Anyone Try 5W-40 in their GXE?
Wondering if this had an adverse affect on fuel economy.
It turns out I can't go with AMSOIL. Pricing too bad in Canada, so I found a possible replacement - Shell Rotella T Synthetic but it only comes in 5W-40, not 5W-30 as is 'recommended' in our service manual.
Any drawbacks to using the 5W-40? I read someone in some other car, it felt 'sluggish at times'...
Do you have experience with Mobil1 full synthetic? I think I want to use it from now on based on a mechanic buddies recommendation. My father told me to be careful with synthetic in old engines considering the molecules themselves are smaller and more likely to escape or travel through smaller gaps the engine may have acquired over the years: while using conventional I might add.
the molecules are not smaller. oil is oil. synthetics are more uniform since there's less "other stuff" in them with longer hydrocarbon chains.
but Mobil 1 is just fine. been using it for years. I use it in all my daily drivers now.
I, too have been running full synth for the past year or so. more available than the other brands, and my car seems to enjoy it. it still has some clarity to it when I change the oil, vs. the Valvoline dyno I was using before.
old mechanics tale left over from when it was actually true.
It used to be that there were more detergents in synthetic than regular oil.
that is no longer the case, the same detergents are used in both in order to meet the API specs.
Should be fine. 5-40 viscosity range is rather large but Rotella has the addtives to make it work. It's stout oil as it's for diesels.
I don't have a manual, but I'm pretty sure a synthetic 40 weight is just fine for a motor originally put into the 3-gen in 1989 and has roots back to 1984.5
thats what i always thought. the previous owner of my 92 used Mobil 1 (i dont think synthetic) and i switched to Castrol synthetic a few oil changes after i got the car and there was a noticable difference
Reason I brought up the Shell one is I wouldn't have to buy that expensive Comp Cams ZDDP for every oil change,as the shell already has it. The shell one doesn't meet SM, but it meets SL, SJ, SH.
Also you guys running those full synthetics, for extreme service interval, do you double it and extend the drain interval out to 7,500 Mi
I figure if I switch to synthetic it's less annoying labor to change the oil every 3,750 Mi interval like our manual says for dino....plus you don't need to buy as many filters.
Have you read any problems with cam wear here on this forums? I haven't. It's probably not a big concern with the VG motor. Although running the Rotella is a nice stout and cheap synthetic.
Why not run the 10w 30?
http://www.shell.com/home/Framework?...t5_detail.html
The original 3rd Gen oil rating was SG, and I'm pretty sure this particular Shell Rotella T I mention has close to the same amount still in it. AMSOIL (which I was very close to getting) is out of the question, the price is way too high in Canada.
I'll read up more on the 5W-40, but Matt, i've been reading cases of people saying that they lost 5% fuel economy when going to the 40 weight, over the 30. So that's a good point on it being possible 'too thick'. Plus a couple of guys said it felt sluggish. I need to use it yr around too.
Standard Oil originally sold oil under the ESSO brand, which still exists in Europe and Canada, which is owned by Exxon-Mobil. Now in Canada they re-branded their ESSO motor oil with the Mobil container...dropped the ESSO. But ESSO (Imperial Oil) is still one of Canada's biggest oil companies...Exxon-Mobil being their biggest shareholder.
tarun900
19
12-20-2021 06:57 PM
jerrod99_se-l
09-25-2015 03:02 AM
