Go Back   Maxima Forums > Maxima Discussions > 3rd Generation Maxima (1989-1994)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 10-24-2009, 10:39 PM   #1
2 VE's are better than one!
Finished JDM swap (and VE 5 conversion) - now some issues
Since I was only waiting on a clutch hard line to finish this project, I decided today to bastardize a Honda line I had laying around. So I did that, bled the clutch, and I took it for a test drive for the first time today. When I (attempt to, at least) accelerate, it seems to be losing power intermittently. It'll rev to about 2k, lose power, catch, bog, buck, nearly die, sputter, then I'll rev it some (or try to), and it'll accelerate normally for a second or two, sputter, lose power, catch, bog, etc. It died on me two times as well.
Now, in the driveway it idles just fine, and revs perfectly smooth all the way up to redline. Doesn't have a miss or putter or anything at idle or when revving in the driveway. It only does this when I'm trying to drive the thing. All injectors check out perfect (each of them is at 11.2 ohms). I swapped MAFs with one of my other cars and ruled that out.
Plugs are new, fuel filter is new, fuel pump and gas tank are new, etc.
Oddly, it kind of feels like how a car feels when it's running out of gas or something
I read through some of the older JDM swap threads I could find, and everybody mentioned changing the coolant temp sensor and I made sure to do that already. I saw other mentions of the IACV but I don't think that's the issue here because the idle doesn't hunt, surge, and isn't high. It's rock solid at about 700 rpm.
Thoughts?
__________________
Desperately looking for a 5 speed axle carrier bracket. Either VG or VE will work. PM me if you have one!
Good working door lock timers $20 shipped. PM me if interested
James92SE is offline   Reply With Quote
Old 10-24-2009, 11:03 PM   #2
I'm needing a caw
Jeff92se's Avatar
Looks like you covered it. Does it do this when it's cold and when it's warm? You could try swapping out your fuel pressure regulators.
__________________
2003 G35 Sedan. Mods comin'
3-gen parts for sale
Sold Jan 14, 2006'
Mod list:
Eibach/Konis - ST front sway bar/Addco rear bar - Blemco rstb - Otto fstb
350Z 18" touring wheels.
Modified Cattman Y, Custom flex, 4-gen Carsound cat, Custom cat-back, Y2K muffler
Custom CAI, custom ground kit, JWT ecu, Fidanza flywheel, ACT clutch, Jeff92se Cobra 13" bbk with 300zx 30mm polished alum calipers.
Jeff92se is offline   Reply With Quote
Old 10-24-2009, 11:28 PM   #3
Good question. Not sure if it does it when cold as i had it idling in the driveway for probably 10-15 minutes before I drove it. I drove it again a little later but the engine was still pretty darn warm and the temp gauge got up to operating temp immediately.
A really strange thing was occuring that I forgot to mention - when the engine was doing its goofyness when I was trying to drive it, I noticed that the gas gauge needle would fall all the way to the bottom, like, allllllllllll the way past empty (i.e., even below where the needle would be even if the tank were all the way empty). Then when I would get it back to the driveway and shut it off, and then start it up again the needle would then slowly move back up to the proper spot. WTF?
__________________
Old 10-25-2009, 01:32 AM   #4
Send a message via MSN to burhan92SE
seems like ur fuel level sending unit going bad...u should take the fuel pump out and inspect it plus check the fuel pressure if it is according to the specs...
__________________
WANT MAXIMA ON FACEBOOK? click here http://www.facebook.com/home.php#/gr...id=40968904022
Selling my VG --->http://forums.maxima.org/canadian-cl...m-edition.html
burhan92SE is offline   Reply With Quote
Old 10-25-2009, 01:39 AM   #5
LvR
Quote:
Sounds to me like a +1 .......... or bad wiring/connections to the new tank/pump etc assembly.
Slap a meter on the fuel rails and it should be easy enough to see
LvR is offline   Reply With Quote
Old 10-25-2009, 09:50 AM   #6
buy a car from him?
internetautomar's Avatar
Send a message via AIM to internetautomar
yeah, I'm thinking bad connection at the tank
__________________
Maxima parts catalog< Website for sale
96 Green A/T gone
94 Pathfinder POS GONE! | 79 Camaro sold
98 I30t Silver on black A/T gone | 96 Granite Pearl (AKA Purple) A/T gone
92 grey VE A/T gone | 96 I30 Black gone
92 maroon VE A/T gone | 92 white VE M/T gone
92 grey VE A/T gone | 6/84 L24E last of the RWD Maxima gone
internetautomar is offline   Reply With Quote
Old 10-26-2009, 12:08 PM   #7
I originally put a new pump and tank in because the old pump wouldn't even come on, and was completely coated in hard mud type stuff as well as sticky black goo. I replaced the tank because it was also coated in the same stuff and just full of rust. I spent about an hour scraping off rust/grime/muddy stuff from all over the sending unit/float deal as well as the fuel pump mounting hanger before installing the new one.
