Go Back   Maxima Forums > Maxima Discussions > 3rd Generation Maxima (1989-1994)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 10-17-2009, 12:04 AM   #1
Send a message via AIM to Stwodahorty
On drive but does not move forward.
so today i put my car on drive, and it doesnt move. i believe its the bushing? anyone want to help me out and talked to me about what needs to be done? is it expensive to fix? once i forced it more down, it would hit and move forward.
your input is appreciated.
__________________
Maxima FTW------>
->Kyb gr2 shocks ->Eibach pro springs ->Stillen lip kit ->G35 Sedan dual tip exhaust ->2.25 inch Custom Piping Upgrade->Warpspeed Y pipe ->Power acoustik sound system
->Clarion MAX675VD touch screen head unit->Painted grill ->Intake air filter w/ adapter ->Front Strut bar ->Clear corners ->Promax Hid kit ->Mb motoring Rev rims w/ Kumho exsta AST tires.<-
Stwodahorty is offline   Reply With Quote
Old 10-17-2009, 12:13 AM   #2
mine does that, if you go straight to D she wont move, i have to move the shifter a bit towards 2 and she goes into drive
i guess its the shifter bushing, $5 to fix ive been told. not fixing it doesnt do damage but its not a pricey fix. one of those things i have to get around to doing
__________________
1992 GXE l 414,000km on original tranny and original VG30E l Pioneer Premier 12" 3500w subwoofer l 600w amp l JVC H/U l aftermarket fog lights l 2.5" Magnaflow catback exhaust l Momo summer rims l Stock winter rims l Sparco Sprint driver/passenger seat w/drivers 6 point harness l Sparco Volanti steering wheel l Castrol Syntec oil/premium Vpower gas
Future mods- 5spd swap, Z31 turbo w/intercooler
This winters mods- Z31 hood scoop, digital cluster swap, lowering springs
chrome91 is offline   Reply With Quote
Old 10-17-2009, 12:19 AM   #3
Send a message via AIM to nismomaxgtr18
When you shift into D and doesn't move, does it rev up like you're in neutral if you hit the gas?
__________________
Originator of these wheels on a 4th gen Maxima.
nismomaxgtr18 is offline   Reply With Quote
Old 10-17-2009, 12:22 AM   #4
Quote:
yea it revs up like im on neutral. once i pull back harder itll hit and move forward. the D, hasnt happened to be before until today but it has affected me from starting the car. a few times i try to start the car it doesnt start, but once you push forward on the knob itll start. i guess it wasnt fully ON park? yep.
__________________
Maxima FTW------>
Old 10-17-2009, 01:01 AM   #5
same thing happenes to me.. i was wondering about that.. how exacly do u repair sumthin like that?
Hatmanafro is offline   Reply With Quote
Old 10-17-2009, 10:31 AM   #6
2 VE's are better than one!
If it will engage drive when you put some pressure on the shifter/move the shifter then it sounds like it's most likely the bushing. It's pretty cheap and not very difficult of a fix.
__________________
Desperately looking for a 5 speed axle carrier bracket. Either VG or VE will work. PM me if you have one!
Good working door lock timers $20 shipped. PM me if interested
James92SE is offline   Reply With Quote
Old 10-17-2009, 10:33 AM   #7
yep, mine rev's but doesnt go anywhere too
i asked about this a few weeks ago and CapedCadaver wrote a good reply with a picture of what needs to be fixed, you might be able to find the thread or i dont remember if i posted it in the giant noob thread
__________________
Old 10-17-2009, 10:42 AM   #8
I just got my '94 and it has the same problem, but I don't know about the "puttin it in drive problem: because I'm always starting off in 1; however, I probably would have that problem. How can it be fixed?
road_warrior05 is offline   Reply With Quote
Old 10-17-2009, 11:02 AM   #9
here guys this thread should be really helpful: Car not starting because of shifter?
