Go Back   Maxima Forums > Maxima Discussions > 3rd Generation Maxima (1989-1994)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 10-28-2009, 09:33 AM   #1
I Has Pushrods!
maxitech's Avatar
P/S Pump is Done
Well, my P/S pump has been noisy for awhile, and was starting to show signs of failure right when I would cold start the car.
Last night is started making an AWFUL noise while idling and started to crap out while I was driving it. Guess it's time to change it...Freakin' OEM junk, only lasted me 16 years and 186K miles...
Ever since I replaced the timing belt almost a year ago the replacement tensioner (aftermarket) has been whiny, too. I suppose while I am in there I will replace it with an OEM unit (only 3 times the price!)...
Just thought I'd share...particularly because the money I will now have to use to buy a pump / tensioner is money I was going to spend to have the exterior of the Corvette detailed...
__________________
MODS: VLSD 5-Speed Swap, Exedy Stage 1 Clutch, Turbo Manifold Studs, Koni/Eibach Suspension, Suspension Techniques F & R Swaybars w/ Blehmco RSB Links, Unorthodox Racing UDP, Blehmco Grounding Kit, WSP Y-Pipe, Place Racing CAI, Custom STS, Polyurethane Front & Rear Bushings, Q45 Front Brakes (Blehmco S.S. Lines, Brembo Rotors, Axxis Metal Master Pads), Courtesy Nissan FSTB, Blehmco RSTB, Blehmco Stage II LTB, NissanWorks TB & IACV Spacers, 9007 Headlight Bulb Conversion, GXE Fog Lamps, Sound System (Infinity, JVC, Polk, MTX), 2k3 SE 17" Wheels w/ 225/50R17 Hankook HR Ventus II Tires - 186K miles (bought 8/03 @ 87K miles)
Other Toy: '96 Corvette LT4 6-Speed, 75K miles (bought 3/09 @ 60K miles), Black on Black, Fassstt!!!! Stock, for now...
maxitech is offline   Reply With Quote
Old 10-28-2009, 10:34 AM   #2
Call me Wookiee Goldberg
CapedCadaver's Avatar
j00needapump? i has a pump.
__________________
PieceOut.FallToPeaces New to the forum? CLICK HERE!!!!
1985 Nissan 300zx 2-seater: VG30E | 5spd Swap | Bilstein | 5-lug conversion | Polyurethane everything | Resurrection-in-progress!
2004 Honda Civic EX Coupe: 1.7L VTEC | 5spd | CAI soon | LED tails and Projectors soon | ES Poly Motormounts soon | 'bad weather' car/backup for teh Z
1990 Nissan Maxima GXE: VG30E | VLSD-5 swap | Exedy | NWP | a33b(F)/z31(R) BBK | ES poly | SE susp swap | 2k2SE 17s | retired Aug 28th '09
2005 Nissan Maxima SE: VQ35DE | 6spd | Carolina Panthers front lisence plate | Brother's car, not mine | <-- Therefore still 100% stock
Quote:
Originally Posted by JasonOksa View Post
Horsepower, torque and speed are all known by The State of California to cause cancer, birth defects, and reproductive disorders.
Quote:
Originally Posted by bigleman View Post
how much would it cost to resleeve?
how does an aluminum motor form rust on the cylinder walls???
DO NOT PM ME ABOUT PROBLEMS WITH YOUR CAR UNLESS I TELL YOU TO. THAT'S WHAT THE FORUM IS FOR
CapedCadaver is offline   Reply With Quote
Old 10-28-2009, 10:51 AM   #3
STFU n00b!
Joo don't need no power steering mang. just drain the fluid from the lines and loop the pressure in back into the low press out on the rack. drive it like that. I did that on the 240 and it's been fine. then again, you gotta still drive the water pump off that same belt and I don't know if you can find a belt the right size.
PS pumps aren't that expensive.. before you replace it, check and make sure it's full of fluid.. and make sure you're using ATF in the system and not power steering fluid..
__________________
04 G35 Sedan 6MT- The DD
96 240SX 5 speed- The track toy
93 Maxima SE 5 speed- retired 1-5-09
Check out the toys I make on my website!