The pump I bought is a Carter semi-universal one that came with a couple of butt-connectors to wire it up, but I'm positive they're on there solidly. I did notice when it's idling it makes a sort of "churning" noise from the pump area but just chalked it up to it being an aftermarket one.
I've never had a fuel sending unit go bad. Would a bad fuel sending unit necessarily cause fuel/driveability issues aside from a flukey gas gauge though?
Anyway, I'm off tomorrow so I guess I'll just rule out an issue with the whole fuel pump "assembly" by swapping in one from one of my other and seeing how it goes.
__________________
Old 10-26-2009, 12:17 PM   #8
Call me Wookiee Goldberg
CapedCadaver's Avatar
i doubt it. i think they were suggesting that the wiring to the whole pump/sender unit as a whole had an issue, like a shared ground or something? not familiar with the exact wiring layout of that part of the car but perhaps the 2 systems have a shared wire or 2.
__________________
PieceOut.FallToPeaces New to the forum? CLICK HERE!!!!
1985 Nissan 300zx 2-seater: VG30E | 5spd Swap | Bilstein | 5-lug conversion | Polyurethane everything | Resurrection-in-progress!
2004 Honda Civic EX Coupe: 1.7L VTEC | 5spd | CAI soon | LED tails and Projectors soon | ES Poly Motormounts soon | 'bad weather' car/backup for teh Z
1990 Nissan Maxima GXE: VG30E | VLSD-5 swap | Exedy | NWP | a33b(F)/z31(R) BBK | ES poly | SE susp swap | 2k2SE 17s | retired Aug 28th '09
2005 Nissan Maxima SE: VQ35DE | 6spd | Carolina Panthers front lisence plate | Brother's car, not mine | <-- Therefore still 100% stock
Quote:
Originally Posted by JasonOksa View Post
Horsepower, torque and speed are all known by The State of California to cause cancer, birth defects, and reproductive disorders.
Quote:
Originally Posted by bigleman View Post
how much would it cost to resleeve?
how does an aluminum motor form rust on the cylinder walls???
DO NOT PM ME ABOUT PROBLEMS WITH YOUR CAR UNLESS I TELL YOU TO. THAT'S WHAT THE FORUM IS FOR
CapedCadaver is offline   Reply With Quote
Old 10-26-2009, 09:13 PM   #9
did u test the ignition coils? sounds like thats the culprit
PMAX08 is offline   Reply With Quote
Old 10-27-2009, 12:06 AM   #10
I can has?
Pearl93VE's Avatar
Send a message via AIM to Pearl93VE
Probably fuel related like others have suggested- but have you Ohmed out the CTS for ****s and giggles? We have tons of returns for bad new and reman CTS's out of the box- so... might as well rule it out.
__________________
Pearl93VE is offline   Reply With Quote
Old 10-27-2009, 08:51 AM   #11
Quote:
What is the CTS? I don't believe I've seen that acronym before
*edit* oh, duh, is it the coolant temp sensor? It's brand new, but I guess I could check it anyway.
__________________
Old 10-27-2009, 08:58 AM   #12
Coolant Temp Sending unit. It tells the ECU when the engine is warm or cold, effecting the amount of fuel supplied to the injectors.
__________________
Bill, 1992 Maxima SE, White, black leather seats, ATX with factory VLSD, completly stock.
2003 Altima SE 3.5, Black, black leather seats, HID head and driving lights, Dual Halos, Active tunning grill, Nismo CAI, Nismo STS, OBX Headers, Magnaflow Exhaust, Koni Adjustable shocks, Eibach springs, Maxima LSD, 20" wheels.
wpendl1 is offline   Reply With Quote
Old 10-27-2009, 09:01 AM   #13
This may help as well. Coolant Temp Sensor Ohms
__________________
Old 10-27-2009, 09:03 AM   #14
James, is there another thread that covers why you swapped your VE out for a JDM. I'm new to the VE world, but have gained a mountain of knowledge in the past couple weeks. I'm always looking for more information on these beasts and track records from what I can expect from mine.
__________________
Old 10-27-2009, 11:11 AM   #15
Way out West
Cliff Clavin's Avatar
Send a message via AIM to Cliff Clavin
Quote:
you can start a thread or do some searching on VE engines on this site. Lots of info.
James, you might want to swap in a full set of coils from your other VE to at least try to rule that out.
Did you check the ECU for codes? The only code my car has ever thrown was when the coolant temp sensor was bad.
good luck -- I know how frustrating these things can be
__________________
Cliff Clavin is online now   Reply With Quote
Old 10-27-2009, 11:16 AM   #16
I'm needing a caw
Jeff92se's Avatar
Probably mentioned but perhaps you are losing power to the fuel pump?
