Go Back   Maxima Forums > Maxima Discussions > 3rd Generation Maxima (1989-1994)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 10-26-2009, 08:17 AM   #1
Headlight Removal
Anyone have any tips on how to get the headlights out? I can see the side lights need to come out first but cant figure that out either . All the bolts seem inaccesable. Ultimatley I want to get the front bumber off.
W00dface is offline   Reply With Quote
Old 10-26-2009, 08:24 AM   #2
Ad·min·is·tra·tor
DanNY's Avatar
pop the corner light/side light off (you know how to do that right?)
once that's off there's two bolts there. loosen them.
then behind the radiator support close to the radiator you'll see two nuts. loose those.
then there are two clips that the headlight bracket attaches to the grill...squeeze and pull or twist and the clips will pop off the headlight bracket.
unplug headlight bulb and remove all the loosen hardware and you should be good to go.
DanNY is offline   Reply With Quote
Old 10-26-2009, 08:26 AM   #3
Cheers. It's the side lights i can't get off either. I see the one screw but cant find any other bolts. Is it a case of force?
Old 10-26-2009, 08:43 AM   #4
Call me Wookiee Goldberg
CapedCadaver's Avatar
Quote:
the bolts are for the headlight after you pop the corner off. the corner is held on by that one screw, and there is also a little ball-and-socket that holds the front of the corner in place. you sort of swing the corner out like a door then pop it out of the socket thing.
__________________
PieceOut.FallToPeaces New to the forum? CLICK HERE!!!!
1985 Nissan 300zx 2-seater: VG30E | 5spd Swap | Bilstein | 5-lug conversion | Polyurethane everything | Resurrection-in-progress!
2004 Honda Civic EX Coupe: 1.7L VTEC | 5spd | CAI soon | LED tails and Projectors soon | ES Poly Motormounts soon | 'bad weather' car/backup for teh Z
1990 Nissan Maxima GXE: VG30E | VLSD-5 swap | Exedy | NWP | a33b(F)/z31(R) BBK | ES poly | SE susp swap | 2k2SE 17s | retired Aug 28th '09
2005 Nissan Maxima SE: VQ35DE | 6spd | Carolina Panthers front lisence plate | Brother's car, not mine | <-- Therefore still 100% stock
Quote:
Originally Posted by JasonOksa View Post
Horsepower, torque and speed are all known by The State of California to cause cancer, birth defects, and reproductive disorders.
Quote:
Originally Posted by bigleman View Post
how much would it cost to resleeve?
how does an aluminum motor form rust on the cylinder walls???
DO NOT PM ME ABOUT PROBLEMS WITH YOUR CAR UNLESS I TELL YOU TO. THAT'S WHAT THE FORUM IS FOR
CapedCadaver is offline   Reply With Quote
Old 10-26-2009, 08:52 AM   #5
Ad·min·is·tra·tor
DanNY's Avatar
you take off that top screw on the side light.
shine a flashlight in there..you'll see a ball and socket looking thing.
if it's real tight i stick a flat screw driver in there and pretty much separate the halfs. the ball part is part of the corner light and the socket is the headlight bracket. it'll "pop" when it comes out. then slide it forward (to the front) and unclip the wires.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