Matt93SE is online now   Reply With Quote
Old 10-28-2009, 11:49 AM   #4
Taking my Maxima to the Max!
mrkanda's Avatar
What about rebuilding the oem one?
mrkanda is offline   Reply With Quote
Old 10-28-2009, 11:59 AM   #5
eh... maybe not on RWD (unless it had a crapload of caster) but i would always want power steering on FWD.
also how would you tighten the belt if you deleted the PS pump? maybe a multi-groove z31 water pump pulley would work and run it off the alternator belt instead but i can't say for sure if that would work
__________________
Old 10-28-2009, 12:23 PM   #6
I Has Pushrods!
maxitech's Avatar
C'mon, Matt...Do you really think this little of me?
BTW, were you at LeMons this past weekend?
__________________
Old 10-28-2009, 12:29 PM   #7
I'm needing a caw
Jeff92se's Avatar
You could probably get away with an used one if you could verify it was running okay before. PS pumps don't go out that often as long as they have fluid. It's more the high pressure side hose that craps out.
__________________
2003 G35 Sedan. Mods comin'
3-gen parts for sale
Sold Jan 14, 2006'
Mod list:
Eibach/Konis - ST front sway bar/Addco rear bar - Blemco rstb - Otto fstb
350Z 18" touring wheels.
Modified Cattman Y, Custom flex, 4-gen Carsound cat, Custom cat-back, Y2K muffler
Custom CAI, custom ground kit, JWT ecu, Fidanza flywheel, ACT clutch, Jeff92se Cobra 13" bbk with 300zx 30mm polished alum calipers.
Jeff92se is offline   Reply With Quote
Old 10-28-2009, 01:42 PM   #8
I Has Pushrods!
maxitech's Avatar
Quote:
I replaced the high pressure hose about a month ago, there are no leaks in the system. Besides, I hate having a whiny pump and it is (relatively) inexpensive to replace it with a new one.
It won't be that big of a deal to replace...
__________________
Old 10-28-2009, 01:47 PM   #9
STFU n00b!
when the PS pump died on my 240, I was on the track headed into a corner at about 90mph. I damn near killed myself because I couldn't turn the wheel at all. I was fortunately able to get slowed down enough and it took all my strength to fight the car around the track and back into the pits. Since I'd just paid $350 for a day of track time, I wasn't about to go home without trying. I dumped all the fluid out of the rack and did this with the water pump belt:
Car is surprisingly drivable and I've run several track events like that. just drain the ps fluid and go.
yeah, it would be better to run a true manual rack, but I'm a cheapass and will run this rack until it fails, then go to a manual rack. (It's a race car, not a DD so I'm not too worried)
__________________
Old 10-28-2009, 02:07 PM   #10
i was serious btw. i have a pump from the 89se that i'm parting out, already pulled off the car, and sitting on a shelf. lmk if you want it.
so have your arm muscles just gotten better between then and now? to go from "took all my strength to fight the car around the track" to "surprisingly drivable"? I know having a stiff clutch will make your left leg stronger than your right... my brother's 6th gen has a MASSIVELY stiff clutch, and he almost murdered my civic's rather soft clutch pedal when i let him drive it
__________________
Old 10-28-2009, 02:29 PM   #11
I Has Pushrods!
maxitech's Avatar
I appreciate the offer, Caped, but I have never been a fan of putting used moving / mechanical parts on my car...If I am going to take the time to perform the labor, I want it to last as long as possible.
__________________
Old 10-28-2009, 09:06 PM   #12
STFU n00b!
The big issue is draining the fluid from the rack. There's several small orifices that you have to force the fluid through to make it push the rack back and forth. fluids don't compress. gases do. Easily. thus, drain the rack from fluid and then loop the hoses back together to keep the dirt out of it and you don't have the ATF to force through the system like you did before. That's the biggest issue.
__________________
Old 10-28-2009, 09:08 PM   #13
oic. cuz right before I parked my max, it kept cutting power randomly, and would occasionally stall out when i would push the clutch in while making a slow turn... first indication that it stalled was always the "OH CRAP!!!" when i couldn't steer the car anymore. course the easy way to fix that was to just dump the clutch and 2nd gear to re-fire the engine, but the first time it happened it scared me, cuz i didn't hear the engine stall due to my stereo playing. i almost wonder what it would be like to drive the car with a manual rack or otherwise no p/s like you do... but the z is right about to get a brand new rack and i don't wanna screw with it.
