3rd Generation Maxima (1989-1994)Learn more about the 3rd Generation Maxima here.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access
to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Looks about right to me. be sure to torque the wheel bearings to the max of that spec. go too low and they have a tendency to come loose and eat wheel bearings.
1. search on here for FSM link.
2. download FSM.
3. open to appropriate section and find specs for yourself.
4. work on car with full confidence in your work.
__________________
04 G35 Sedan 6MT- The DD
96 240SX 5 speed- The track toy
93 Maxima SE 5 speed- retired 1-5-09
2. download FSM.
one small problem.
the only FSM for 3rd gens online is a 94. which has torque specs for a VE flywheel with 8 bolts, but not a VG flywheel with 6 bolts, since all the 92-94 VGs were automatics.
Yea, I had an fsm but it didn't look right. I just wanted to verify before I took it down the road and right back to square one! I'll be done tomorrow! I'll let you guys know how it turns out!
<---------- read that, n00b.
there's no problem. The torque specs are the same.
Quote:
one small problem.
__________________
1993 Maxima GXE Super White, Ebay FSTB, 97-99 SE Rims, KYB GR2s, BlehmCo Lower Tiebar, BlehmCo Parallel Link Kit, BlehmCo RSTB, BlehmCo Swaybar Links, Addco RSB, z31 rear disc upgrade, Assurance TripleTreds.
1995 Maxima GXE-5 Dark Blue Pearl, 03 SE TE RIMs, I30 leather w/rear headrests, KYB GR2 on Progress springs, Progress RSB, ES Poly in front end suspension,WarpSpeed YPipe, Pioneer InDash Navi, Kzoosho LED tails and FX35 HID retrofit
1997 Maxima SE A/T Super Black on black fully loaded, 2001 SE Rims
i noticed that after the fact, o Captain my Captain
for some reason i thought i had seen them listed as being different in the past.. not sure why. or maybe i assumed that 8 bolts would need less tq-per-bolt than 6.
Bros, I got it running. Everything went well. I torqued the axle nut to 220. Think that will be enough? Sadly, one of the axle seals is leaking $100 worth of transmission fluid out. Gotta get that fixed! Thanks for the help gang!
