Go Back   Maxima Forums > Maxima Discussions > 3rd Generation Maxima (1989-1994)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 10-27-2009, 11:58 PM   #1
2961cc
VEvolution's Avatar
Send a message via AIM to VEvolution
Shaking Violently In Reverse
Unfortunately I've been trying to sell the VE for sometime now, but was just curious as what you guys might think is up with my tranny when trying to move in reverse.
When I throw it in reverse, it shifts smooth and all, and stays in gear well, backs up fine to the first few feet, then the tranny starts shaking. Then some more. Then even more. Harder, harder, till it gets to the point where it feels like it's gonna fall out from underneath the car, and the whole car is vibrating intensely. If you try to accelerate even faster, it will stall. I once backed up really fast, just to see what would happen, and the wheels just locked up completely, leaving skid marks on the ground, and my head almost flew off. And that all happened because the car decided to stall, while I was going 10mph with the wheels locking up cause it was still in gear. Im assuming, what ever part keeps the car from stalling in reverse when your foot isn't on the clutch is broken or something. Thats my take on it. Mind you, the car will not stall but just shake badly if you do it slowly, and every other gear works just fine, minus the worn clutch.
Any insight? Thanks.
__________________
FS: My black 92' VE 5spd
http://forums.maxima.org/maximas-sal...2-ve-5spd.html
VEvolution is offline   Reply With Quote
Old 10-28-2009, 12:22 AM   #2
check your engine and transmission mounts..... as well as your driveshafts cv joints!
__________________
CMax03 is offline   Reply With Quote
Old 10-28-2009, 12:38 AM   #3
2961cc
VEvolution's Avatar
Quote:
I replaced the axels with rebuilt NAPA ones, awhile back. The tranny and engine mounts are definatly shot, but this only happens in reverse.
__________________
Old 10-28-2009, 02:05 AM   #4
Fix it and it'll probably stop! WHY DOES UNBALANCED TIRES ALWAYS VIBRATE EXCESSIVELY BETWEEN 60-70 MPH? ????
__________________
Old 10-28-2009, 06:21 AM   #5
STFU n00b!
Based on his sig and avatar and such, I'm assuming he has a 5 spd.
The only thing I can think of in that case is that your bearings are shot in the tranny and there's shrapnel floating around inside the box.
you'll have to pull the tranny apart and see what's there.
any noises when going forward? does it 'growl' at all in lower gears, possibly worse under throttle?
__________________
04 G35 Sedan 6MT- The DD
96 240SX 5 speed- The track toy
93 Maxima SE 5 speed- retired 1-5-09
Check out the toys I make on my website!
Matt93SE is offline   Reply With Quote
Old 10-28-2009, 06:25 AM   #6
LvR
There you go then - its obviously a manual! - ignore me and I will promptly go away
LvR is offline   Reply With Quote
Old 10-28-2009, 06:40 AM   #7
STFU n00b!
No you won't. we tried that with 19993-VG30E and he still comes around.
__________________
Old 10-28-2009, 09:00 AM   #8
Call me Wookiee Goldberg
CapedCadaver's Avatar
Quote:
lol i thought the part about "when your foot isn't off the clutch pedal" gave away the manual-ness
at any rate i think matt might be right about having bits and pieces jamming up inside the tranny where they don't belong. sounds like time for a new tranny unless you know how to rebuild a m/t.
__________________
PieceOut.FallToPeaces New to the forum? CLICK HERE!!!!
1985 Nissan 300zx 2-seater: VG30E | 5spd Swap | Bilstein | 5-lug conversion | Polyurethane everything | Resurrection-in-progress!
2004 Honda Civic EX Coupe: 1.7L VTEC | 5spd | CAI soon | LED tails and Projectors soon | ES Poly Motormounts soon | 'bad weather' car/backup for teh Z
1990 Nissan Maxima GXE: VG30E | VLSD-5 swap | Exedy | NWP | a33b(F)/z31(R) BBK | ES poly | SE susp swap | 2k2SE 17s | retired Aug 28th '09
2005 Nissan Maxima SE: VQ35DE | 6spd | Carolina Panthers front lisence plate | Brother's car, not mine | <-- Therefore still 100% stock
Quote:
Originally Posted by JasonOksa View Post
Horsepower, torque and speed are all known by The State of California to cause cancer, birth defects, and reproductive disorders.
Quote:
Originally Posted by bigleman View Post
how much would it cost to resleeve?
how does an aluminum motor form rust on the cylinder walls???
DO NOT PM ME ABOUT PROBLEMS WITH YOUR CAR UNLESS I TELL YOU TO. THAT'S WHAT THE FORUM IS FOR
CapedCadaver is offline   Reply With Quote
Old 10-28-2009, 05:41 PM   #9
2961cc
VEvolution's Avatar
Nooooo waayyyyy
I see.. Another member actually PM'ed me and told me he had the same exact problem and nobody could ever figure it out to this day. Oh well, was just interested. Thought it might be common.