__________________
Sold Jan 14, 2006'
Mod list:
Old 10-27-2009, 02:14 PM   #17
Well, I bought the car for $200 with a blown automatic transmission. I planned to do a 5 speed swap in it just to get it going, but once I got into the engine a little bit I noticed how badly taken care of it was, and since I'd had a JDM VE in the garage for a couple years I just decided to put it in (along with replacing/rebuilding everything else on the car - this $200 car has turned into an over $3k project ).
Back to my issue - well, it turned out to be the new fuel pump. The pump was/is brand new
I pulled the pump out of one of the other VE's, and swapped it in and now the car has no bucking/dying/etc. symptoms whatsoever on acceleration. I still haven't REALLY driven it out on the open road as it's not registered/inspected yet but
I checked the new pump for maybe a bad connection (it's the kind you have to butt-connect into the factory power and ground) but couldn't find anything loose/wrong at all. It tests out fine, works just fine at idle and revving in the driveway, but acted like it was running out of gas when I tried to accelerate in gear. So who knows. I think I'm just going to buy another complete OEM pump assembly and skip the universal aftermarket type stuff.
__________________
Old 10-27-2009, 03:38 PM   #18
lol i know EXACTLY how you feel. I got my '85 z31 with a dead engine. But the front struts were also dead so i was like eh, might as well do them too. But if i do the struts i might as well put lowering springs on it while i'm at it. And if i'm gonna do that i might as well put swaybars on. And if i'm changing all that i might as well put polyurethane bushings on it. And if I do all that I'm gonna need an alignment. And if I get an alignment i might as well get new tires to further improve my handling. And if i get new tires i might as well get bigger and wider wheels and do a 5-lug swap. And if I do a 5-lug swap i might as well use the vented 87-89 rear rotors. And if i buy new rear rotors i might as well buy new front rotors too. And if I'm working on the brakes i might as well get Hawk pads and SS brake lines.......... yea. see what i mean?
__________________
Old 10-27-2009, 06:13 PM   #19
Quote:
Ha ha.. ain't that the truth. Where do you draw the line???
__________________
Old 10-27-2009, 06:28 PM   #20
it's hard to say cuz it needs a new driveshaft (siezed u-joint) and new half-shafts... so i'm debating putting an LSD also
__________________
Old 10-27-2009, 06:44 PM   #21
Quote:
Hmm. I would love to, as soon as i get enough posts to get past my Newbie state. I guess I haven't rambled on enough in the newbie thread to earn the right to post new threads.
__________________
Old 10-27-2009, 06:47 PM   #22
I got lucky on the LSD thing, the SE came with it. But I did install a helical style lsd in my 03 altima. Not a fun job by any means, but hey, it's water under the bridge now. Sure helps with winter driving, well worth the $600 for the part and fluids.
__________________
Old 10-27-2009, 07:17 PM   #23
i know.. well, the 92-94SE anyways. 89-91SE had VG and no LSD. but my 5spd Civic has an open-diff and i keep one-tire-fire'ing in the rain.... the VLSD on the VE tranny was stealthy at times but it sure kept me out of trouble on my 3rd gen.. too bad the maxima tranny won't work on the civic haha. but that's the one thing about civics, parts are very available. front/rear poly engine mount inserts from EnergySuspension were $32 shipped. I will say that the VLSD swap was worth it as long as you don't have the problems i did - getting hubs with good wheelbearings, and the stupid rusted-on shift rod yoke preventing me from changing the striking rod seal. frankly i doubt that tranny has much fluid left in it since the car has sat for 2 months.
__________________
Old 10-27-2009, 07:57 PM   #24
That's the exact same thing I did with my '89 Civic last winter. It developed an oil leak and that turned into a complete engine rebuild, MPFI conversion, rebuilt/new Si transmission, all new suspension, new paint, new door moldings, new carpet even. The thing is basically a brand new car but I ended up spending close to $4k total
And I spoke too soon on my fuel pump issue. I got it registered and insured today (still no inspection though, but insurance and registration is good enough for me to justify driving it around ), and took it out for some extended driving. The longer I drove it began hesitating/stumbling but not near as bad as the previous pump did (just driving it around the block the other day it was nearly undriveable and I was scared it would strand me).
Now, it's not near as bad as it was, but it's still noticeably stumbly/hesitant when accelerating and definitely lacking some power. So now I guess my issue is hesitation/stumbling when the engine is warmed up. I think I saw a flow-chart in the FSM for something like "hesitation when engine hot" or something, hopefully I can run through that on my next day off.
And I added up my total so far - $3,371.15, and I still have to do paint and body!
__________________
Old 10-27-2009, 08:13 PM   #25
:O That's a good amount of money to put into a $2K car.
I've got $800 into my 92 so far, and am debating spending $300 on replacing the timing chains or $650 plus fluid to swap a JDM engine into her. Then I've still got a tranny leak to fix, a leaking windshield to fix, and alignment.
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
