Transmission Mount inquiry
Ok, I started on my swap. I got the transmission out. I got the clutch, flywheel, and pressure plate out. But a mount broke on me and I can't continue until I get a new one. Below are pictures of said mount. Will an automatic max have one? Or is this a manual specific mount? Anyone have a part number?
m/t only. that bracket looks reusable actually. just get that broken stud off there. the stud came from the upper part of the tranny mount, which is a separate piece. and also m/t-specific. the rear tranny mount bracket that bolts to the frame is the same tho.
looks like you need a new mount but it seems the bracket is still fine. i remember going through the same thing but the bracket broke on mine not the mount. just get a new mount and try to take out the old broken piece out the bracket.
I can't find this mount at Autozone or any place like that? Does anyone know a part number or the actual name of this mount? Is it just a front driver's side transmission mount? Thanks for the help guys.
i just had the same prob with the rear tranny mount on the ve, the bracket that went to the tranny was broke, came out in 2 pieces when i pulled the 5spd for a rebuild, couldn't find one anywhere, not nissan, not used, i took it to a custom fab shop, they fixed it for about 80 bucks, its billet aluminum and they did a wicked job, i would do the same if i was you or hit up cliff for his, in my opinion tho, it would be better to get it welded like i did, im sure its much stronger now than it was stock
Unclejunebug
04-02-2016 05:42 AM
