Quote:
Originally Posted by 1990maxGXE
I am about to replace the transmission on my max and was wondering what seals I need to buy and what transmission fluid to buy and where to get. It looks like I can get the seals from O'reilly autoparts. Also im guessing i should probably replace the filter on the transmission since it is used with 59,000 miles, How hard is this to do and do you guys recomend a transmission cooler for it and how much do those cost?
Im sure some people will read this and think im an idiot but I want to make sure i have all the parts since i am in college and am trying to go home and get the transmission installed over the weekend.
axle seals
top pan seal (if it looks iffy)
torque converter seal
engine rear main seal
no serviceable filter on the RE4F02A.
maybe get a can of flush to flush out the radiator cooler or just get an external one (cold climates should get a t-stat on the cooler). cooler runs about 20-50 bucks. get a bar and plate and avoid the tube and fin models.
personal fav fluid is Amsoil universal ATF or Redline ATF. If you must mobil 1 will work in a pinch but i'm not a huge fan of their ATF.
good luck.
