3rd Generation Maxima (1989-1994)Learn more about the 3rd Generation Maxima here.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access
to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
So one of my fuel injectors died today. I went to start the car tonight and it ran really rough and had a check engine light. It was code 51- fuel injector circuit open. So, I used my trusty DMM to ohm out the injectors. Sure enough, the front center injector measured open.
I have searched the forums, and have found that the front injectors are supposed to be quicker and easier to replace. Some say my front center injector can be done in 20 minutes.
My question is: How do I replace the front center injector in 20 minutes as claimed?
maybe on a 4th gen or a VE, you could do it that quick, but not on a VG, due to the way the intake sits. it's a couple-hour job, IF you've done it before, or a day job if you haven't.
anyways you can sortof damage stuff by running without that injector, since your air/fuel feedback is gonna be totally wrong which will cause you to run rich on the other 5 cylinders, plus it's very unbalanced right now which certainly isn't good for your motor mounts.
__________________ PieceOut.FallToPeacesNew to the forum? CLICK HERE!!!! 1985 Nissan 300zx 2-seater: VG30E | 5spd Swap | Bilstein | 5-lug conversion | Polyurethane everything | Resurrection-in-progress! 2004 Honda Civic EX Coupe: 1.7L VTEC | 5spd | CAI soon | LED tails and Projectors soon | ES Poly Motormounts soon | 'bad weather' car/backup for teh Z 1990 Nissan Maxima GXE: VG30E | VLSD-5 swap | Exedy | NWP | a33b(F)/z31(R) BBK | ES poly | SE susp swap | 2k2SE 17s | retired Aug 28th '09 2005 Nissan Maxima SE: VQ35DE | 6spd | Carolina Panthers front lisence plate | Brother's car, not mine | <-- Therefore still 100% stock
Quote:
Originally Posted by JasonOksa
Horsepower, torque and speed are all known by The State of California to cause cancer, birth defects, and reproductive disorders.
Quote:
Originally Posted by bigleman
how much would it cost to resleeve?
how does an aluminum motor form rust on the cylinder walls???
DO NOT PM ME ABOUT PROBLEMS WITH YOUR CAR UNLESS I TELL YOU TO. THAT'S WHAT THE FORUM IS FOR
mines went bad too. was shaking like crazy. basically i was running on only 5 cylinders, and its not stable. maybe stable enough to get to the mechanics to get it fixed.
__________________ Maxima FTW------>
->Kyb gr2 shocks ->Eibach pro springs ->Stillen lip kit ->G35 Sedan dual tip exhaust ->2.25 inch Custom Piping Upgrade->Warpspeed Y pipe ->Power acoustik sound system ->Clarion MAX675VD touch screen head unit->Painted grill ->Intake air filter w/ adapter ->Front Strut bar ->Clear corners ->Promax Hid kit ->Mb motoring Rev rims w/ Kumho exsta AST tires.<-
you can't complain until you've been on 3 cylinders like i was earlier this year.... 1st gear feels like 3rd.
No way 20 minutes. It'll take you the whole day to do it the first time. You'll need to label everything when you remove the hoses and wires so you know how to put it back. From what I remember:
3 hours my first time, just take you time. the worst is the EGR tube (dont break it) the next is the coolent lines.
Get new rubber fuel line since you will have it apart. you gas mileage wil love you for it. also do not forget to change the injector o-ring. my 89 se parts car was pouring out gas.
__________________
1991 GXE Resurrected from the dead
1989 SE gutted for parts and 5 speed.
The first time it took me about 3 or 4 hours, the second time it only took me about 2 hours. Its real easy once you do one time. The shops around here wanted to charge from $120 up to $200 just to replace one injector, and not including the parts.
Thats really not too bad. This concerns my 'parts car' which I've decided to restore for the time being. I have so many little problems between both cars I dunno what to do next
You might try cleaning the injector once removed to see if it is still usable. They aren't the cheapest things around. Or, better yet, see if a shop in your area has an injector cleaning machine. From what I can figure, it is a mechanical set up that pumps a cleaning solvent through the injectors, via engaging the injectors in a continuous pulse, which could fix the one bad one and perhaps be a good preventative measure for the others.
I paid a shop to clean my injectors on my car. I am skeptical of this claimed procedure and was narrow minded at the time. If they did what they were supposed to, they hooked up a machine which pumped a cleaning solvent through the feed and return lines going to the injectors. I am even more unsure as to whether or not they engaged the injectors to provide flow so as to clean the inside of them. Beyond the skepticism I have for the claimed procedure they supposedly did, how would they have let the solvent out of cylinder/pre-valve intake outlet (if the valve(s) was/were closed)?? I apologize for any misused names for parts/components.
I paid them up front like a jerk off and was unable to tell if there was any evidence of their work on the gas lines..................
Good luck with whichever route you take! The job is really easy once the intake is off, and all of the hoses attached to it usually stay in place without having to label (my most time consuming activity when under the hood).
__________________
"Max" - 1990 SE
- Rebuilt Engine
+ Fall 2009
