Go Back   Maxima Forums > Maxima Discussions > 3rd Generation Maxima (1989-1994)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 11-08-2009, 05:25 AM   #1
Old Car
I recently procured an twenty year old Maxima (1989) SE manual. The car seems to be suffering from broken studs around the exhaust manifolds. Would it be easier to lift the heads and drill them out or to try to drill it with the motor still in the car.
__________________
02 Max SE 6spd
92 Max SE 5spd
Augustus Maximus is offline   Reply With Quote
Old 11-08-2009, 08:05 AM   #2
Send a message via MSN to akurtzer57
On my 91 I pulled my radiator, ac compressor, altenator and drilled them out. I had to change antifreeze anyways so why I went that route. On my 91 I dropped the motor actually to do the back studs. I couldn't get between the firewall and motor with a drill.
__________________
1991 Maxima HE351 10-18psi
1989 Maxima T04E 9psi
1986 300zx in progress
From Nebraska? Post here.
http://forums.maxima.org/midwest-texas/554848-am-i-only-maxima-owner-nebraska.html
akurtzer57 is offline   Reply With Quote
Old 11-08-2009, 10:24 AM   #3
Send a message via AIM to Stwodahorty
i took mines to the shop to drill out the studs. cost 520 with replacement of gaskets.
__________________
Maxima FTW------>
->Kyb gr2 shocks ->Eibach pro springs ->Stillen lip kit ->G35 Sedan dual tip exhaust ->2.25 inch Custom Piping Upgrade->Warpspeed Y pipe ->Power acoustik sound system
->Clarion MAX675VD touch screen head unit->Painted grill ->Intake air filter w/ adapter ->Front Strut bar ->Clear corners ->Promax Hid kit ->Mb motoring Rev rims w/ Kumho exsta AST tires.<-
Stwodahorty is offline   Reply With Quote
Old 11-08-2009, 11:59 AM   #4
I took my heads out to remove them. I didn't have the room to drill them out while still in the car, so while the heads were out me and my dad went ahead with a minor rebuild. New gaskets, piston rings, had the heads sent out and cleaned, ect. The car had been out of commission for a while because the transmission was shot, so we took this route.
__________________
89 Maxima GXE
Mods: Rear Disc Conversion, Front Strut Tower Brace, Brembo's all around (Slotted Front), SE Tails - Hopefully more to come!
Dhunterx is offline   Reply With Quote
Old 11-14-2009, 08:22 AM   #5
Started taking the engine apart...the RH manifold studs are ok, I pulled those so there's no need to pull that head. I think I should be able to do the LH without removing it. What is the difference between say Autozone manifold gaskets and Nissan OEM stuff apart from the exorbitant price.
__________________
02 Max SE 6spd
92 Max SE 5spd
Old 11-14-2009, 09:04 AM   #6
2 VE's are better than one!
Personally, I've used aftermarket (RockAuto) for exhaust manifold gaskets, intake manifold gaskets, etc. with no problems. I only make a point to stay OEM on things like the knock sensor, water pump, internal engine seals/gaskets, etc.
__________________
Desperately looking for a 5 speed axle carrier bracket. Either VG or VE will work. PM me if you have one!
Good working door lock timers $20 shipped. PM me if interested
James92SE is offline   Reply With Quote
Old 11-14-2009, 09:55 AM   #7
when i took it to the shop, they had lifted the engine to have a better view to drill it out. my motor was still in my car too, but they just lefted it a bit so they can see.
__________________
Maxima FTW------>
Old 11-14-2009, 10:06 AM   #8
STFU n00b!
If you have a small drill, you can get to them while it's still in the car. you might find it advantageous to remove the left side engine mount and lower the engine a bit using an engine hoist, but I was able to do the left side studs in the car.
I don't even think I removed the radiator... but on a 20 yr old car, pulling it and flushing the radiator out while you have the car apart isn't really a bad idea.
You'll have to pull the alternator, AC compressor, and at least the top radiator hose to get the stuff out of the way.
For the AC compressor, you don't have to actually open the lines and remove it. just remove the mounting bolts and place the compressor on top of the engine so it's out of the way.
__________________
04 G35 Sedan 6MT- The DD
96 240SX 5 speed- The track toy
93 Maxima SE 5 speed- retired 1-5-09
Check out the toys I make on my website!
Matt93SE is offline   Reply With Quote
Old 11-14-2009, 04:56 PM   #9
1993-VG30E-GXE's Avatar
Quote:
Who knows what Autozone may be sourcing, they could even be OEM. Nissan OEM is made by Ishino (VG anyways):
#14036-V5000 (RH)
#14037-V5000 (LH)
So you could ask Autozone if they are Ishino, and if so they are OEM, although they won't have the Nissan logo on the bag. Confirm the L & R though as my bags may have been switched if you do find the OEM ones. They are quite cheap if bought outside of Nissan.
1993-VG30E-GXE is offline   Reply With Quote
Old 11-15-2009, 07:09 AM   #10
FEL-PRO has always worked well for me as far as exhaust gaskets go.
__________________
1991 GXE Resurrected from the dead
1989 SE gutted for parts and 5 speed.
300zmax is offline   Reply With Quote
Old 11-20-2009, 01:42 PM   #11
Turns out I don't need to drill the studs after all. I just bought another 3rd gen. A 1992 with a 1994 VE engine 5spd manual and she looks pretty good apart from a banged up front bumper.
__________________
02 Max SE 6spd
92 Max SE 5spd
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