Nope.. No growling. Same sounds since I bought it 20k miles ago. Actuallyyyyy.............. Theres a "loose change" sound when I cruise in 5th on the highway, and I hear all types of chatter in those higher gears. But thats probably something totally different.
Quote:
Yeah, I probably won't be doing this, but the new owner is free to do so (thats if there will be one)
This problem has actually started 2 years ago, but I haven't drove it much since then. Imagine one of those floating peices gets into 5 gear on the highway, and the wheels decide to lock up?
__________________
Old 10-28-2009, 05:46 PM   #10
I have an auto, and mine does the same thing in reverse, but I figure it's a bad transmission because it doesnt shift properly while in drive, and the car has lost it's power significantly
biggz2332 is offline   Reply With Quote
Old 10-28-2009, 06:02 PM   #11
2961cc
VEvolution's Avatar
Quote:
Sounds like it's time for a 5spd swap or rebuild, but rebuilds suck in my opinion.
__________________
Old 10-28-2009, 06:52 PM   #12
er... so you're just gonna junk the car? too bad i already bought the civic then! i wouldn't have minded having a VE5 since i have a ve5 tranny i coulda just tossed on there. o well too late now.
__________________
Old 10-28-2009, 09:18 PM   #13
STFU n00b!
Sounds more like main shaft or differential bearings then. Input shaft bearing failure is more common since it almost always spins faster than the mainshaft... but the mainshaft isn't impossible to kill bearings.
__________________
Old 10-28-2009, 10:21 PM   #14
2961cc
VEvolution's Avatar
Donation probably.. Maybe I'll get some decent tax return. Shame to see it go there.
It's all right, I think the Civic was a better choice and would spank the VE if modded properly
Oh yeah, now I remember our weak input shaft bearings. The turbo guys were always complaining about them.
__________________
Old 10-29-2009, 07:24 AM   #15
eh, it's not bad, but i prefer being able to launch at 900rpm instead of >1600rpm. That and not having to use 1st gear to get over speedbumps.
__________________
Old 10-29-2009, 09:18 AM   #16
buy a car from him?
internetautomar's Avatar
Send a message via AIM to internetautomar
<snip>
don't bother unless you are making 6 figures.
the way it works is that you only get to write off what they sell it for from your taxes unless they "keep" it then you may be able to write off trade in value (not retail) That is if my memory serves right.
consult a tax lawyer before donating.
__________________
Maxima parts catalog< Website for sale
96 Green A/T gone
94 Pathfinder POS GONE! | 79 Camaro sold
98 I30t Silver on black A/T gone | 96 Granite Pearl (AKA Purple) A/T gone
92 grey VE A/T gone | 96 I30 Black gone
92 maroon VE A/T gone | 92 white VE M/T gone
92 grey VE A/T gone | 6/84 L24E last of the RWD Maxima gone
internetautomar is offline   Reply With Quote
Old 10-29-2009, 01:48 PM   #17
2961cc
VEvolution's Avatar
Isn't it the other way around? If your making alot of money, you wont get squat for it. I will consult indeed, thanks.
__________________
Old 10-29-2009, 09:12 PM   #18
STFU n00b!
you will get less tax credit donating it than you will spend fixing it. a tranny rebuild is $850 or so for a shop to do. a junkyard tranny is anywhere from $75 to 750, depending on where you go. you cna rebuild it yourself for about $300 with all new bearings.
honestly.... pull the tranny out of yours and open it up. FSM tells you how step by step. get it open and take a looksee at the problems. remove shrapnel and replace broken bits (bearings are about $50-80 each from nissan, depending on which one)..
__________________
Old 10-29-2009, 09:16 PM   #19
__________________
1992 GXE l 414,000km on original tranny and original VG30E l Pioneer Premier 12" 3500w subwoofer l 600w amp l JVC H/U l aftermarket fog lights l 2.5" Magnaflow catback exhaust l Momo summer rims l Stock winter rims l Sparco Sprint driver/passenger seat w/drivers 6 point harness l Sparco Volanti steering wheel l Castrol Syntec oil/premium Vpower gas
Future mods- 5spd swap, Z31 turbo w/intercooler
This winters mods- Z31 hood scoop, digital cluster swap, lowering springs
chrome91 is offline   Reply With Quote
Old 10-29-2009, 09:25 PM   #20
Quote:
Originally Posted by chrome91 View Post
well it's true, only because of how available mods are, and the fact that lots of stuff is bolt-on-plug-and-play kits, esp. turbo kits. The maxima is a better car in terms of comfort tho.. my civic is slightly lacking in legroom (console/steering column too close to floor)
__________________
Old 10-29-2009, 09:31 PM   #21
lol i just like using squinty eyes. Civic aftermarket>3rd gen Maxima aftermarket. Urban dictionary's definition for Altezza's says "the riced light you can get for every car made", 3rd gens didnt even have any aftermarket tails
hence the bishness of my Sparco seats, Sparco has no 3rd gen bases in stock and i 99.999999999999% guarantee they wont make more, to top it off they can only be welded on manual seats, not power seats hence me needing your manual seat brackets lol.