i should prolly be doing this to my max pretty soon. 220k and it has never been changed as far as i know
__________________
CAI, EGR removed, FSTB, DZ springs, SS brake lines, Cross Drilled Rotors, ES Poly bushings, 9007 upgrade, Front lip and repaint, fogs, 2x alpine type s 10's, pioneer HU Alpine Amp,
Garf is offline   Reply With Quote
Old 10-17-2009, 12:20 PM   #10
Call me Wookiee Goldberg
CapedCadaver's Avatar
all you have to do is remove the 4-5 small bolts that hold the catalytic converter heat-shield, and slide it out of the way, then just pop the cotter pin off, slide the shifter cable end off the shifter, and put the new bushing on (big side toward the shifter, small side toward the cable end). if you do it while the exhaust is cool, you can do it in under 10 minutes.
there's another bushing on the backside of the transmission, same part# as the other one, that is sort of directly below the brake master cylinder. you don't have to jack the car up to get to that one.
now i'm assuming that the car will go if you shift straight into 2 or L, right?
__________________
PieceOut.FallToPeaces New to the forum? CLICK HERE!!!!
1985 Nissan 300zx 2-seater: VG30E | 5spd Swap | Bilstein | 5-lug conversion | Polyurethane everything | Resurrection-in-progress!
2004 Honda Civic EX Coupe: 1.7L VTEC | 5spd | CAI soon | LED tails and Projectors soon | ES Poly Motormounts soon | 'bad weather' car/backup for teh Z
1990 Nissan Maxima GXE: VG30E | VLSD-5 swap | Exedy | NWP | a33b(F)/z31(R) BBK | ES poly | SE susp swap | 2k2SE 17s | retired Aug 28th '09
2005 Nissan Maxima SE: VQ35DE | 6spd | Carolina Panthers front lisence plate | Brother's car, not mine | <-- Therefore still 100% stock
Quote:
Originally Posted by JasonOksa View Post
Horsepower, torque and speed are all known by The State of California to cause cancer, birth defects, and reproductive disorders.
Quote:
Originally Posted by bigleman View Post
how much would it cost to resleeve?
how does an aluminum motor form rust on the cylinder walls???
DO NOT PM ME ABOUT PROBLEMS WITH YOUR CAR UNLESS I TELL YOU TO. THAT'S WHAT THE FORUM IS FOR
CapedCadaver is online now   Reply With Quote
Old 10-17-2009, 01:04 PM   #11
so i just came back from the mechanic. he said i need to change 2 engine mounts, and 2 transmission mounts in order for him to adjust the shifter. according to him the bushing is still usuable and not damaged. what do you guys think?
__________________
Maxima FTW------>
Old 10-17-2009, 01:06 PM   #12
he quoted me
580 including labor for original nissan engine and transmission mount
or
380 including labor for generic engine and transmission mount.
when i drive i mean, it seems really smooth, im not quite sure. its alot of money.
eff my life.
__________________
Maxima FTW------>
Old 10-17-2009, 01:09 PM   #13
$600 is almost halfway to a 5spd swap
__________________
Old 10-17-2009, 01:17 PM   #14
Quote:
i think that's the biggest load of sh*t i've ever heard........... motor mounts have absolutely NOTHING to do with the shift linkage on an automatic. nothing at all. there are metal straps mounted to the body of the trans, and on the body of the car. the sheath itself stays put, which allows the cable inside to slide and push/pull on the selector shaft on the tranny. because the sheath is affixed to the body and the tranny, the drivetrain can move relative to the body without disturbing the adjustment of the shifter.
__________________
Old 10-17-2009, 01:29 PM   #15
so i would have to take off the wsp pipe to get under there right, its above the cat?
__________________
Maxima FTW------>
Old 10-17-2009, 01:42 PM   #16
Probably tell my pops to help me out with this. so in that other thread, someone posted
is the bushing located where the red circle is?
so all i need to do is remove the heatshield,slide it down, and replace the bushing? thats it?
is there any tips or anything i need to know before performing this?