__________________
Old 10-29-2009, 09:14 AM   #14
buy a car from him?
internetautomar's Avatar
Send a message via AIM to internetautomar
I thought you had to keep fluid in the rack so that it stays lubricated and keeps turning. that is why the lines are looped rather than plugged. At least that is what I thought.
I could always ask the rack rebuilder.
__________________
Maxima parts catalog< Website for sale
96 Green A/T gone
94 Pathfinder POS GONE! | 79 Camaro sold
98 I30t Silver on black A/T gone | 96 Granite Pearl (AKA Purple) A/T gone
92 grey VE A/T gone | 96 I30 Black gone
92 maroon VE A/T gone | 92 white VE M/T gone
92 grey VE A/T gone | 6/84 L24E last of the RWD Maxima gone
internetautomar is offline   Reply With Quote
Old 10-29-2009, 09:16 PM   #15
STFU n00b!
If I tore the rack apart and removed the orifices and hydraulic "stuff" inside it, I could fill it with fluid and it would be fine.
The reason I looped the lines was to keep dirt out and let the air flow through the system vs. fluid.
I have another rack at the house that I'm going to rebuild and remove the hydraulic guts so it's just the rack and pinion itself. this one I don't care about and don't have time to deal with so I'll just keep driving till it starts having problems. it won't just lock up and stop working, so it's not like I'm going to have a major failure and drive straight off the end of the track. it will just slowly get stiffer and/or develop some play and get harder to drive.. then I'll swap it. then again, I have a buddy that races an S13 and he's had his rack like this for about 5 years with no issues. not worried.
__________________
Old 10-29-2009, 09:20 PM   #16
STFU n00b!
Yup. there's two fixes for that.
1. don't stomp on the clutch.. leave the car in gear and your foot off the gas. you can even brake the engine down to about 4-500rpm to make a turn and then let it idle back up. jsut don't do that in heavy traffic, as lugging the engine will cause rod bearings to get eaten up from the high loads and low oil pressure.
2. fix the idle problem.
But yeah.. my car did/does the exact same thing. I think the IACV can't flow enough air at idle because of my ported heads.. it idled perfectly before the engine rebuild. now the damn thing won't idle right, but the IACV is clean and works perfectly according to CONSULT. we can enable/disable it through the ECU with CONSULT and make it idle up/down/etc... but soon as I turn the A/C on, and start tryign to suck more air into the engine at idle, it stalls out on me. grrr
__________________
Old 10-29-2009, 09:43 PM   #17
well the reason i was doing it that was so i could re-accelerate quicker by moving the shifter into 2nd mid-turn instead of post-turn. ideally i would have it in 2nd gear before slowing down at all, but that wasn't always possible. that and i had cheap tranny fluid in there so it didn't like doing big multi-gear 4000rpm downshifts like that.
i ended up fixing it tho (loose wire connection needed to be re-crimped). about a week before my suspension bushings unseated themselves
__________________
Old 10-31-2009, 10:36 PM   #18
Dang! I didn't know about the ATF deal. I have a slow leak somewhere and have been refilling with PS fluid...
Cravacor is offline   Reply With Quote
Old 11-01-2009, 09:00 AM   #19
I would install another pump Maxitech, this isn't light like a 240SX and there is no manual steering rack offered for a Maxima....So I'd leave it Oem unless you like working out and driving at the same time! Cause you probably get a hernia trying to park that beast without any p/s! I have manual steering in my little D21 HB pickup and the few times I've I let friends borrow the truck. They've always commented on that's why your arms are in good shape...your truck has no p/s!!! That was a freakin work out! But I'm used to it, 335,000 miles and I had it since 1988....LOL!
__________________
CMax03 is offline   Reply With Quote
Old 11-04-2009, 01:27 PM   #20
I Has Pushrods!
maxitech's Avatar
I'm sure I will get around to replacing it when I get back to town...Away on business ATM...
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
