Steering problem
Old 01-06-2010, 03:48 PM
biggz2332's Avatar
Steering problem
Remember I live in the NE so it's cold outside... Whenever I first get in the car the wheel is hard to turn no matter if morning, afternoon, or night. After I drive a couple of minutes it loosens up and the wheel feels normal and easy to turn... the only thing that came to mind for me was a ps pump going bad. any thoughts??
biggz2332 is offline
Old 01-06-2010, 04:14 PM
Garf's Avatar
Have you checked the ps fluid level?
Garf is offline
Old 01-06-2010, 04:17 PM
coolsun's Avatar
^ that and u might have to bleed it to let the air out, by opening the cap and turning your wheel max left/right a few times.
coolsun is offline
Old 01-06-2010, 04:30 PM
biggz2332's Avatar
Yea the level is fine!
Old 01-06-2010, 04:33 PM
biggz2332's Avatar
The level is ok so I'm gong to bleed it tomorow. does the front wheels have to be off the floor?
Old 01-06-2010, 05:04 PM
chrome91's Avatar
i would think bleed it too, my Max is garaged now but last year i parked outside and even in -40c my steering was normal right after startup
i dont believe the front wheels need to be off the floor, wouldnt be the best to turn them on dry asphalt but on snow theres enough lubrication that there shouldnt be a problem
chrome91 is offline
Old 01-06-2010, 05:23 PM
biggz2332's Avatar
oh ok I never bleed the PS before so I was just makin sure
Old 01-06-2010, 06:40 PM
300zmax's Avatar
I have the same issue, only happens when it is bitter cold. it has done that since i started driving it in 2002 and the pump was replaced prior to my brother buying it. i have bleed, refilled, used lucas additives and it still does it. its one of my cars quirks
300zmax is offline
Old 10-02-2010, 06:11 PM
cduffy's Avatar
Sounds like the power steering rack piston/sleeve is worn out. When it warms up it expands and has more presssure......Changing the Power steering rack should do it.
cduffy is offline
Old 10-02-2010, 06:12 PM
chrome91's Avatar
8 months later i think he probably fixed it lol
chrome91 is offline
Old 10-03-2010, 04:03 PM
shiloh51933's Avatar
leave wheels straight at fast idle til she's warm then take cap off, turn wheel left/right without hitting the stops. After doing that for a few minutes then put the wheels straight again and let her idle for a bit and then shut off. Don't forget 2 check da fluid level again. Take her for a run around the block and see what's good.
shiloh51933 is offline
lowpost99
05-16-2021 11:18 AM
03-12-2020 12:06 AM
2kmaximel
09-10-2015 08:13 AM
SusieQQ
09-09-2015 12:14 PM
slowlifer
09-08-2015 05:53 AM
Quick Reply: Steering problem
