3rd Generation Maxima (1989-1994)Learn more about the 3rd Generation Maxima here.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access
to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
first off, the ECU does not control ABS. there is a TOTALLY separate control unit for that. The ECU could care less.
Now think about this. If some part of your ABS system fails without you tampering with anything, what happens? Does the car become totally undrivable or does it just illuminate the ABS light and disable ABS until you fix it? The latter, of course. ABS is not a necessary system (neither of my Nissans have it), so the car can still do just fine without it... it'll just funciton as if it never had ABS, except that now there's a yellow light on your cluster. The ABS actuator box is a pass-thru design until it is activated. So if something is amiss, it simply just won't step in, but your brakes will function identically to those of a non-ABS 3rd gen.
So if for whatever reason you need to disconnect/remove certain components of the ABS system, the only thing you have to worry about is being more alert and avoiding hard stops.
__________________ PieceOut.FallToPeacesNew to the forum? CLICK HERE!!!! 1985 Nissan 300zx 2-seater: VG30E | 5spd Swap | Bilstein | 5-lug conversion | Polyurethane everything | Resurrection-in-progress! 2004 Honda Civic EX Coupe: 1.7L VTEC | 5spd | CAI soon | LED tails and Projectors soon | ES Poly Motormounts soon | 'bad weather' car/backup for teh Z 1990 Nissan Maxima GXE: VG30E | VLSD-5 swap | Exedy | NWP | a33b(F)/z31(R) BBK | ES poly | SE susp swap | 2k2SE 17s | retired Aug 28th '09 2005 Nissan Maxima SE: VQ35DE | 6spd | Carolina Panthers front lisence plate | Brother's car, not mine | <-- Therefore still 100% stock
Quote:
Originally Posted by JasonOksa
Horsepower, torque and speed are all known by The State of California to cause cancer, birth defects, and reproductive disorders.
Quote:
Originally Posted by bigleman
how much would it cost to resleeve?
how does an aluminum motor form rust on the cylinder walls???
DO NOT PM ME ABOUT PROBLEMS WITH YOUR CAR UNLESS I TELL YOU TO. THAT'S WHAT THE FORUM IS FOR
Why not just de-activate it rather than clipping/removing wires?
Because I know i'll never need it again, and I'm putting my knuckles on in a minute and can save time finding the tiny screws, plus one of the sensors on the other side needs to have the rust ground off it with a wire wheel and it's going to add more time.
I take it i'll have to disconnect the rears if I cut the front wires out.
if you want to remove EVERYTHING and reroute to the master cylinder directly you will need all new hardlines, AND a non-ABS spec master cylinder. ABS has 2 outputs, non-abs has 4.
(btw i was just kidding about the radiator thing you're never gonna live that one down)
But it's feezing outside and i'm working quickly now, I don't want to get caught in the cold. I did the deed, I went and snipped the wires from the inside of the engine bay. I notice there were little connectors, but I would have had to cut it anyway to pull it out.
Gotta remember to do the rears too. Yes, I remember now, there's something I forgot to ask you. In the VG, all those harness connectors around the engine. Do you remember if they are all keyed differently, so I can't by accidently plug one into the wrong female connector?
Worse comes to worse I can trace it back, but it would be a lot quicker if I just try and mate them up.
All the tranny ones are connected OK.
on the tranny you can (which will plug into the iacv and injector subharness). just make sure that each wire lines up to another wire... i think one of them has 6 and one 5 (iacv and inhibitor switch), and the way they are bundled SHOULD prevent any cross-wiring. for reference, the harness with yellow/black, yellow/brown, red/black, green/black, green, and yellow/blue belongs on the tranny, as does the 2x2 plug next to it (iirc black, green, green/black, brown). can't remember the wire colors for the iacv and injectors, but if you put the aforementioned ones where they belong, the others will only have 1 place they can go.
rust ate my rear driver side abs wheel speed sensor so I threw it away and unplugged the cables from the octopus looking abs pump. It has been working fine for two+ years. I rather have no abs than a faulty sensor keeping abs flipping on/off intermittently. If you were referring to the cables going into the octopus looking thingy then yes you should be fine. Go for it. But as far as removing the entire abs controlling unit, I wouldn't do it man. You're not going to gain anything from doing it.
And yes BVtran it's seems like a big headache, although I will say that when my previous ABS Actuator failed I lost brake control, so if I did re-route and replace the master cylinder as caped said is possible, it could improve safety as one less thing in the chain.
For now I can't do it though, the engine bay is full again, and I just replaced the lines to the stock master cylinder, no way I will do it again. The brake line and fuel line job was a major pain in the ***. Probably worse than anything i've done before, trying to bend those fuel lines properly.