__________________
Maxima FTW------>
Old 10-17-2009, 02:19 PM   #17
I had this problem, and I thought it was normal now I will go fix it!
biggz2332 is offline   Reply With Quote
Old 10-17-2009, 09:02 PM   #18
thar she be, i made a thread i guess
why does it do this?
__________________
Old 10-17-2009, 09:06 PM   #19
yea, where the red circle is. there is 1 bolt that is gonna be harder to get to than the rest of them (the middle-rear bolt) but the other ones are easy to get to. luckily my middle-rear bolt was rusted out so i didn't have to touch it the heatshield itself you're going to have to bend just a little bit, but it will regain its shape naturally once you put it back in its proper position. it's pretty springy.
just don't lose the washer that sits between the cable-end and cotter pin.
__________________
Old 10-17-2009, 10:24 PM   #20
do i need to take off the wsp or can i work around it?
and also what are the symtoms of needing new engine and transmission mounts?
cuz when i drive it seems fine but iono my mechanic said i need new ones. please let me know, thanks alot capedcadaver, uve been a great help bro.
__________________
Maxima FTW------>
Old 10-17-2009, 10:50 PM   #21
Judging by your threads in recent months - your mechanic sure seems to make an absolute killing off of you.
No you don't have to take the exhaust off. You just have to remove the heat shield above the cat. Once you do that, you can change the bushing in about 30 seconds tops
You should be able to inspect the mounts visually. You can inspect them quite easily. Just look at them - if they're not torn/split/cracked/etc. then they are likely fine. Generally on an automatic if your engine/transmission mounts are shot, then your car will "lunge" (or "clunk") pretty hard when you put it into gear. The fact that you have the play in your shifter wherein you need to just nudge it a little further back points almost exclusively to the shifter bushing.
__________________
Old 10-19-2009, 05:30 PM   #22
does anyone have a pics of what the bushing/insulator looks like, so i can get an idea of what im dealing with.
__________________
Maxima FTW------>
Old 10-19-2009, 05:36 PM   #23
i saw your video capedcadaver,
is the bushing a rubber piece that goes in between?
__________________
Maxima FTW------>
Old 10-19-2009, 05:46 PM   #24
and also, wheres the best place i can pick up the bushing, autozone? kragen? please let me know.
__________________
Maxima FTW------>
Old 10-19-2009, 06:37 PM   #25
i took my Max in to get some other stuff looked at, and asked them to look at my bushing because i have to wiggle the shifter in D and it does that crap where i have to rock her back and forth and you hear a click then she lets you start her
they said my bushing is fine and my whole shifter is fine? what else could cause it?
__________________
Old 10-19-2009, 07:38 PM   #26
funny thing, my mechanic said my bushing is fine, and i had my dad take a look at it today, he said it was fine also, however, our knobs might be a bit loose. we can possibly fix that problem by taking the cover off and unscrewing it to see what is loose so that we can tighten it. if i fix the problem this way, ill keep you update don what you need to tighten.
on another note, when i took my car to the mechanic, he said i need new engine mounts and transmission mounts, but when i tried to shake my engine today it doesnt shake one bit, when i start the car, and switch the gears, it jerks which is probably normal. my mechanic said that if the engine and transmission moves, it can possible move the shifter. so im kind of lost myself, i dont want to pay 580 bucks for something thats not broken. ill keep you updated if i find the problem. cuz my mechanic and dad said that my bushing is fine also.
__________________
Maxima FTW------>
Old 10-20-2009, 07:17 AM   #27
buy a car from him?
internetautomar's Avatar
Send a message via AIM to internetautomar
if your motor jumps when you put it into gear, then you need mounts. Do all of them at once otherwise you will be continually replacing them because once one goes it takes out the next weakest one.
