ok updates...gas leak
so recently ive been going thru a gas leak issue...replaced all spark plug wires, plugs and the what i thought bad injector? nope still leaking now ive gotta go in and test the compression in cylinder 6. what fun!?? im hoping and praying that the compression in my cylinder isnt bad because it couldnt come at a worse time than now. if compression test turns out to be good any other ideas on ways to troubleshoot my issue?
How do you know you have a gas leak?
I don't think the compression test will shed much light on the blinding problem right in front of you. If it only leaks when it is on, then wouldn't the seal be faulty, and I may be missing something here too..... Didn't you tear it down and see if the pressure from the pump caused a leak? I couldn't remember and this thread isn't your old one which you could have added to for clarity in diagnosis.............. Have you checked the seal?
"plugged - in" situation only? ................ doesn't make sense at all - the fuel rail and o-rings must therefore be fine because its irrelevant whether or not the injector is energized via the connector - the inner/outer body of the injector is always under pressure that the o-rings must seal off.
"ONTO"? .......... as in external? - if so you have a fire hazard and I certainly cannot see how an injector can be responsible for that.
i bought a maxima as a parts car and it did the same thing yours is... but i couldnt see a leak any were i could just smell it i wasnt driving it though...
did you check the fuel rail maybe its leakin were the rubber hose hooks up???
ok im not much of a car expert...all i know is when i get under my car while that #6 injector is plugged up gas starts just drizzling down my exhaust manifold onto my exhaust piping...i do have a broken exhaust manifold stud...and stops as soon as i pull off the injector harness...im thinking something is grounding out that injector? i could be wrong because if that injector was being grounded wouldnt that cause all them to do the same?
The basic operation of an injector is such that its physically impossible for the injector to make fuel run down the outside of the exhaust pipe - its simply not possible - plugged in or not - AT ALL.
Can you take a picture of the situation both with the injector unplugged as well as plugged-in ................. I don't see any other way of tackling this because your description of the facts of the problem simply doesn't match up with science at all
ummm.....
it's spraying gas, only when connected (and engine is running I presume). in other words, it works fine, it's just not spraying into the intake, but rather, everywhere else.
when you replaced the injector, you probably installed it wrong.
also, it is rude to have multiple threads on one subject. might consider that when you have ongoing issues.
thank you ben i might be new here but that makes sense dont make new threads about on going issues its just rude and i think your right he probably installed it wrong cause that same thing happened to me on my truck and i just reinstalled it properly and it worked fine
Only way that is possible is if the injector and rail its seated in is not installed on the engine .................
ummm.....
Got a air compressor? Hook up pressurized air to the inlet of the fuel rail and plug the return hose break out some soapy water and spray your entire fuel rail/injectors/hoses/regulator and look for those bubbles buddy!!!!!! GL
My guess is the regulator oring leaking!!!!!
NO! its not installed wrong! he has compression! Its not the Fuel rail! He is watching it drip from his manifold! the injector # 6 is spraying to much and the other front 2 injectors are spraying to less causing the front 3 cylinders to not fire! im having the same problem! Its not mass air flow, not ANY gasket, not distributer, not camshaft position sensor, not throttle position sensor, not grounds, not plug wires or plugs, not computer, not emission control sensor, NOT ISTALLED WRONG. TEST THE OTHER FRONT INJECTORS. I cant figure out what is wrong? does anybody know? this must be a common problem!!!!
I have a 1989 nissan maxima. It sat for 7 years, since ive had it i put on, new spark plugs, spark plug wires, K&N filter, Camshaft position sensor/Distributer, clutch, water pump, rear main seal, timing belt, tires, interior work, and exhaust. nothing major, just regular fix ups. When i got it after sitting, it appeared only the spark plug wires were chewed on by mice. Im having a very big problem with it tho. It starts fine, and the computer tells me code #55, meaning nothings wrong. When i drove it it missed and spit and had very little power, but sounded nice under 2000RPM. So i looked at it, I found out my injector was spraying in way to much fuel, i could smell it and that cylinder, plus 2 others were not firing. all 3 back cylinders run fine, but none of the front run at all. the far left front cylinder, i think #2, Was spraying way to much fuel, so i replaced the computer, later to find out it dident fix it, and plus my other 2 front cylinders, i think #s 4 and 6, werent getting enough fuel. i tested them, the far left front injector plug read like 13v, the other 2 read around 2.57v. all 3 back ones read between 11 and 12v. but the front 3 stay the same they dont change ever, to open and close. im getting spark, air, and fuel, i checked, throttle position sensor, grounds, emission control sensor, plugs, compression, intake, and they all turned out good. Ive seen on forums people have this same probllem, ive been trying to figure this out for a few months now, could you please help me or just tell me what i could do or need to do to fix this? Thank you very much, Robert Zeromski.
litch
123
01-04-2024 07:01 PM
03-12-2020 12:06 AM
JoshG
51
09-21-2015 10:41 PM
