se cluster help
se cluster help
I just tried to install one in my gxe and ran into problem, the battery light is on, the rpm gauge doesn't work and the transmission is locked(unless I use the red button on the **** (automatic), I tried to reinstall my old one and its the same thing, I really need help as to what happened (headlights still work and so do turn signals)
yea, must just be bad then. there's no difference in the electronics of one cluster vs the next as far as compatibility is concerned. the VE speedo has less degrees-per-mph just b/c it has to fit more MPH into the same sweep but it's fully compatible as well with the VG trannies' speed sensors.
Are you swapping the 125mph for the 145mph cluster? Just wondering I wanted to see what it would be like to have the white in the day and the black in the night. Even though I like the green color of my GXE at night. Jus wanna try something different.
yea.. that's just a shadow cast by the overhang of the dash btw. i had one of the map lights by the mirror turned on, otherwise it was darkish outside. but that shows what it looks like in the day vs night (except that during the day the numbers will probably be totally black)
no sir, all you have to do is just unscrew them from behind the cluster and they just come out as a whole assembly with the needles. all you have to do is just screw them back into your GXE cluster and your done. i did this to mine like 7-8 years ago.
steering wheel can stay. you have to remove the knee panel, the trim around the radio, the trim around the steering column, the trim that holds the cruise/mirror/defrost buttons, and the big black shroud around the cluster/vents/clock. about 20 screws' worth or so. then after all that's out, just tilt the wheel down, undo the 4 screws holding the cluster into the dash, and pinch the release buttons on both sides of each of the 3 harness plugs to release the cluster. I usually roll it toward me to get to those wires.
Great i just got an SE cluster out of the junk yard for my GXE. I swapped it out in like less than an hour, and it looks great, everything works fine, going to get those blue Led's from pep boys tomarro. Thanks for the idea.
I had no idea pep boys sold leds, guess i'll have to go check them out
$20 vs $11 ish ... eh not that much difference I guss but as long as they're similar style and quality
jsmith24
02-01-2016 12:35 AM
Max139617
09-06-2015 06:02 PM