__________________
Maxima parts catalog< Website for sale
96 Green A/T gone
94 Pathfinder POS GONE! | 79 Camaro sold
98 I30t Silver on black A/T gone | 96 Granite Pearl (AKA Purple) A/T gone
92 grey VE A/T gone | 96 I30 Black gone
92 maroon VE A/T gone | 92 white VE M/T gone
92 grey VE A/T gone | 6/84 L24E last of the RWD Maxima gone
internetautomar is offline   Reply With Quote
Old 10-20-2009, 10:57 AM   #28
Quote:
jumps or jerks? or is that the same, it jerks a bit . but when i drive it seems smooth. so much **** to fix and iono where to start -___-
__________________
Maxima FTW------>
Old 10-20-2009, 10:58 AM   #29
and also what do you guys think of generic mounts as oppose to nissan oem mounts. its a 200 dollar differents pretty much.
580 nissan including labor
380 generic including labor.
he said once i replace those he can adjust it so that i can put my car on drive to work properly.
__________________
Maxima FTW------>
Old 10-20-2009, 11:05 AM   #30
buy a car from him?
generic mounts will be fine if he gets the right ones.
__________________
96 Green A/T gone
Old 10-20-2009, 12:03 PM   #31
what about the life on both? its probably ovious that nissan oem parts last longer, but how bout the generics.
__________________
Maxima FTW------>
Old 10-20-2009, 01:00 PM   #32
actually i have had HUGE problems with generic motor mounts. the absolute only way they would fit was to grind down the xmember. they are garbage. oem all the way for motor mounts. tranny mounts can probably go generic tho.
__________________
Old 10-20-2009, 01:34 PM   #33
because the tranny doesnt move all that much right.
__________________
Maxima FTW------>
Old 10-20-2009, 02:03 PM   #34
im so lost i dont even know where to start. i originally came to my mechanic to figure out what to do with the Drive and Park. Cuz sometimes when im on park i cant start the car unless i push the knob up. As for D i doesnt move up unless i pull it down hard or go into 2 then push it back to D. my mechanic said my bushing is fine, and my dad checked it out he said it was fine too, its not warn out or cracked or anything. so now i have 3 problems i needa fix and i have no idea what to do.
1. need to fix the P & D problem
2. supposedly need to change my engine and transmission mounts ( if i do this itll fix the p & d problem, however its alot of money)
3. the hissing problem which is coming from my exhaust manifold, supposedly i need a new gasket, on top of that there are 3-5 bolts stripped, so they need to drill it to take out the broken bolts. -_________- this can probably wait not quite sure. FML.
what do you guys thing i should do.
oh and also just to make sure theres 2 engine mounts and 2 transmission mounts correct?
__________________
Maxima FTW------>
Old 10-20-2009, 06:57 PM   #35
nevermind, so my dad took a better look today, turns out it was the bushing, probably pick it up at nissan dealership tomarow.
__________________
Maxima FTW------>
Old 10-20-2009, 07:44 PM   #36
one more bit of proof that your mechanic is a cawk.
i guess you know i had a feeling it would be this all along
__________________
Old 10-20-2009, 07:48 PM   #37
haha yeah man. my dad took another look turns out it came out exactly like your video. the insulator is totally missing. the part number in the other thread isnt correct tho.
the part number is 34552-D4000. just picked it up right now, my dads gonna do it for me tomarow. good thing i didnt blow 580 bucks. i still needa fix the hissing problem tho, ill probably take it somewhere else to do it. iono want him ripping me off.
__________________
Maxima FTW------>
Old 10-20-2009, 07:52 PM   #38
my mechanic is actually a great mechanic, but this is the very first it just didnt seem right you know. cuz when i drive its smooth as hell, and im thinkin wtf does that have to do with the shifting. -_-
__________________
Maxima FTW------>
Old 10-21-2009, 01:12 AM   #39
This bushing always go bad in these 3rd gens.
I'm posting these pics for reference:
__________________
All*Pro is offline   Reply With Quote
Old 10-21-2009, 07:54 AM   #40
yea the way it's mounted is similar to the brake cables on a mountain bike.. you can turn the handlebars whichever way and it has no effect on the adjustment of the cable.
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
