta33
09-17-2015 12:14 PM
ac max 92
09-17-2015 07:35 AM
Quick Reply: Generally this isn't good..