3rd gen aftermarket= fail
__________________
Old 10-29-2009, 09:53 PM   #22
yea... but usually the cars with the most aftermarket are the ones that people like ricing up. the ones that the owners prefer to keep tasteful (in terms of appearance) don't get any aftermarket.. And the VE aftermarket is even worse than the VG-3rdgen aftermarket (well except for intake spacers)
__________________
Old 10-29-2009, 10:08 PM   #23
ive seen one scary Honda here, it was a old school JDM Accord or something, a boxy 4dr. Looked clean, but i thought it was stock and slow so i gave him the ricer look. turns out it was engine swapped, had a huge turbo, massive intercooler, and a sick BOV
at first, i was like
then i was like
but yeah, large aftermarket equals rice too. half the Hondas at pick n pull have altezzas and other rice
Sucks youre so far from me VEvolution, i'd buy that 5spd for a few hundred and keep it to do a tranny swap
__________________
Old 10-29-2009, 11:36 PM   #24
2961cc
VEvolution's Avatar
Heh, thats all great and I wish I could, but the biggest problem here is NY insurance is a killer, which is why I can't keep two cars. For me, it's $1800 for 6 months from pretty much every company(liability), so it doesn't pay. Which is why my current car is not even in my name. And ATM, moneys tight and maintaining two cars is impossible let alone one.
As for the tranny surgery, I don't have a garage. Never did. It's parked in the parking lot outside of my building and it needs to be moved asap. So Im all lucked out.
The chassis is overall better as well. Stiffer and better balanced.
Wouldn't sell it for a few hundred
Theres a brand new $600 system in there aside from the engine being healthy and body being fairly clean for such an old north eastern car. Not to mention the $300 in new parts and mods that Im throwing in as well. Unless when you meant few hundred you meant no less then $900
__________________
Old 10-30-2009, 05:23 AM   #25
and I don't have time for either thats the worst thing think imma look 4 a new one when da money comes through
Old 10-30-2009, 01:51 PM   #26
for some reason i thought the engine was shot too. with a good engine, you should find a buyer
__________________
Old 10-30-2009, 08:31 PM   #27
mine shakes like hell when its on drive while i step on the brakes at the light and a lil in reverse and its quiet and still on parking.
but i was told it was the mounts that are shot plus 2 bad injectors.
problem is when i get on the highway it takes way too long to accelerate and it feels like low power till it gains it and then it hauls ***. dirty MAF maybe? ( yes i have a intake cone) i hope its not my tranny -__-
nyc_ink is offline   Reply With Quote
Old 10-30-2009, 08:50 PM   #28
even with a m/t (ie, i could control what RPM i was at) i can tell you that the car will run like total crap if you have 2 bad injectors. the engine is unbalanced and the ECU is confused, so you really probably lose more than a third of your engine's power due to the inaccurate a/f feedback from the o2 when you have some cylinders that are not firing.
__________________
Old 10-30-2009, 08:56 PM   #29
thanks cape i guess ill have to change them when i get to south carolina cuz im driving down this sunday, i guess ill wont make it on regular ETA ...lol
i wonna check my coil packs but dont know where they are located lol
i hope thats not what the long sticks on the spark plug cables are called -__-
Old 10-30-2009, 09:46 PM   #30
vid of my start up
http://tinypic.com/r/2dt7o7m/4
you can hear the car shake
Old 10-31-2009, 06:18 AM   #31
vid of my start up
you don't have coilpacks.. only the 92-94 SE had coilpacks (the rare 24v VE engine). all GXE and 89-91 SE had the common 12v VG engine which has regular spark plug wires, a distributor, and a single ignition coil.
at any rate, OP's shake is WAY different than yours.. his is due to loose metal bits inside the tranny jamming the gears. yours is due to an engine misfire (or two)
__________________
Old 11-01-2009, 08:04 PM   #32
2961cc
VEvolution's Avatar
Neeehhh, surprisingly nobody wants it for that price. I had a lady in my area offer me $400 but I was like no thanks
I love telling people that..
My coworkers at my last job kept tryin to make fun of me when I told them that. "ooooo the raaaareee engineeeee". Little did they know the capabilities of this motor. noobs
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
