3rd Generation Maxima (1989-1994)Learn more about the 3rd Generation Maxima here.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access
to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
UPDATE 03/11-09:
The problem was one small 1uF 50v capacitor on the card standing up, (card with 74hc14 IC on it) (sorry, forgot to take pics before installing).
Anyone tried to fix there dead digital dash?
Most of the parts are easy to get like resistors, capacitors, transistor, harder to get would be the display drivers and some of the more specialized IC's.
Mine is dead, all voltage in place, following the FSM tells me to replace the control unit, so looking for advice to what may be worth changing.
Even better would be a schematic for the circuit boards inside it, but proparly not available..
__________________
Nissan Maxima VG30E 1990
Nissan Laurel 2.4 1987
Working fuel temp means you need to resolder the hot pins on the speedo/tach display. If they're both dead, or needs to warm up before both displays light up, then the MCU/power supply is defective and needs rebuilt.
u gotta open it up and test everything in there (if u r good at electrical)...otherwise just swap one from Junkyard...there's no info in FSM to repair the digi dash...
Now I did some more soldering, and powered it up with a +12v and GND only, and it worked, both displays light up!
Then I took it down to my car and installed it, and ofc it did not work, took it back in, still dead (but all the tiny horisontal and vertical lines in the speedo and temp glows faint red when power is connected)..
I'll let it warm up again and retry later.
Maybe because of temperature, its like +2 C out now.
__________________
if temperature is affecting it, it typically is a bad solder joint. I would just keep redoing them (after looking for obvious bad ones) until it all works.
96 Green A/T gone
94 Pathfinder POS GONE! | 79 Camaro sold
98 I30t Silver on black A/T gone | 96 Granite Pearl (AKA Purple) A/T gone
92 grey VE A/T gone | 96 I30 Black gone
92 maroon VE A/T gone | 92 white VE M/T gone
92 grey VE A/T gone | 6/84 L24E last of the RWD Maxima gone
Tried changing the scmitt trigger, did not solve the problem.
Now it may seem like the real problem is in one of the capacitors on one of the "stand up" cards, when warmed up display lights up, when cooled down display turns off.
And electrolyte capacitors tend to go bad after some years, so ordered new one, gonna replace it on tuesday, will come back with a update then.
__________________
